[PIC®/AVR®/dsPIC®产品] dsPIC33EP64MC502 PWM无输出
1636|0
 楼主| anstxfw 发表于 2015-12-29 11:38 | 显示全部楼层 |阅读模式
void PWM_Init(void)
    PTCONbits.PTEN=0;
    PTCONbits.PTSIDL=0;
    PTCONbits.SESTAT=0;
    PTCONbits.SEIEN=0;
    PTCONbits.EIPU=0;
    PTCONbits.SYNCPOL=0;
    PTCONbits.SYNCOEN=0;
    PTCONbits.SYNCEN=0;
    PTCONbits.SYNCSRC=1;
    PTCONbits.SEVTPS=0;
    /* 1:1 Prescaler */
    PTCON2bits.PCLKDIV=0;     //120M
    /* PTPER provides the PWM time period value */
    PWMCON1bits.ITB=0;
    PWMCON1bits.MDCS=0;     //set PDCX as pwm duty
    PWMCON1bits.DTC=2;      //disable Dead Zone
    PWMCON1bits.CAM=0;      //Edge-Aligned mode
    IOCON1bits.PENH=1;      //PWM LOCK DISENABLE
    IOCON1bits.PENL=1;      //
    IOCON1bits.SWAP=0;
    /* Set PWM Period on Primary Time Base */
    PTPER = 6000;               //20khz     120M/20K=6000
    /* Set Phase Shift */
    PHASE1 = 0;
    /* Set Duty Cycles */
    PDC1 = 3000;                 //120M/20K*DUTY=6000*(0~1);
    ANSELB = 0;
    TRISBbits.TRISB14 = 0;
    TRISBbits.TRISB15 = 0;                      //PWMH PWML as output
    /* Enable PWM Module */
    PTCONbits.PTEN=1;
用示波器测量PWM1H与PWM1L均无波形。请帮忙看下,不胜感激!
