出现了下面的错误
672|6
zhanghqi|  楼主 | 2015-12-15 21:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
se, ce, AN, AC, TI
最近在写ILI9325的驱动程序,单片机是MSP430F149,程序是从51单片机上拿过来改的,51单片机上可以正常工作,但是用IAR编译的时候,却出现了下面的错误:
Building configuration: 彩屏驱动 - Debug
Updating build tree...
ILI9325.c
main.c
Linking
Error[e16]: Segment DATA16_I (size: 0xe04 align: 0x1) is too long for segment definition. At least 0x604 more bytes needed. The problem occurred while
processing the segment placement command "-Z(DATA)DATA16_I,DATA16_Z,DATA16_N,DATA16_HEAP+_DATA16_HEAP_SIZE=0200-09FF", where
at the moment of placement the available memory ranges were "CODE:200-9ff"
   Reserved ranges relevant to this placement:
   200-9ff              DATA16_I
Error while running Linker
Total number of errors: 1
Total number of warnings: 0
shimx| | 2015-12-15 21:49 | 只看该作者
没见过这样的错误啊
jiaxw| | 2015-12-15 21:49 | 只看该作者
路过帮顶一下
liliang9554| | 2015-12-15 21:49 | 只看该作者
RAM不够用了
果然。。。。
zhanghqi|  楼主 | 2015-12-15 21:50 | 只看该作者
4楼真乃神人,一语道破天机啊,多谢了,结贴啦
jiajs| | 2015-12-15 21:50 | 只看该作者
改一下堆栈的大小看看?
