KEIL 编译优化问题?
2271|0
 楼主| wsl_5631 发表于 2009-8-3 19:36 | 显示全部楼层 |阅读模式
重新整理一下发帖
下面的程序 会执行到while(1);请高手指点
#include"STC89C58RD+.H"
#include<stdlib.h>
#include<intrins.h>
#define        uchar            unsigned char
#define        ulint            unsigned long int
#pragma ot(9,speed)                //9级优化
#define        BUZZER            P1_0
#define        WORK        0
#define        SET            1
#define        IDLE        2
idata    ulint      data_var;
idata    ulint      idata_var;
xdata    ulint      xdata_var;
data    uchar      status;
void    key_process(uchar key);
void    delay5us();
void    delay5ms();
void    main()
        while(1)
             status = WORK;
            key_process(1);
    switch(status)
        case WORK:
            switch(key)
                case 1:
                    data_var = 0;
                    delay5us();
                    BUZZER = 1;
                    delay5ms();
                    BUZZER = 0;
                    status = IDLE;
                    break;
                case 2:
                    _nop_();
                    _nop_();
                    _nop_();
                    _nop_();
                    _nop_();
                    while(1);
                    break;
                default:
                    break;
            break;
        case SET:
            switch(key)
                case 1:
                    xdata_var = 0;
                    delay5us();
                    BUZZER = 1;
                    delay5ms();
                    BUZZER = 0;
                    status = IDLE;;
                    break;
                case 2:
                    idata_var = 0x897890;
                    delay5us();
                    BUZZER = 0;
                    delay5ms();
                    BUZZER = 1;
                    status = IDLE;
                    break;
                default:
                    break;
            break;
        case IDLE:
            break;
        default:
            break;
void    delay5us()
    uchar i;
    for(i=0;i<5;i++);
void    delay5ms()
    uchar i;
    for(i=0;i<50;i++)delay5us();
