[STM32F1] STM32 USB HUB 求助
3121|7
 楼主| louisignal 发表于 2015-12-2 16:42 | 显示全部楼层 |阅读模式
最近的项目中需要使用STM32F105通过USB HUB连接多个USB Key。
HUB芯片选用台湾汤铭科技的FE2.1
STM32F105已经成功枚举了HUB芯片,设置了地址、读出了设备描述字、配置描述字、接口描述字、端点描述字。
枚举过程如下:
case ENUM_IDLE:                                 // 初始化,读端点0的MPS
case ENUM_GET_FULL_DEV_DESC:      // 读完整的设备描述字
case ENUM_SET_ADDR:                        // 设置地址
case ENUM_GET_CFG_DESC:                //  读配置描述字前8字节
case ENUM_GET_FULL_CFG_DESC:       //  读全部配置描述字
case ENUM_GET_MFC_STRING_DESC:  //  读字符串
case ENUM_GET_SERIALNUM_STRING_DESC:    //   读字符串
case ENUM_SET_CONFIGURATION:       //  设置HUB配置------卡住
case ENUM_GET_HUB_DESC:                 //  读HUB描述字------卡住
case ENUM_DEV_CONFIGURED:             //  枚举结束
USB2.0标准上说HUB需要使用USB 标准配置命令Set Configuration配置以后才能正常工作,我配置如下:
       phost->Control.setup.b.bmRequestType = 0;
       phost->Control.setup.b.bRequest = USB_REQ_SET_CONFIGURATION;
       phost->Control.setup.b.wValue.w = 1;
       phost->Control.setup.b.wIndex.w = 0;
       phost->Control.setup.b.wLength.w = 0;
HUB芯片给我的回复是STALL,意思是不支持此项配置!同样是USB 标准命令,为什么Set Address就可以,Set Configuration不可以。
我又试着读取HUB描述字,结果回来都是0!
FE2.1搞死我算了,枚举就卡在倒数第2、3项设置HUB配置、读HUB描述字。
插上USB KEY以后,读HUB的变化字,也是都是0,根本检测不出端口插上的USB设备。
 楼主| louisignal 发表于 2015-12-2 21:15 | 显示全部楼层
自问自答吧:问题解决了
在USB2.0协议文档中,关于Set Address和Set configuration是这么说的:
关于地址设置:设为0,则设备处于Default state;设成非0地址,则设备处于Address state
>>Default state: If the address specified is non-zero, then the device shall enter the Address state;
otherwise, the device remains in the Default state (this is not an error condition).
>>Address state: If the address specified is zero, then the device shall enter the Default state;
otherwise, the device remains in the Address state but uses the newly-specified
address.
>>Configured state: Device behavior when this request is received while the device is in the Configured
state is not specified.
关于Set Configuration:对处于Default state下的设备Set Configuration是错误的。
>>Default state: Device behavior when this request is received while the device is in the Default state
is not specified.
>>Address state: If the specified configuration value is zero, then the device remains in the Address
state. If the specified configuration value matches the configuration value from a
configuration descriptor, then that configuration is selected and the device enters the
Configured state. Otherwise, the device responds with a Request Error.
>>Configured state: If the specified configuration value is zero, then the device enters the Address state.
configuration descriptor, then that configuration is selected and the device remains in
the Configured state. Otherwise, the device responds with a Request Error.
SO,只要设置一个非0的地址就什么都好了!
 楼主| louisignal 发表于 2015-12-2 21:17 | 显示全部楼层
大家速速回复,我要结贴撒分了!
香水城 发表于 2015-12-3 12:06 | 显示全部楼层
自己找到问题所在更能学到东西!
加油!
小小强112 发表于 2016-5-4 17:40 | 显示全部楼层
楼主我也正用唐铭的FE2.1S  能把你代码参考一下吗
vakite 发表于 2017-5-2 17:55 | 显示全部楼层
请问楼主hub枚举完了如何读设备的描述符
yqdz2005 发表于 2017-5-2 18:10 | 显示全部楼层
有需要用到ST MCU的,都可以加我聊下,我们专注这块10多年了,常备现货!或许能帮到你降低成本!   270129716
18784506782 发表于 2022-1-28 17:19 | 显示全部楼层
楼主,新年好,想问下 我现在HUb枚举成功了,插上设备都能识别是哪个口 但是不知道怎么去枚举HUB上的设备,你能给点提示吗
