[其它应用] 中断问题
845|15
 楼主| zhuhuis 发表于 2015-11-21 17:11 | 显示全部楼层 |阅读模式
IRQ        EQU    01H
TM0        EQU    02H
TM1        EQU    03H
TL0        EQU    04H
TH0        EQU    05H
PROGRAMME:
           ORG    0000H
           JMP RESET
           RTNI
         JMP TIMER0_INT              ;T1 INT THEN GO TO T1_INT
         RTNI
           RTNI
RESET:
      NOP
      NOP
      NOP
      NOP
      NOP
      NOP
      NOP
      NOP
      NOP
      NOP
CLEARRAM:                      ;CLEAR RAM 020H-3AFH,
      LDI    DPH        ,07H
      LDI    DPM        ,02H
     LDI    DPL        ,0FH
     LDI    WDT        ,1100B         ;CLR  WDT     WDT=64ms
?CLinx:
     LDI    INX        ,00H
     CALL   DataPointDec
     LDA    DPH        ,BANK0
     OR     DPM        ,BANK0
     BNZ    ?CLinx
     LDI    PAOUT        ,1111B         ;set PA output
      LDI    PORTA        ,1111B
    LDI    PFOUT        ,1111B         ;set PF output
      LDI    PORTF        ,1111B
    LDI    TMP01        ,1111B
      STA    PIOUT        ,BANK7         ;set PI output
      LDI    TMP01        ,1111B
      STA    PORTI        ,BANK7
      LDI    TM1           ,1111B
      LDI    TM0          ,0111B          ;T1RM=1111B--; 1/1       ;T1RM=1110B--;1/2 ;CLOCK/4
      LDI    TL0          ,06H            ;T1RL=06H
    LDI    TH0          ,00H            ;T1RH=00H----; /250      ;T1RH=08H----;/125
      LDI    IRQ          ,0000B
      LDI    IE           ,1000B          ; T1 INTERRUPT ENABLE
      LDI    PA_BUF       ,0FH
      LDI    PF_BUF       ,0FH
      LDI    PI_BUF       ,0FH
;                  main  programme
MAIN:
      JMP    TIME_CLOCK
RE_TIME_CLOCK:
JMP     KEY_SCAN
RE_KEY_SCAN:
      JMP   KEY_PROCESS
RE_KEY_PROCESS:
     JMP    DISPLAY
RE_LED_DISP:
      NOP
      NOP
      NOP
      NOP
      JMP    MAIN
;数据指针减一子程序
DataPointDec:
     SBIM    DPL        ,01H
      EOR     DPL        ,BANK0
      SBCM    DPM        ,BANK0
      EOR     DPM        ,BANK0
      SBCM    DPH        ,BANK0
     RTNI
;timer0中断服务子程序
;=================================================TIMER0_INT:
      STA    ACC_BUF      ,BANK0  ;备份ACC的值
      LDI    IRQ  ,00H         ;清TIMER0中断请求标志
COUNT_1MS:
      ADIM   CT0_1MS      ,01H
      SBI    CT0_1MS      ,04H
      BNZ    COUNT_5MS
      LDI    CT0_1MS       ,00H
      ORIM   TIME_FLAG    ,0001B         ;设置“1ms到”标志
COUNT_5MS:
    ADIM   CT0_5MS      ,01H         ;5ms计数
    LDI    TMP_T0       ,00H
      ADCM   CT1_5MS      ,BANK0         ;5ms计数
      SBI    CT0_5MS      ,04H
      BNZ    TIMER1_INT_END
      SBI    CT1_5MS      ,01H
      BNZ    TIMER1_INT_END
      ORIM   TIME_FLAG    ,0010B         ;设置“5ms到”标志
      ORIM   CLOCK_FLAG   ,0001B         ;设置时钟计时的5ms标志位
    LDI    CT0_5MS      ,00H         ;重置5ms计数器
      LDI    CT1_5MS      ,00H         ;重置5ms计数器
      ADIM   CT0_200MS    ,01H
      LDI    TMP_T0       ,00H
      ADCM   CT1_200MS    ,BANK0
      SBI    CT0_200MS    ,08H
      BNZ    TIMER1_INT_END
      SBI    CT1_200MS    ,02H
      BNZ    TIMER1_INT_END
      ORIM   TIME_FLAG    ,0100B         ;设置“0.2s到”标志
    LDI    CT0_200MS    ,00H         ;重置0.2S计数器
      LDI    CT1_200MS    ,00H         ;重置0.2S计数器
TIMER1_INT_END:
      LDI    IE           ,1000B          ;打开timer0中断
      LDA    ACC_BUF      ,BANK0         ;返回ACC的值
      RTNI
进不了了
宋倩2010 发表于 2015-11-21 17:11 | 显示全部楼层
这样打开的不是TIMER0中断,是最高位的中断,即入口地址的RTNI.
那我该怎么办呢?
chenho 发表于 2015-11-21 17:11 | 显示全部楼层
打开TIMER0中断啊
gongche 发表于 2015-11-21 17:11 | 显示全部楼层
改为  LDI   IE,0100B    就行了
 楼主| zhuhuis 发表于 2015-11-21 17:12 | 显示全部楼层
那我要time1和time0同时打开 IE应该怎么设置?
chenho 发表于 2015-11-21 17:12 | 显示全部楼层
改为  LDI   IE,1100B    ;这样才是打开TIMER1,TIMER0中断.
IE  的第二位是time1的控制位
我用的是69p55的单片机,它定义IE为第一位是time0第二位是time1第三位是time2
huwr 发表于 2015-11-21 17:12 | 显示全部楼层
就是要打开哪个中断就把IE的相应位置成1即可.
huanghuac 发表于 2015-11-21 17:13 | 显示全部楼层
huanghuac 发表于 2015-11-21 17:14 | 显示全部楼层
IE寄存器的bit3是定时器0允许标志,bit2是定时器1允许标志,bit1是定时器2的允许标志,bit0是端口中断,AD中断,按键中断允许标志。
happy_10 发表于 2015-11-21 17:14 | 显示全部楼层
楼上说得对,如果要开启定时器0中断,只要将IE设置为1000b就可以了。
wenfen 发表于 2015-11-21 17:14 | 显示全部楼层
高手呀,用汇编
又是粘代码的
眼晕
huwr 发表于 2015-11-21 17:15 | 显示全部楼层
这该有多熟练才能看得出来呢
 楼主| zhuhuis 发表于 2015-11-21 17:15 | 显示全部楼层
懂了,多谢
