[i.MX] DDR调校出错imx6dl
1788|3
 楼主| shengzhaodong 发表于 2015-11-27 19:59 | 显示全部楼层 |阅读模式
今天配置DDR,两个板子都不行,提示如下:
Would you like to run the write leveling calibration? (y/n)
  Please enter the MR1 value on the initilization script
  This will be re-programmed into MR1 after write leveling calibration
  Enter as a 4-digit HEX value, example 0004, then hit enter
0004 You have entered: 0x0004
Start write leveling calibration
Write leveling calibration completed
MMDC_MPWLDECTRL0 ch0 after write level cal: 0x001F001F
MMDC_MPWLDECTRL1 ch0 after write level cal: 0x001F001F
MMDC_MPWLDECTRL0 ch1 after write level cal: 0x001F001F
MMDC_MPWLDECTRL1 ch1 after write level cal: 0x001F001F
Would you like to run the DQS gating, read/write delay calibration? (y/n)
Starting DQS gating calibration...
. . . . . . . . . . . . . . ERROR FOUND, we can't get suitable value !!!!
dram test fails for all values.
The DDR stress test can run with an incrementing frequency or at a static freq
To run at a static freq, simply set the start freq and end freq to the same valu
e
Would you like to run the DDR Stress Test (y/n)?
求回复。。。
mini1986 发表于 2015-12-1 10:07 | 显示全部楼层
调过ddr,现在能用,但是还没有好好压力测试过......期待楼主搞定后分享经验......
 楼主| shengzhaodong 发表于 2016-2-24 17:09 | 显示全部楼层
调过ddr,现在能用,但是还没有好好压力测试过......期待楼主搞定后分享经验...... ...
哎。。。我这里没用到lvds,所以没引出lvds的供电,谁知道ddr的供电是与lvds共享的。。。引出供电就好了
qq729101414 发表于 2016-7-14 15:49 | 显示全部楼层
哎。。。我这里没用到lvds,所以没引出lvds的供电,谁知道ddr的供电是与lvds共享的。。。引出供电就好了 ...
IMX6SXHDG 里面的checkList 电源部分有说明这个的。。。
