- void Sleep()
- RCC_DeInit(); // RCC 时钟系统重启
- /* Flash 0 wait state */
- FLASH_SetLatency(FLASH_Latency_0);
- /* Disable Prefetch Buffer */
- FLASH_PrefetchBufferCmd(DISABLE);
- /* Disable 64-bit access */
- FLASH_ReadAccess64Cmd(DISABLE);
- /* Enable the PWR APB1 Clock */
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
- /* Select the Voltage Range 2 (1.5V) */
- PWR_VoltageScalingConfig(PWR_VoltageScaling_Range2);
- /* Wait Until the Voltage Regulator is ready */
- while(PWR_GetFlagStatus(PWR_FLAG_VOS) != RESET)
- /* HCLK = SYSCLK/2 = ~32KHz */
- RCC_HCLKConfig(RCC_SYSCLK_Div2);
- /* PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);
- /* PCLK1 = HCLK */
- RCC_PCLK1Config(RCC_HCLK_Div1);
- /* Set MSI clock range to 65.536KHz */
- RCC_MSIRangeConfig(RCC_MSIRange_0);
- /* Select MSI as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_MSI);
- /* Wait till PLL is used as system clock source */
- while (RCC_GetSYSCLKSource() != 0x00)
- /* Enable The ultra Low Power Mode */
- PWR_UltraLowPowerCmd(ENABLE);
- /* Enable the power down mode during Sleep mode */
- FLASH_SLEEPPowerDownCmd(ENABLE);
- /* Request to enter SLEEP mode with regulator in low power mode */
- PWR_EnterSleepMode(PWR_Regulator_LowPower, PWR_SLEEPEntry_WFI);
- main(){
- if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_7)==0){
- if(flagSLEEP == false){
- Sleep();
- flagSLEEP = true;
- else{
- if(t == true){
- GPIO_SetBits(GPIOB,GPIO_Pin_5);
- t = false;
- else{
- GPIO_ResetBits(GPIOB,GPIO_Pin_5);
- t = true;
其中函数Sleep是从STM32L1的例程中拿来的
在Datasheet中可以看到,Sleep模式下,CPU是关闭的,但感觉程序还可以运行,我按按钮PC7时,为什么IO还是可以翻转的?
