[STM32F1] 我的ADC直输出2~8或者4088~4095
3646|19
 楼主| 电子小龙 发表于 2015-10-28 13:25 | 显示全部楼层 |阅读模式
ADC, DMA, DM, ni, ST
我的ADC1输出要么是2啊3啊8啊,要么就是输出4095或者4092或者4088,就是没有中间值,我测了我的AD端口当模拟输入为0V时,ADC1转换结果是2~8,当模拟输入0.16V时ADC1输出4084~4095,是PC0(模拟输入)最大也才1V,这个是哪哪了问题?麻烦帮我看看,谢谢了。
ADC初始化代码如下:
void Adc_Init(void)
ADC_InitTypeDef       ADC_InitStructure;
DMA_InitTypeDef       DMA_InitStructure;
GPIO_InitTypeDef      GPIO_InitStructure;
//时钟使能
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1, ENABLE );
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
RCC_ADCCLKConfig(RCC_PCLK2_Div6);
//IO初始化
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_Init(GPIOC, &GPIO_InitStructure);
  //DMA初始化
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&(ADC1->DR);
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADCConvertedValue;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_BufferSize = 12;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
DMA_Cmd(DMA1_Channel1, ENABLE);
//ADC1初始化
ADC_DeInit(ADC1);
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel = 6;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 6, ADC_SampleTime_239Cycles5 );
ADC_DMACmd(ADC1, ENABLE);
ADC_Cmd(ADC1, ENABLE);
ADC_ResetCalibration(ADC1);
while(ADC_GetResetCalibrationStatus(ADC1));
ADC_StartCalibration(ADC1);
while(ADC_GetCalibrationStatus(ADC1));
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
643757107 发表于 2015-10-28 14:22 | 显示全部楼层
给你个例程看看
  1. /**
  2.   ******************************************************************************
  3.   * [url=home.php?mod=space&uid=288409]@file[/url]    ADC/ADC_RegularConversion_DMA/Src/main.c
  4.   * [url=home.php?mod=space&uid=187600]@author[/url]  MCD Application Team
  5.   * [url=home.php?mod=space&uid=895143]@version[/url] V1.0.0
  6.   * [url=home.php?mod=space&uid=212281]@date[/url]    25-June-2015
  7.   * [url=home.php?mod=space&uid=247401]@brief[/url]   This example describes how to use the DMA to transfer
  8.   *          continuously converted data.
  9.   ******************************************************************************
  10.   * @attention
  11.   *
  12.   * <h2><center>© COPYRIGHT(c) 2015 STMicroelectronics</center></h2>
  13.   *
  14.   * Redistribution and use in source and binary forms, with or without modification,
  15.   * are permitted provided that the following conditions are met:
  16.   *   1. Redistributions of source code must retain the above copyright notice,
  17.   *      this list of conditions and the following disclaimer.
  18.   *   2. Redistributions in binary form must reproduce the above copyright notice,
  19.   *      this list of conditions and the following disclaimer in the documentation
  20.   *      and/or other materials provided with the distribution.
  21.   *   3. Neither the name of STMicroelectronics nor the names of its contributors
  22.   *      may be used to endorse or promote products derived from this software
  23.   *      without specific prior written permission.
  24.   *
  25.   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  26.   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  27.   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  28.   * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  29.   * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  30.   * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  31.   * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  32.   * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  33.   * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  34.   * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  35.   *
  36.   ******************************************************************************
  37.   */
  38. /* Includes ------------------------------------------------------------------*/
  39. #include "main.h"
  40. /** @addtogroup STM32F7xx_HAL_Examples
  41.   * @{
  42.   */
  43. /** @addtogroup ADC_RegularConversion_DMA
  44.   * @{
  45.   */
  46. /* Private typedef -----------------------------------------------------------*/
  47. /* Private define ------------------------------------------------------------*/
  48. /* Private macro -------------------------------------------------------------*/
  49. /* Private variables ---------------------------------------------------------*/
  50. /* ADC handler declaration */
  51. ADC_HandleTypeDef    AdcHandle;
  52. /* Variable used to get converted value */
  53. __IO uint16_t uhADCxConvertedValue = 0;
  54. /* Private function prototypes -----------------------------------------------*/
  55. void SystemClock_Config(void);
  56. static void Error_Handler(void);
  57. static void MPU_Config(void);
  58. static void CPU_CACHE_Enable(void);
  59. /* Private functions ---------------------------------------------------------*/
  60. /**
  61.   * @brief  Main program.
  62.   * @param  None
  63.   * @retval None
  64.   */
  65. int main(void)
  66. {
  67.   ADC_ChannelConfTypeDef sConfig;
  68.   /* Configure the MPU attributes as Write Through */
  69.   MPU_Config();
  70.   /* Enable the CPU Cache */
  71.   CPU_CACHE_Enable();
  72.   /* STM32F7xx HAL library initialization:
  73.        - Configure the Flash prefetch
  74.        - Systick timer is configured by default as source of time base, but user
  75.          can eventually implement his proper time base source (a general purpose
  76.          timer for example or other time source), keeping in mind that Time base
  77.          duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
  78.          handled in milliseconds basis.
  79.        - Set NVIC Group Priority to 4
  80.        - Low Level Initialization
  81.      */
  82.   HAL_Init();
  83.   /* Configure the system clock to 216 MHz */
  84.   SystemClock_Config();
  85.   /* Configure LED1 */
  86.   BSP_LED_Init(LED1);
  87.   /*##-1- Configure the ADC peripheral #######################################*/
  88.   AdcHandle.Instance          = ADCx;
  89.
  90.   AdcHandle.Init.ClockPrescaler        = ADC_CLOCKPRESCALER_PCLK_DIV4;
  91.   AdcHandle.Init.Resolution            = ADC_RESOLUTION_12B;
  92.   AdcHandle.Init.ScanConvMode          = DISABLE;                       /* Sequencer disabled (ADC conversion on only 1 channel: channel set on rank 1) */
  93.   AdcHandle.Init.ContinuousConvMode    = ENABLE;                        /* Continuous mode disabled to have only 1 conversion at each conversion trig */
  94.   AdcHandle.Init.DiscontinuousConvMode = DISABLE;                       /* Parameter discarded because sequencer is disabled */
  95.   AdcHandle.Init.NbrOfDiscConversion   = 0;
  96.   AdcHandle.Init.ExternalTrigConvEdge  = ADC_EXTERNALTRIGCONVEDGE_NONE;        /* Conversion start trigged at each external event */
  97.   AdcHandle.Init.ExternalTrigConv      = ADC_EXTERNALTRIGCONV_T1_CC1;
  98.   AdcHandle.Init.DataAlign             = ADC_DATAALIGN_RIGHT;
  99.   AdcHandle.Init.NbrOfConversion       = 1;
  100.   AdcHandle.Init.DMAContinuousRequests = ENABLE;
  101.   AdcHandle.Init.EOCSelection          = DISABLE;
  102.   if (HAL_ADC_Init(&AdcHandle) != HAL_OK)
  103.   {
  104.     /* ADC initialization Error */
  105.     Error_Handler();
  106.   }
  107.   /*##-2- Configure ADC regular channel ######################################*/
  108.   sConfig.Channel      = ADC_CHANNEL_8;
  109.   sConfig.Rank         = 1;
  110.   sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
  111.   sConfig.Offset       = 0;
  112.   if (HAL_ADC_ConfigChannel(&AdcHandle, &sConfig) != HAL_OK)
  113.   {
  114.     /* Channel Configuration Error */
  115.     Error_Handler();
  116.   }
  117.   /*##-3- Start the conversion process #######################################*/
  118.   if(HAL_ADC_Start_DMA(&AdcHandle, (uint32_t*)&uhADCxConvertedValue, 1) != HAL_OK)
  119.   {
  120.     /* Start Conversation Error */
  121.     Error_Handler();
  122.   }
  123.   /* Infinite loop */
  124.   while (1)
  125.   {
  126.     if (uhADCxConvertedValue > 2700)
  127.     {
  128.       BSP_LED_Off(LED1);
  129.     }
  130.     else
  131.     {
  132.       BSP_LED_On(LED1);
  133.     }
  134.   }
  135. }
  136. /**
  137.   * @brief  System Clock Configuration
  138.   *         The system Clock is configured as follow :
  139.   *            System Clock source            = PLL (HSE)
  140.   *            SYSCLK(Hz)                     = 216000000
  141.   *            HCLK(Hz)                       = 216000000
  142.   *            AHB Prescaler                  = 1
  143.   *            APB1 Prescaler                 = 4
  144.   *            APB2 Prescaler                 = 2
  145.   *            HSE Frequency(Hz)              = 25000000
  146.   *            PLL_M                          = 25
  147.   *            PLL_N                          = 432
  148.   *            PLL_P                          = 2
  149.   *            PLL_Q                          = 9
  150.   *            VDD(V)                         = 3.3
  151.   *            Main regulator output voltage  = Scale1 mode
  152.   *            Flash Latency(WS)              = 7
  153.   * @param  None
  154.   * @retval None
  155.   */
  156. void SystemClock_Config(void)
  157. {
  158.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  159.   RCC_OscInitTypeDef RCC_OscInitStruct;
  160.   HAL_StatusTypeDef ret = HAL_OK;
  161.   /* Enable HSE Oscillator and activate PLL with HSE as source */
  162.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  163.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  164.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  165.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  166.   RCC_OscInitStruct.PLL.PLLM = 25;
  167.   RCC_OscInitStruct.PLL.PLLN = 432;
  168.   RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  169.   RCC_OscInitStruct.PLL.PLLQ = 9;
  170.
  171.   ret = HAL_RCC_OscConfig(&RCC_OscInitStruct);
  172.   if(ret != HAL_OK)
  173.   {
  174.     while(1) { ; }
  175.   }
  176.
  177.   /* Activate the OverDrive to reach the 216 MHz Frequency */
  178.   ret = HAL_PWREx_EnableOverDrive();
  179.   if(ret != HAL_OK)
  180.   {
  181.     while(1) { ; }
  182.   }
  183.
  184.   /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2 clocks dividers */
  185.   RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
  186.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  187.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  188.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  189.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  190.
  191.   ret = HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7);
  192.   if(ret != HAL_OK)
  193.   {
  194.     while(1) { ; }
  195.   }
  196. }
  197. /**
  198.   * @brief  This function is executed in case of error occurrence.
  199.   * @param  None
  200.   * @retval None
  201.   */
  202. static void Error_Handler(void)
  203. {
  204.   while (1)
  205.   {
  206.     /* LED1 blinks */
  207.     BSP_LED_Toggle(LED1);
  208.     HAL_Delay(20);
  209.   }
  210. }
  211. /**
  212.   * @brief  Conversion complete callback in non blocking mode
  213.   * @param  AdcHandle : AdcHandle handle
  214.   * [url=home.php?mod=space&uid=536309]@NOTE[/url]   This example shows a simple way to report end of conversion, and
  215.   *         you can add your own implementation.
  216.   * @retval None
  217.   */
  218. void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* AdcHandle)
  219. {
  220.   /* Turn LED1 on: Transfer process is correct */
  221.   BSP_LED_On(LED1);
  222. }
  223. #ifdef  USE_FULL_ASSERT
  224. /**
  225.   * @brief  Reports the name of the source file and the source line number
  226.   *         where the assert_param error has occurred.
  227.   * @param  file: pointer to the source file name
  228.   * @param  line: assert_param error line source number
  229.   * @retval None
  230.   */
  231. void assert_failed(uint8_t *file, uint32_t line)
  232. {
  233.   /* User can add his own implementation to report the file name and line number,
  234.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  235.   /* Infinite loop */
  236.   while (1)
  237.   {
  238.   }
  239. }
  240. #endif
  241. /**
  242.   * @brief  Configure the MPU attributes as Write Through for SRAM1/2.
  243.   * @note   The Base Address is 0x20010000 since this memory interface is the AXI.
  244.   *         The Region Size is 256KB, it is related to SRAM1 and SRAM2  memory size.
  245.   * @param  None
  246.   * @retval None
  247.   */
  248. static void MPU_Config(void)
  249. {
  250.   MPU_Region_InitTypeDef MPU_InitStruct;
  251.
  252.   /* Disable the MPU */
  253.   HAL_MPU_Disable();
  254.   /* Configure the MPU attributes as WT for SRAM */
  255.   MPU_InitStruct.Enable = MPU_REGION_ENABLE;
  256.   MPU_InitStruct.BaseAddress = 0x20010000;
  257.   MPU_InitStruct.Size = MPU_REGION_SIZE_256KB;
  258.   MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
  259.   MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
  260.   MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
  261.   MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
  262.   MPU_InitStruct.Number = MPU_REGION_NUMBER0;
  263.   MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
  264.   MPU_InitStruct.SubRegionDisable = 0x00;
  265.   MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
  266.   HAL_MPU_ConfigRegion(&MPU_InitStruct);
  267.   /* Enable the MPU */
  268.   HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
  269. }
  270. /**
  271.   * @brief  CPU L1-Cache enable.
  272.   * @param  None
  273.   * @retval None
  274.   */
  275. static void CPU_CACHE_Enable(void)
  276. {
  277.   /* Enable I-Cache */
  278.   SCB_EnableICache();
  279.   /* Enable D-Cache */
  280.   SCB_EnableDCache();
  281. }
  282. /**
  283.   * @}
  284.   */
  285. /**
  286.   * @}
  287.   */
  288. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
gmm2015 发表于 2015-10-28 15:44 | 显示全部楼层
要开启管脚的复用功能的时钟:   RCC_APB2Periph_AFIO
lefeng 发表于 2015-10-29 10:34 | 显示全部楼层
ADC用的片上吗,参考电压是多少
 楼主| 电子小龙 发表于 2015-10-29 17:15 | 显示全部楼层
我试了的,还是一样的结果,,,
 楼主| 电子小龙 发表于 2015-10-29 17:18 | 显示全部楼层
ADC用的片上吗,参考电压是多少
你好,,是的片上AD电路是这样的:
 楼主| 电子小龙 发表于 2015-10-29 17:24 | 显示全部楼层
你好,,是的片上AD电路是这样的:
参考电压直接和3.3V电源电压接在一起,麻烦帮我分析下哪些地方可能出问题,,谢谢了,,,
gmm2015 发表于 2015-10-29 17:41 | 显示全部楼层
你的AD输入电压是如何输入的,发电路上来看看。  你用表测量过AD相关管脚的电压了吗?
september7 发表于 2015-10-29 18:35 | 显示全部楼层
烧官方的例程看看。不应该吧,AD是很简单的
 楼主| 电子小龙 发表于 2015-10-29 22:09 | 显示全部楼层
你的AD输入电压是如何输入的,发电路上来看看。  你用表测量过AD相关管脚的电压了吗? ...
模拟输入口我都测量了,当时0.06V时候AD转换结果是8,模拟输入口电压接近0.16V时候AD结果是4085,就没有中间值,本身是个很简单的东西,各种都测了,现在没得办法,麻烦帮我分析下,不行只有换片子了,,,
 楼主| 电子小龙 发表于 2015-10-29 22:11 | 显示全部楼层
模拟输入口我都测量了,当时0.06V时候AD转换结果是8,模拟输入口电压接近0.16V时候AD结果是4085,就没有 ...
另外,我用的是STM32F103VC -100脚的片子,,,前一版用STM32F103RB的片子AD没有问题,不知道是不是片子问题,,,
 楼主| 电子小龙 发表于 2015-10-29 22:12 | 显示全部楼层
我都对比了不知道多少次了,,
gmm2015 发表于 2015-10-30 13:37 | 显示全部楼层
1、Vref+和Vref-管脚有测量过没? 要在单片机的管脚上测量,不要在走线上测量,以便确认硬件焊接没问题。
2、你就一块PCBA吗?有的话,换一块试试。
 楼主| 电子小龙 发表于 2015-10-30 21:21 | 显示全部楼层
2 ...
谢谢啊,问题找到了,很低级的错误,,我把通道10弄成通道0了
会飞の鱼 发表于 2015-10-30 23:14 | 显示全部楼层
楼主问题解决了就好,感觉写的最多的就是初始化了,也是很容易忽视的地方。
boy1990 发表于 2015-10-30 23:27 | 显示全部楼层
楼主,请问什么是2~8或者4088~4095啊
 楼主| 电子小龙 发表于 2015-11-1 13:04 | 显示全部楼层
楼主问题解决了就好,感觉写的最多的就是初始化了,也是很容易忽视的地方。 ...
就是初始化问题,,,谢谢啊,,,呵呵
 楼主| 电子小龙 发表于 2015-11-1 13:07 | 显示全部楼层
就是AD转换结果啊,,,引脚没有初始化到对应引脚,也就是转换的是数字输入电平电压,2~8就是低电平了,4088~4095就是高电平了,呵呵,,初始化问题,,现在解决了,,呵呵
boy1990 发表于 2015-11-10 20:00 | 显示全部楼层
就是AD转换结果啊,,,引脚没有初始化到对应引脚,也就是转换的是数字输入电平电压,2~8就是低电平了,4 ...
嗯呢 楼主问题解决就好:lol
september7 发表于 2015-11-24 11:26 | 显示全部楼层
好low的错误
个人签名:奋斗啊....奋斗!
16
