[i.MX] 编译错误
801|2
 楼主| 乐勉力123 发表于 2015-12-17 08:26 | 显示全部楼层 |阅读模式
checking for glib-genmarshal... no
configure: error: Could not find a glib-genmarshal in your PATH
error: Bad exit status from /home/yuli/Desktop/I.MX6/L3.0.35_4.1.0_130816_source/source/ltib/tmp/rpm-tmp.407 (%build)
RPM build errors:
Build time for glib2: 63 seconds
Failed building glib2
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Wed Dec 16 16:10:14 2015
Ended:   Wed Dec 16 16:11:28 2015
Elapsed: 74 seconds
These packages failed to build:
glib2
Build Failed
Exiting on error or interrupt
这是什么原因?
mini1986 发表于 2015-12-24 15:34 | 显示全部楼层
你是不是没好好看文档啊......把那些必要的软件包装上,就不会出现这些问题了......
kris_fei 发表于 2015-12-24 16:33 | 显示全部楼层
安装了吗?
