android4.3,在imx6板子上启动了系统,通过hdmi连接显示器.但是界面一直卡在电量过低,强制关机的画面上.
请各位帮忙分析一下.
打印日志如下:
warning: `zygote' uses 32-bit capabilities (legacy support in use)
request_suspend_state: wakeup (3->0) at 20461133338 (1970-01-02 00:00:07.424861667 UTC)
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:00, irq=-1)
ADDRCONF(NETDEV_UP): eth0: link is not ready
acc_open
acc_release
ehci_fsl_bus_resume begins, Host 1
ehci_fsl_bus_resume ends, Host 1
ehci_fsl_bus_resume begins, DR
SysRq : Emergency Remount R/O
EXT4-fs (mmcblk1p5): re-mounted. Opts: (null)
EXT4-fs (mmcblk1p4): re-mounted. Opts: (null)
EXT4-fs (mmcblk1p6): re-mounted. Opts: (null)
EXT4-fs (mmcblk1p7): re-mounted. Opts: (null)
Emergency Remount complete
imx2-wdt imx2-wdt.0: Device shutdown: Expect reboot!
Disabling non-boot CPUs ...
CPU1: shutdown
CPU2: shutdown
CPU3: shutdown
Power down.
note: Thread-69[2789] exited with preempt_count 1
init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
