ADSL Tester - xDSL Tester
1802|0
 楼主| gaotek 发表于 2008-8-11 10:32 | 显示全部楼层 |阅读模式
ADSL&nbsp;Tester&nbsp;-&nbsp;GAO330&nbsp;xDSL&nbsp;Tester&nbsp;-&nbsp;Description<br />GAO330&nbsp;is&nbsp;designed&nbsp;for&nbsp;present&nbsp;all&nbsp;kinds&nbsp;of&nbsp;xDSL&nbsp;line&nbsp;including&nbsp;ADSL,&nbsp;ADSL2,&nbsp;ADSL2+,&nbsp;READSL.&nbsp;It&nbsp;not&nbsp;only&nbsp;can&nbsp;test&nbsp;xDSL&nbsp;physical&nbsp;layer&nbsp;parameter&nbsp;and&nbsp;also&nbsp;can&nbsp;help&nbsp;you&nbsp;to&nbsp;confirm&nbsp;whether&nbsp;your&nbsp;line&nbsp;is&nbsp;proper&nbsp;to&nbsp;provide&nbsp;xDSL&nbsp;service.&nbsp;<br />It&nbsp;also&nbsp;can&nbsp;evaluate&nbsp;your&nbsp;line&nbsp;quality.&nbsp;It&nbsp;also&nbsp;can&nbsp;have&nbsp;PPPoE&nbsp;dial,&nbsp;do&nbsp;IE&nbsp;network&nbsp;page&nbsp;browsing,&nbsp;and&nbsp;emulate&nbsp;user&nbsp;'&nbsp;s&nbsp;PC+&nbsp;Modem&nbsp;by&nbsp;inside&nbsp;Modem&nbsp;of&nbsp;GAO330&nbsp;to&nbsp;test&nbsp;the&nbsp;connection&nbsp;between&nbsp;user&nbsp;and&nbsp;ISP&nbsp;provider.&nbsp;You&nbsp;can&nbsp;have&nbsp;all&nbsp;kinds&nbsp;of&nbsp;test&nbsp;such&nbsp;as&nbsp;Ping,&nbsp;Ipconfig,&nbsp;Rouge,&nbsp;Tracert&nbsp;after&nbsp;successful&nbsp;dial.&nbsp;GAO330&nbsp;also&nbsp;can&nbsp;emulate&nbsp;the&nbsp;user&nbsp;'&nbsp;s&nbsp;PC&nbsp;to&nbsp;test&nbsp;broadband&nbsp;IP&nbsp;line&nbsp;or&nbsp;have&nbsp;PPPoE&nbsp;dial&nbsp;by&nbsp;user&nbsp;'&nbsp;s&nbsp;Modem&nbsp;to&nbsp;test&nbsp;the&nbsp;connection&nbsp;of&nbsp;IP&nbsp;network&nbsp;and&nbsp;Modem&nbsp;problem&nbsp;or&nbsp;to&nbsp;remove&nbsp;the&nbsp;problem&nbsp;arisen&nbsp;by&nbsp;computer.&nbsp;<br />GAO330&nbsp;takes&nbsp;240X320&nbsp;TFT&nbsp;true&nbsp;color&nbsp;LCD,&nbsp;touching&nbsp;screen&nbsp;and&nbsp;embedded&nbsp;system.&nbsp;So&nbsp;it&nbsp;is&nbsp;easy&nbsp;to&nbsp;operate&nbsp;and&nbsp;to&nbsp;see&nbsp;the&nbsp;test&nbsp;result.&nbsp;<br /><br />ADSL&nbsp;Tester&nbsp;-&nbsp;GAO330&nbsp;xDSL&nbsp;Tester&nbsp;-&nbsp;Features&nbsp;<br />xDSL&nbsp;Test&nbsp;<br /><br />Test&nbsp;xDSL&nbsp;line&nbsp;and&nbsp;validate&nbsp;dialing&nbsp;and&nbsp;**n&nbsp;Internet.&nbsp;Testing&nbsp;items&nbsp;include&nbsp;physical&nbsp;layer&nbsp;test,&nbsp;Modem&nbsp;parameter&nbsp;setting,&nbsp;PPPoE&nbsp;property,&nbsp;PPPoE&nbsp;dial,&nbsp;network&nbsp;layer&nbsp;test(Ping,&nbsp;Ipconfig,&nbsp;Route,&nbsp;Tracert),&nbsp;loopback&nbsp;test,&nbsp;webpage&nbsp;browsing,and&nbsp;so&nbsp;on.&nbsp;<br />LAN&nbsp;Test&nbsp;<br /><br />LAN&nbsp;test&nbsp;includs&nbsp;netcard&nbsp;property,&nbsp;PPPoE&nbsp;property,&nbsp;PPPoE&nbsp;dial,&nbsp;network&nbsp;layer&nbsp;test&nbsp;(Ping,&nbsp;Ipconfig,&nbsp;Route,&nbsp;Tracert),webpage&nbsp;browsing,&nbsp;fixative&nbsp;IP&nbsp;scanning,&nbsp;Ftp&nbsp;Client&nbsp;and&nbsp;webpage&nbsp;speed&nbsp;test.&nbsp;<br />DMM&nbsp;Test&nbsp;<br /><br />Test&nbsp;xDSL&nbsp;line&nbsp;physical&nbsp;layer&nbsp;parameters&nbsp;include&nbsp;loop&nbsp;resistance,&nbsp;capacitance,&nbsp;insulation&nbsp;resistance&nbsp;and&nbsp;voltage.&nbsp;<br />Modem&nbsp;Emulation:&nbsp;Emulate&nbsp;users&nbsp;Modem&nbsp;<br />File&nbsp;management:&nbsp;File&nbsp;management&nbsp;includes&nbsp;saving&nbsp;records,&nbsp;browsing&nbsp;records,&nbsp;memory&nbsp;key&nbsp;storage&nbsp;and&nbsp;file&nbsp;transmission.&nbsp;<br /><br />About&nbsp;GAO&nbsp;Tek&nbsp;Inc.<br />GAO&nbsp;Tek&nbsp;Inc.&nbsp;is&nbsp;a&nbsp;leading&nbsp;provider&nbsp;of&nbsp;test&nbsp;and&nbsp;measurement&nbsp;equipment,&nbsp;embedded&nbsp;development&nbsp;tools,&nbsp;telecommunication&nbsp;testers,&nbsp;electronic&nbsp;measurement&nbsp;instruments,&nbsp;video&nbsp;surveillance,&nbsp;alarm&nbsp;and&nbsp;other&nbsp;electronic&nbsp;products&nbsp;that&nbsp;serve&nbsp;the&nbsp;needs&nbsp;of&nbsp;electronic&nbsp;professionals&nbsp;internationally.<br />For&nbsp;more&nbsp;information&nbsp;please&nbsp;visit&nbsp;http://www.GAOTek.com.<br />
