[技术求助] STM32F103的pwm输出
876|2
 楼主| 371311039 发表于 2015-12-16 20:13 | 显示全部楼层 |阅读模式
刚学stm32f103的板子,就是按照原子的程序改了个IO口,但是好像PA7的没有PWM输出,我也是用TIM3_CH2来控制PA7的灯,毫无反应,灯都不亮,求大神指教void TIM3_Int_Init(u16 arr,u16 psc)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
        TIM_TimeBaseStructure.TIM_Period = arr;
        TIM_TimeBaseStructure.TIM_Prescaler =psc;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
        TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE );
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        TIM_Cmd(TIM3, ENABLE);
}void TIM3_IRQHandler(void)   //TIM3ÖжÏ
        if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
                TIM_ClearITPendingBit(TIM3, TIM_IT_Update  );
void TIM3_PWM_Init(u16 arr,u16 psc)
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
        //ÉèÖøÃÒý½ÅΪ¸´ÓÃÊä³ö¹¦ÄÜ,Êä³öTIM3 CH2µÄPWMÂö³å²¨ÐÎ GPIOB.5
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure)
   //³õʼ»¯TIM3
        //³õʼ»¯TIM3 Channel2 PWMģʽ
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
        TIM_OC2Init(TIM3, &TIM_OCInitStructure);
        TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
主程序是这样的
int main(void)
        u16 led0pwmval=0;
        u8 dir=1;
        delay_init();
  JTAG_Set(JTAG_SWD_DISABLE); //¹Ø±ÕJTAG); //¹Ø±ÕJTAG
        NVIC_Configuration();
        uart_init(9600);
        LED_Init();
        TIM3_PWM_Init(899,0);
  while(1)
   delay_ms(10);
         if(dir)
    led0pwmval++;
         else
         {led0pwmval--;
         if(led0pwmval>300) dir=0;
         if(led0pwmval==0) dir=1;
         TIM_SetCompare2(TIM3,led0pwmval);
才学stm32,求帮忙,弄了好两天了,非常感谢
airwill 发表于 2015-12-16 21:43 | 显示全部楼层
初始化代码没有发现问题, 只是在 main() 里没有找到哪里调用了 TIM3_Int_Init() ?
xyz549040622 发表于 2015-12-17 08:50 | 显示全部楼层
徐工看的很仔细,补充下,主函数中调用的是TIM3_PWM_Init(899,0);而实际写的函数是TIM3_Int_Init,估计是字母不小心打错了。还有,用了中断,主循环中加10ms的延时,什么意思
