FX3/FX2G2 通过Pin来控制从USB启动
2412|0
 楼主| zengweitotty 发表于 2015-11-4 12:03 | 显示全部楼层 |阅读模式
新手入门的系列文档【原创】
     原有设计从SPI/I2C 启动,如何通过GPIO来选择从USB启动。
上电启动后,判断引脚状态,是否选择破环原有启动镜像。
#ifdef UART_BOOT
    CyBool_t boot_value = 0;
    uint8_t release_count = 0;
    for(uint8_t i = 0;i < 30;i++){
        if(CyU3PGpioSimpleGetValue (BOOTPIN, &boot_value) == CY_U3P_SUCCESS){
            if(boot_value == CyFalse){
                if(release_count++ >= RELEASE_COUNT){
                    bootfromusb();
            }else{
                release_count = 0;
        CyU3PBusyWait(100);
#endif
破环之前EEPROM上存储的镜像。
#ifdef UART_BOOT
void CyI2cInit(void){
    CyU3PI2cConfig_t i2cConfig;
    CyU3PReturnStatus_t apiRetStatus;
    apiRetStatus = CyU3PI2cInit ();
    if (apiRetStatus != CY_U3P_SUCCESS)
        CyU3PDebugPrint (4, "I2C initialization failed!\n");
        CyFxAppErrorHandler (apiRetStatus);
    /*  Set I2C Configuration */
    i2cConfig.bitRate    = 100000;      /*  100 KHz */
    i2cConfig.isDma      = CyFalse;
    i2cConfig.busTimeout = 0xffffffffU;
    i2cConfig.dmaTimeout = 0xffff;
    apiRetStatus = CyU3PI2cSetConfig (&i2cConfig, NULL);
    if (CY_U3P_SUCCESS != apiRetStatus)
        CyU3PDebugPrint (4, "I2C configuration failed!\n");
static void I2CAccessDelay(CyU3PReturnStatus_t status){
    /* Add a 10us delay if the I2C operation that preceded this call was successful. */
    if (status == CY_U3P_SUCCESS)
        CyU3PBusyWait(10);
/*I2C write stream function*/
CyU3PReturnStatus_t masterWrite_register(uint8_t slaveAddr, uint16_t regAddr, uint8_t* regData,uint16_t byteCount){
    CyU3PReturnStatus_t apiRetStatus = CY_U3P_SUCCESS;
    CyU3PI2cPreamble_t preamble;
    for(uint8_t i = 0;i < byteCount;i++){
        preamble.buffer[0] = slaveAddr & I2C_SLAVEADDR_MASK; /*  Mask out the transfer type bit. */
        preamble.buffer[1] = (uint8_t)(regAddr >> 7);
        preamble.buffer[2] = (uint8_t)(regAddr);
        preamble.length = 3;
        preamble.ctrlMask = 0x0000; /*  Send start bit after third byte of preamble. */
        apiRetStatus = CyU3PI2cTransmitBytes(&preamble, &regData[i], 1, 0);
        I2CAccessDelay(apiRetStatus);
    return apiRetStatus;
void bootfromusb(){
    uint8_t temp[I2C_COUNT];
    masterWrite_register(I2C_DEVICE_ADDR,0x00,temp,I2C_COUNT);
    CyU3PDeviceReset(CyFalse);
#endif
