[STM32F1] 请教官方停机模式例程的问题
1057|6
 楼主| wang2945 发表于 2015-10-29 09:59 | 显示全部楼层 |阅读模式
ST, TI, se, TE, rc
最近利用了ST官方提供的进入停机模式的例程 设置了3秒的闹钟唤醒和外部中断唤醒,可是不明白的是,程序中还开启了systick中断,1ms产生一次中断,这样还可以进入停机模式吗?
以下是程序例程
#include "stm32f10x.h"
#include "stm32_eval.h"
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup PWR_STOP
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
extern __IO uint32_t TimingDelay;
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void SYSCLKConfig_STOP(void);
void EXTI_Configuration(void);
void RTC_Configuration(void);
void NVIC_Configuration(void);
void SysTick_Configuration(void);
void Delay(__IO uint32_t nTime);
/* Private functions ---------------------------------------------------------*/
  * @brief   Main program.
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* Initialize LEDs and Key Button mounted on STM3210X-EVAL board */
  STM_EVAL_LEDInit(LED1);
  STM_EVAL_LEDInit(LED2);
  STM_EVAL_LEDInit(LED3);
  STM_EVAL_PBInit(BUTTON_KEY, BUTTON_MODE_EXTI);
  /* Enable PWR and BKP clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE);
  /* Configure EXTI Line to generate an interrupt on falling edge */
  EXTI_Configuration();
  /* Configure RTC clock source and prescaler */
  RTC_Configuration();
  /* NVIC configuration */
  NVIC_Configuration();
  /* Configure the SysTick to generate an interrupt each 1 millisecond */
  SysTick_Configuration();
  /* Turn on LED1 */
  STM_EVAL_LEDOn(LED1);
  while (1)
    /* Insert 1.5 second delay */
    Delay(1500);
    /* Wait till RTC Second event occurs */
    RTC_ClearFlag(RTC_FLAG_SEC);
    while(RTC_GetFlagStatus(RTC_FLAG_SEC) == RESET);
    /* Alarm in 3 second */
    RTC_SetAlarm(RTC_GetCounter()+ 3);
    /* Wait until last write operation on RTC registers has finished */
    RTC_WaitForLastTask();
    /* Turn off LED1 */
    STM_EVAL_LEDOff(LED1);
    /* Request to enter STOP mode with regulator in low power mode*/
    PWR_EnterSTOPMode(PWR_Regulator_LowPower, PWR_STOPEntry_WFI);
    /* At this stage the system has resumed from STOP mode -------------------*/
    /* Turn on LED1 */
    /* Configures system clock after wake-up from STOP: enable HSE, PLL and select
       PLL as system clock source (HSE and PLL are disabled in STOP mode) */
    SYSCLKConfig_STOP();
  * @brief  Configures system clock after wake-up from STOP: enable HSE, PLL
  *         and select PLL as system clock source.
  * @param  None
  * @retval None
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
#ifdef STM32F10X_CL
    /* Enable PLL2 */
    RCC_PLL2Cmd(ENABLE);
    /* Wait till PLL2 is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLL2RDY) == RESET)
#endif
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
  * @brief  Configures EXTI Lines.
  * @param  None
  * @retval None
  EXTI_InitTypeDef EXTI_InitStructure;
  /* Configure EXTI Line17(RTC Alarm) to generate an interrupt on rising edge */
  EXTI_ClearITPendingBit(EXTI_Line17);
  EXTI_InitStructure.EXTI_Line = EXTI_Line17;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  * @brief  Configures RTC clock source and prescaler.
  * @param  None
  * @retval None
  /* RTC clock source configuration ------------------------------------------*/
  /* Allow access to BKP Domain */
  PWR_BackupAccessCmd(ENABLE);
  /* Reset Backup Domain */
  BKP_DeInit();
  /* Enable the LSE OSC */
  RCC_LSEConfig(RCC_LSE_ON);
  /* Wait till LSE is ready */
  while(RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET)
  /* Select the RTC Clock Source */
  RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
  /* Enable the RTC Clock */
  RCC_RTCCLKCmd(ENABLE);
  /* RTC configuration -------------------------------------------------------*/
  /* Wait for RTC APB registers synchronisation */
  RTC_WaitForSynchro();
  /* Set the RTC time base to 1s */
  RTC_SetPrescaler(32767);
  /* Enable the RTC Alarm interrupt */
  RTC_ITConfig(RTC_IT_ALR, ENABLE);
  * @brief  Configures NVIC and Vector Table base location.
  * @param  None
  * @retval None
  NVIC_InitTypeDef NVIC_InitStructure;
  /* 2 bits for Preemption Priority and 2 bits for Sub Priority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  NVIC_InitStructure.NVIC_IRQChannel = RTCAlarm_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  * @brief  Configures the SysTick to generate an interrupt each 1 millisecond.
  * @param  None
  * @retval None
  /* Setup SysTick Timer for 1 msec interrupts  */
  if (SysTick_Config(SystemCoreClock / 1000))
    /* Capture error */
    while (1);
  /* Set SysTick Priority to 3 */
  NVIC_SetPriority(SysTick_IRQn, 0x0C);
  * @brief  Inserts a delay time.
  * @param  nTime: specifies the delay time length, in milliseconds.
  * @retval None
  TimingDelay = nTime;
  while(TimingDelay != 0);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
eggbiscuit 发表于 2015-10-29 19:16 | 显示全部楼层
可以的,这样是不冲突的
 楼主| wang2945 发表于 2015-10-29 20:02 | 显示全部楼层
可以的,这样是不冲突的
您好,我想问下,那这样systick不是一直产生中断吗?那不会一直唤醒?
734774645 发表于 2015-10-29 20:49 | 显示全部楼层
systick的中断是提供时钟的吧,跟其他无关。
 楼主| wang2945 发表于 2015-10-29 23:03 | 显示全部楼层
但是进入停机之后,发生中断不是会进行唤醒吗?
734774645 发表于 2015-10-30 16:39 | 显示全部楼层
这个滴答的中断应该不会,这个是无论什么时候都在走。就是个表啊。停止了,咋计时。
 楼主| wang2945 发表于 2015-10-31 18:08 | 显示全部楼层
这个滴答的中断应该不会,这个是无论什么时候都在走。就是个表啊。停止了,咋计时。  ...
额,试过了如果使能了,便无法进入停机模式,所以也只能进入之前禁能,唤醒之后使能了。
