PIC16F1937 RA7配置成IO问题请教
1531|1
 楼主| keykay 发表于 2015-12-27 14:34 | 显示全部楼层 |阅读模式
哪位老师帮忙看下 配置完以后  RA7还是不能当IO使用 驱动不了
// CONFIG1
#pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = ON       // Power-up Timer Enable (PWRT enabled)
#pragma config MCLRE = ON       // MCLR Pin Function Select (MCLR/VPP pin function is MCLR)
#pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config CPD = OFF        // Data Memory Code Protection (Data memory code protection is disabled)
#pragma config BOREN = ON       // Brown-out Reset Enable (Brown-out Reset enabled)
#pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = OFF       // Internal/External Switchover (Internal/External Switchover mode is disabled)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (000h to 1FFFh write protected, no addresses may be modified by EECON control)
#pragma config VCAPEN = OFF     // Voltage Regulator Capacitor Enable (All VCAP pin functionality is disabled)
#pragma config PLLEN = ON      // PLL Enable (4x PLL enabled)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will not cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), high trip point selected.)
#pragma config LVP = ON         // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)gramming)
    OSCCONbits.IRCF = 0b1110;
    OSCCONbits.SPLLEN = 0b1;
    OSCCONbits.SCS = 0b00;
    LATA = 0;
    LATB = 0;
    LATC = 0;
    LATD = 0;
    LATE = 0;
    /* APFCON Initial */
    APFCON = 0;
    OPTION_REG = 0;
    /* GPIOA */
    TRISAbits.TRISA0 = 0;
    TRISAbits.TRISA1 = 1;
    TRISAbits.TRISA2 = 1;
    TRISAbits.TRISA3 = 1;
    TRISAbits.TRISA4 = 0;
    TRISAbits.TRISA5 = 1;
    TRISAbits.TRISA6 = 0;
    TRISAbits.TRISA7 = 0;
    ANSELAbits.ANSA0 = 0;
    ANSELAbits.ANSA1 = 1;
    ANSELAbits.ANSA2 = 1;
    ANSELAbits.ANSA3 = 1;
    ANSELAbits.ANSA4 = 0;
    ANSELAbits.ANSA5 = 0;
 楼主| keykay 发表于 2015-12-27 15:27 | 显示全部楼层
问题已解决 配置没有问题
