[ZLG-MCU] 求助:DP—51PROC单片机综合仿真试验仪的一个细致问题
1866|1
 楼主| lieagle 发表于 2007-10-18 22:52 | 显示全部楼层 |阅读模式
<br />各位先辈看看这是怎么回事儿。。。<br />在编辑程序时出现:<br />Build&nbsp;target&nbsp;'Target&nbsp;1'<br /><br />linking...<br /><br />BL51&nbsp;BANKED&nbsp;LINKER/LOCATER&nbsp;V5.01&nbsp;-&nbsp;SN:&nbsp;Eval&nbsp;Version<br /><br />COPYRIGHT&nbsp;KEIL&nbsp;ELEKTRONIK&nbsp;GmbH&nbsp;1987&nbsp;-&nbsp;2002<br /><br />&quot;shishi.obj&quot;,<br /><br />&quot;.\startup.obj&quot;&nbsp;<br /><br />TO&nbsp;&quot;shishi&quot;&nbsp;<br /><br />CODE(&nbsp;0X8000-0XBFFF&nbsp;)<br /><br />XDATA(&nbsp;0XC000-0XFFFF&nbsp;)<br /><br />***&nbsp;FATAL&nbsp;ERROR&nbsp;L210:&nbsp;I/O&nbsp;ERROR&nbsp;ON&nbsp;INPUT&nbsp;FILE:<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;EXCEPTION&nbsp;0021H:&nbsp;PATH&nbsp;OR&nbsp;FILE&nbsp;NOT&nbsp;FOUND<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;FILE:&nbsp;C:\KEIL\C51\LIB\C51FPS.LIB<br /><br />Target&nbsp;not&nbsp;created<br /><br /><br />这是怎么回事儿啊???<br />拜托拜托~~~~<br />
 楼主| lieagle 发表于 2007-10-19 09:04 | 显示全部楼层
帮帮忙啊
知道的帮忙看看是怎么回事儿啊
