使用CW10.6,并安装了Freescale MQX RTOS 4.2.0,新建工程向导只用MQX-lite的,并没有MQX的。
我看到MQX_CW10_Getting_Started里面是可以新建的。如图。
并且FSL_MQX_getting_started中也提到:
The Freescale MQX RTOS setup installs the MQX RTOS "New Project Wizard" plug-in into CodeWarrior 10 installation
directory. The Project Wizard helps to select one of the supported evaluation boards, include appropriate MQX RTOS
libraries, and create initial application project. The project wizard is available in the File/New/MQX Projects menu in the
CodeWarrior 10 IDE. Follow the steps displayed by the Wizard, specify application name, and select the target evaluation
board.
但是MQX RTOS目录中并没有MQX的工程向导。所以想请教如何将MQX的安装向导添加到CW10.6中。 |
