[STM32F0] stm32f0的I2C读写24c02,读取对应地址数据缺失空白的?
2570|2
 楼主| 亦已即 发表于 2015-11-26 10:25 | 显示全部楼层 |阅读模式
程序用的书上的程序,板子是stm32f030c8板子。数据读取是空白的。不知道是那边出错了。
void I2C_Conf()
    //I2C所使用I/O的配置
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_Level_3;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
    //GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    //I/O口映射到I2C2外设
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_1);
    //I/O口映射到I2C2外设
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_1);
    //I2C的初始化
    I2C_InitTypeDef I2C_InitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2,ENABLE);
    I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
    I2C_InitStructure.I2C_AnalogFilter = I2C_AnalogFilter_Enable;
    I2C_InitStructure.I2C_DigitalFilter = 0x00;
    I2C_InitStructure.I2C_OwnAddress1 = 0x00;
    I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
    I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
    I2C_InitStructure.I2C_Timing = 0x00210507;
    //使能I2C
    I2C_Cmd(I2C2, ENABLE);
    I2C_Init(I2C2, &I2C_InitStructure);
//函数名   :  viod I2C_Write(uchar data, uchar WriteAddr)
//功能描述 :  I2C的指定位置写入数据
//输入    :   MemoryAddress:要写入数据的地址;DeviceAddress:物理地址;Data:需要写入的数据
//输出    :   无
//返回    :   无
void I2C2_Write(uint8_t DeviceAddress, uint8_t MemoryAddress, uint8_t Data)
    while(I2C_GetFlagStatus(I2C2,I2C_FLAG_BUSY));
    I2C_TransferHandling(I2C2,DeviceAddress,1,I2C_Reload_Mode,I2C_Generate_Start_Write);   // I2C_SoftEnd_Mode
    while(I2C_GetFlagStatus(I2C2,I2C_ISR_TXIS) == RESET);
    I2C_SendData(I2C2,MemoryAddress);
    while(I2C_GetFlagStatus(I2C2,I2C_ISR_TCR) == RESET);
    I2C_TransferHandling(I2C2,DeviceAddress,1,I2C_AutoEnd_Mode,I2C_No_StartStop);   // I2C_Generate_Start_Write
    I2C_SendData(I2C2, Data);
    while(I2C_GetFlagStatus(I2C2,I2C_ISR_STOPF) == RESET);
    for(uint32_t i=0;i<20000;i++);
    I2C_ClearFlag(I2C2, I2C_ICR_STOPCF);
//函数名   :  unsigned char I2C2_Read(uchar ReadAddr)
//功能描述 :  读指定位置的数据;
//输入    :   DeviceAddress:物理地址; MemoryAddress:读取数据的地址;
//输出    :   无
//返回    :   读取的数据
uint8_t I2C2_Read(uint8_t DeviceAddress, uint8_t MemoryAddress)
    uint8_t Data;
    I2C_TransferHandling(I2C2,DeviceAddress,1,I2C_SoftEnd_Mode,I2C_Generate_Start_Write);   // I2C_SoftEnd_Mode
    while(I2C_GetFlagStatus(I2C2,I2C_ISR_TC) == RESET);
    I2C_TransferHandling(I2C2,DeviceAddress,1,I2C_AutoEnd_Mode,I2C_Generate_Start_Read);   // I2C_Generate_Start_read
    while(I2C_GetFlagStatus(I2C2,I2C_ISR_RXNE) == RESET);
    Data = I2C_ReceiveData(I2C2);
    return Data;
 楼主| 亦已即 发表于 2015-11-26 10:28 | 显示全部楼层
在线等。。。
失去的不再 发表于 2015-11-30 09:19 | 显示全部楼层
各位大神帮忙看看吧,不知道拿错了。。
