电子类术语1
1764|0
 楼主| itxss 发表于 2009-7-22 10:29 | 显示全部楼层 |阅读模式
ead-out,单独读出
absolute resolution,绝对分辨率
absolute salinity,绝对盐度
absolute stability,绝对稳定性
absolute stability of a linear system,线性系统的绝对稳定性
absolute static pressure of the fluid,流体绝对静压
absolute temperature scale,绝对温标
absorbance,吸光度
absorbed current image,吸收电流象
absorptance,吸收比
absorptiometer,吸收光度计
absorption cell,吸收池
absorption coefficient,吸收系数
absorption correction,吸收修正
absorption edges,吸收边
absorption factor,吸收系数
absorption hygrometer,吸收温度表
absorption spectrum,吸收光谱
absorption X-ray spectrometry,吸收X射线谱法
absorptivity,吸收率
absorptivity of an absorbing,吸引材料的吸收率
abstract system,抽象系统
abundance sensityivity,丰度灵敏度
AC-ACLVDT displacement transducer,交流差动变压器式位移传感器
accelerated test,加速试验
accelerationg voltage,加速电压
acceleration,加速度
acceleration error coefficient,加速度误差系数
acceleration of gravity,重力加速度
acceleration simulator,加速度仿真器
acceleration transducer[sensor],加速度传感器
accelerometer,加速度计
acceptance of the mass filter,滤质器的接收容限
acceptance test,验[交]收检验
access,存取 access time,存取时间
accessibility,可及性
accessories of testing machine,试验机附件
accessory(for a measuring instrument),(测量仪表的)附件
accessory hardware,附属硬件
accessory of limited interchangeability,有限互换附件
accumulated error,积累误差
accumulated time difference,累积时差
