[i.MX] 【求助】内存压力测试,失败
3091|7
 楼主| 911neo 发表于 2015-11-20 19:58 | 显示全部楼层 |阅读模式
报错如下:
MX6Q opened。
HAB_TYPE:DEVELOPED
ROM_WRITE:READING HAB ack failed 0x00000000
ROM_WRITE failed,addr:0x021b0404
write dcd failed。
电压都测过。之前这个板卡也好用。
目前,内存和EMMC就没有时钟了。
 楼主| 911neo 发表于 2015-11-20 20:04 | 显示全部楼层
MFG Tools能识别到HID设备,LOG信息如下:
DLL version: 2.3.4
Wednesday, November 11, 2015 15:49:27   Start new logging
ModuleID[2] LevelID[10]: CMyExceptionHandler thread is running
ModuleID[2] LevelID[1]: new MxHidDeviceClass
ModuleID[2] LevelID[10]: Device Manager thread is running
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_15A2&PID_0054#7&32bae591&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - end
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_15A2&PID_0054#7&32bae591&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 0
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 0
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#vid_093a&pid_2510#7&12f5fc5e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 1
ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#vid_15a2&pid_0054#8&1442bd35&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
ModuleID[2] LevelID[10]: new MxHidDevice[00606F98]
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_New, devInstPathToFind: USB\VID_15A2&PID_0054\7&32BAE591&0&3, _deviceInstanceID: USB\VID_15A2&PID_0054\7&32BAE591&0&3
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_New, Find the device, Port: 3
ModuleID[2] LevelID[10]: DeviceClass::AddUsbDevice() successful USB#VID_15A2&PID_0054#7&32BAE591&0&3#{A5DCBF10-6530-11D2-901F-00C04FB951ED} add to current list, retrycount: 0
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0054, Hub:4-Port:3
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Arrive
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceArriveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device arrive1
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 0
ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is C:\Users\Ryan\Desktop\mfgtool\Profiles\Linux\OS Firmware\firmware_private\u-boot\u-boot_imx6q_sspis5100_hw110_otg.imx
ModuleID[2] LevelID[1]: MxHidDevice::Read() Error reading from device 0x48f.
ModuleID[2] LevelID[1]: Failed to read HAB type from ROM!!!
ModuleID[2] LevelID[1]: Failed to initialize memory!
ModuleID[2] LevelID[1]: PortMgrDlg(0)--MxHidDevice--Command Boot excute failed
ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
舒斯特尔 发表于 2015-11-20 20:46 | 显示全部楼层
好高级啊,没有用过,帮顶了
侣行天下 发表于 2015-11-21 17:46 | 显示全部楼层
麻烦问下楼主问题解决了吗,我也在找答案
mini1986 发表于 2015-11-24 21:14 | 显示全部楼层
之前能用,现在不能用了?某个地方短路了?......
 楼主| 911neo 发表于 2015-11-27 10:28 | 显示全部楼层
之前也怀疑过,都检查了,但是没发现。
今天芯片重新吹了一下。还是没有改善。
 楼主| 911neo 发表于 2016-1-28 08:53 | 显示全部楼层
吹了三遍,终于识别了。压力测试能过去了。
不过,LVDS输出异常,程序说IPU有损坏。
换了芯片,又不认了。又吹了2遍。终于正常了。
mini1986 发表于 2016-2-1 14:45 | 显示全部楼层
焊接就得多花点钱,找个焊接质量可靠的,不然整死搞开发的......
