[STM8] STM32输出PWM波 遇到一些问题
1458|4
 楼主| Anthonybrave 发表于 2015-11-25 14:45 | 显示全部楼层 |阅读模式
用Tim3输出PWM波。 使用PA6、PA7、PB0、PB1。能够发出占空比不同的方波。
代码如下:
void TIM3_PWM_Init(void)
        GPIO_InitTypeDef         GPIO_InitStructure;
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef        TIM_OCInitStructure;
//        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3|RCC_APB2Periph_GPIOA, ENABLE); //使能TIM3时钟,GPIOA时钟
        RCC_APB1PeriphClockCmd (RCC_APB1Periph_TIM3,ENABLE);
        RCC_APB2PeriphClockCmd (RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB,ENABLE);
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
  /*GPIOB Configuration: TIM3 channel 3 and 4 as alternate function push-pull */
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_1;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* Time base configuration */
    TIM_TimeBaseStructure.TIM_Period = 999;
    TIM_TimeBaseStructure.TIM_Prescaler = 0;
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 750;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_Pulse = 500;
  TIM_OC2Init(TIM3, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel3 */
  TIM_OCInitStructure.TIM_Pulse = 250;
  TIM_OC3Init(TIM3, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel4 */
  TIM_OCInitStructure.TIM_Pulse = 100;
  TIM_OC4Init(TIM3, &TIM_OCInitStructure);
  TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM3, ENABLE);
  /* TIM3 enable counter */
  TIM_Cmd(TIM3, ENABLE);
问题如下:(已解决)   另外有个问题请大神看下三楼
1、使用其他IO口,比如PA4、PA5或者PB6、PB7,在IO口处检测不到方波.
2、使用其他定时器,比如Tim2,就检测不到方波。
 楼主| Anthonybrave 发表于 2015-11-25 15:17 | 显示全部楼层
还有就是  波形中好像总夹杂着其他的小脉冲还是杂波 ?
请大神赐教
 楼主| Anthonybrave 发表于 2015-11-25 15:31 | 显示全部楼层
每个定时器确实只和某些IO口对应。。详情可以看下STM32参考手册中的第八章第三节。。复用功能I/O
继续请教为什么波形中夹杂着其他波?
 楼主| Anthonybrave 发表于 2015-11-25 16:08 | 显示全部楼层
知道了
探头没插好
结了
mmuuss586 发表于 2015-11-25 17:56 | 显示全部楼层
有杂波和程序没啥关系的
