[圈圈教你玩USB] 圈圈到底是男是女,请全圈圈回复,一直我都是蒙在鼓里
6360|20
 楼主| 比尔熊 发表于 2009-4-22 19:55 | 显示全部楼层 |阅读模式
xwj 发表于 2009-4-22 20:02 | 显示全部楼层
已经没有“全圈圈”了
因为全圈圈早就被computer扔了<br />look:<br /><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><br /><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><br /><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><br /><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><br /><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><img src="http://blog.21ic.org/uploadfile-/2007-4/426826673.gif"><br />
sz_kd 发表于 2009-4-22 20:26 | 显示全部楼层
呵呵~~~~~~~~~~~~~
computer00 发表于 2009-4-22 21:34 | 显示全部楼层
阿弥陀佛……我佛慈悲……楼主何必如此固执呢~~~
eastbest 发表于 2009-4-23 09:17 | 显示全部楼层
21ic的牛人绝大部分是男的
RT
lost1421 发表于 2009-4-23 11:11 | 显示全部楼层
如此看来
圈圈非男非女?
 楼主| 比尔熊 发表于 2009-4-26 12:25 | 显示全部楼层
圈圈咋不说清楚呢
taoest 发表于 2009-4-26 12:38 | 显示全部楼层
圈圈
两个圈圈挂胸前,你说呢。
sailen 发表于 2009-5-16 18:00 | 显示全部楼层
俺也想知道啊!
huangqi412 发表于 2009-5-18 21:00 | 显示全部楼层
晕, 你们都错了 本来他有两个圈,跟着老X练葵花包点,结果就
SHANGHUO 发表于 2009-6-29 18:36 | 显示全部楼层
从书的名字上来看,应该是公的
从书的名字上来看,应该是公的.<br />另外还有一种判别方法,那就是调用<br />computer00()函数,如果返回为真,那决对是公的,<br />如果为假,估计---函数可能有错.
eastbest 发表于 2009-7-2 09:40 | 显示全部楼层
教你一个方法
买本00的书,封面有作者真名,google一下。
auzxj 发表于 2009-7-6 11:23 | 显示全部楼层
求圈圈的性别
求延验身图片
tohope 发表于 2009-7-8 21:57 | 显示全部楼层
我晕
呵呵呵呵。
小智若愚 发表于 2009-7-11 02:28 | 显示全部楼层
圈圈桂林人士,桂林米粉长大的。
俺是柳州的,柳州的螺蛳粉味道也不错啊。
xwj 发表于 2009-7-11 04:41 | 显示全部楼层
据说.... 后来.... 圈圈...
<br /><br /><br /><br />下面...<br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br />下面...<br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br />...<br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br />别翻了,再翻下面也是没有了。<br />
wxyj2003 发表于 2009-7-14 16:19 | 显示全部楼层
圆圆
还有圆圆呢
evilive 发表于 2009-10-12 22:32 | 显示全部楼层
有圈圈的地方,就有传说。。。。
linzhiqi1 发表于 2009-11-20 18:35 | 显示全部楼层
oo大概戴眼镜吧oo像一副眼镜
linzhiqi1 发表于 2009-11-20 18:37 | 显示全部楼层
中泰康有个搞DSP的叫刘荣,oo是那个刘博士吗
