debug时出现错误
431|3
wyjie|  楼主 | 2015-12-15 21:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
BUG, TE, se, TI, ST
前几天我在调试EKK-8962时,IDE为CCS4.2.4,在debug时出现如下的错误:
CORTEX_M3_0: Error connecting to the target: The target board you are attempting to connect to does not appear to be a Stellaris IDK and is not supported with this license. This license may only be used with the development board that is included with Stellaris IDKs bundled with Code Composer Studio.
baimiaocun2015| | 2015-12-15 22:25 | 只看该作者
没看懂是啥问题的,,求解。。
dirtwillfly| | 2015-12-16 08:28 | 只看该作者
license不支持你的板子
tongbu2015| | 2015-12-16 13:19 | 只看该作者
这个问题的不好找的。
