2410才用下init, 程序大于4K时应该不能从nand启动起来了吧?
2299|2
playlinus|  楼主 | 2008-10-6 16:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ni, NAND, ST, se, AC
; NAME: 2410INIT.S
; DESC: C start up codes
;       Configure memory, ISR ,stacks
;    Initialize C-variables
; HISTORY:
; 2002.02.25:kwtark: ver 0.0
; 2002.03.20:purnnamu: Add some functions for testing STOP,POWER_OFF mode
    GET option.inc
    GET memcfg.inc
    GET 2410addr.inc
BIT_SELFREFRESH EQU    (1<<22)
;Pre-defined constants
USERMODE    EQU     0x10
FIQMODE     EQU     0x11
IRQMODE     EQU     0x12
SVCMODE     EQU     0x13
ABORTMODE   EQU     0x17
UNDEFMODE   EQU     0x1b
MODEMASK    EQU     0x1f
NOINT       EQU     0xc0
;The location of stacks
UserStack    EQU    (_STACK_BASEADDRESS-0x3800)    ;0x33ff4800 ~
SVCStack        EQU    (_STACK_BASEADDRESS-0x2800)     ;0x33ff5800 ~
UndefStack    EQU    (_STACK_BASEADDRESS-0x2400)     ;0x33ff5c00 ~
AbortStack    EQU    (_STACK_BASEADDRESS-0x2000)     ;0x33ff6000 ~
IRQStack        EQU    (_STACK_BASEADDRESS-0x1000)    ;0x33ff7000 ~
FIQStack    EQU    (_STACK_BASEADDRESS-0x0)    ;0x33ff8000 ~
;Check if tasm.exe(armasm -16 ...@ADS 1.0) is used.
    GBLL    THUMBCODE
    [ {CONFIG} = 16
THUMBCODE SETL  {TRUE}
        CODE32
THUMBCODE SETL  {FALSE}
        MACRO
    MOV_PC_LR
        [ THUMBCODE
            bx lr
            mov    pc,lr
    MEND
        MACRO
    MOVEQ_PC_LR
        [ THUMBCODE
            bxeq lr
            moveq pc,lr
    MEND
        MACRO
$HandlerLabel HANDLER $HandleLabel
$HandlerLabel
    sub    sp,sp,#4        ;decrement sp(to store jump address)
    stmfd    sp!,{r0}        ;PUSH the work register to stack(lr does't push because it return to original address)
    ldr     r0,=$HandleLabel;load the address of HandleXXX to r0
    ldr     r0,[r0]         ;load the contents(service routine start address) of HandleXXX
    str     r0,[sp,#4]      ;store the contents(ISR) of HandleXXX to stack
    ldmfd   sp!,{r0,pc}     ;POP the work register and pc(jump to ISR)
    MEND
    IMPORT  |Image$$RO$$Limit|  ; End of ROM code (=start of ROM data)
    IMPORT  |Image$$RW$$Base|   ; Base of RAM to initialise
    IMPORT  |Image$$ZI$$Base|   ; Base and limit of area
    IMPORT  |Image$$ZI$$Limit|  ; to zero initialise
    IMPORT  Main    ; The main entry of mon program
    AREA    Init,CODE,READONLY
    ENTRY
    ;1)The code, which converts to Big-endian, should be in little endian code.
    ;2)The following little endian code will be compiled in Big-Endian mode.
    ;  The code byte order should be changed as the memory bus width.
    ;3)The pseudo instruction,DCD can't be used here because the linker generates error.
    ASSERT    :DEF:ENDIAN_CHANGE
    [ ENDIAN_CHANGE
        ASSERT  :DEF:ENTRY_BUS_WIDTH
        ][ ENTRY_BUS_WIDTH=32
        b    ChangeBigEndian        ;DCD 0xea000007
        [ ENTRY_BUS_WIDTH=16
        andeq    r14,r7,r0,lsl #20   ;DCD 0x0007ea00
        [ ENTRY_BUS_WIDTH=8
        streq    r0,][r0,-r10,ror #1] ;DCD 0x070000ea
        b    ResetHandler
    b    HandlerUndef    ;handler for Undefined mode
    b    HandlerSWI    ;handler for SWI interrupt
    b    HandlerPabort    ;handler for PAbort
    b    HandlerDabort    ;handler for DAbort
    b    .        ;reserved
    b    HandlerIRQ    ;handler for IRQ interrupt
    b    HandlerFIQ    ;handler for FIQ interrupt
;@0x20
    b    EnterPWDN
ChangeBigEndian
;@0x24
        DCD    0xee110f10    ;0xee110f10 => mrc p15,0,r0,c1,c0,0
        DCD    0xe3800080    ;0xe3800080 => orr r0,r0,#0x80;  //Big-endian
        DCD    0xee010f10    ;0xee010f10 => mcr p15,0,r0,c1,c0,0
        DCD 0x0f10ee11
        DCD 0x0080e380
        DCD 0x0f10ee01
    [ ENTRY_BUS_WIDTH=8
        DCD 0x100f11ee
        DCD 0x800080e3
        DCD 0x100f01ee
    DCD 0xffffffff  ;swinv 0xffffff is similar with NOP and run well in both endian mode.
    DCD 0xffffffff
    DCD 0xffffffff
    DCD 0xffffffff
    DCD 0xffffffff
    b ResetHandler
;Function for entering power down mode
; 1. SDRAM should be in self-refresh mode.
; 2. All interrupt should be maksked for SDRAM/DRAM self-refresh.
; 3. LCD controller should be disabled for SDRAM/DRAM self-refresh.
; 4. The I-cache may have to be turned on.
; 5. The location of the following code may have not to be changed.
;void EnterPWDN(int CLKCON);
EnterPWDN
    mov r2,r0        ;r2=rCLKCON
    tst r0,#0x8        ;POWER_OFF mode?
    bne ENTER_POWER_OFF
ENTER_STOP
    ldr r0,=REFRESH
    ldr r3,[r0]        ;r3=rREFRESH
    mov r1, r3
    orr r1, r1, #BIT_SELFREFRESH
    str r1, [r0]        ;Enable SDRAM self-refresh
    mov r1,#16           ;wait until self-refresh is issued. may not be needed.
0    subs r1,r1,#1
    bne %B0
    ldr r0,=CLKCON        ;enter STOP mode.
    str r2,[r0]
    mov r1,#32
0    subs r1,r1,#1    ;1) wait until the STOP mode is in effect.
    bne %B0        ;2) Or wait here until the CPU&Peripherals will be turned-off
            ;   Entering POWER_OFF mode, only the reset by wake-up is available.
    ldr r0,=REFRESH ;exit from SDRAM self refresh mode.
    str r3,[r0]
    MOV_PC_LR
ENTER_POWER_OFF
    ;NOTE.
    ;1) rGSTATUS3 should have the return address after wake-up from POWER_OFF mode.
    ldr r0,=REFRESH
    ldr r1,[r0]        ;r1=rREFRESH
    mov r1,#16           ;Wait until self-refresh is issued,which may not be needed.
0    subs r1,r1,#1
    bne %B0
    ldr     r1,=MISCCR
    ldr    r0,[r1]
    orr    r0,r0,#(7<<17)  ;Make sure that SCLK0:SCLK->0, SCLK1:SCLK->0, SCKE=L during boot-up
    str    r0,[r1]
    ldr r0,=CLKCON
    str r2,[r0]
    b .            ;CPU will die here.
WAKEUP_POWER_OFF
    ;Release SCLKn after wake-up from the POWER_OFF mode.
    ldr     r1,=MISCCR
    ldr    r0,[r1]
    bic    r0,r0,#(7<<17)  ;SCLK0:0->SCLK, SCLK1:0->SCLK, SCKE:L->H
    str    r0,[r1]
    ;Set memory control registers
        ldr    r0,=SMRDATA
    ldr    r1,=BWSCON    ;BWSCON Address
    add    r2, r0, #52    ;End address of SMRDATA
    ldr    r3, [r0], #4
    str    r3, [r1], #4
    cmp    r2, r0
    bne    %B0
    mov r1,#256
0    subs r1,r1,#1    ;1) wait until the SelfRefresh is released.
    bne %B0
    ldr r1,=GSTATUS3     ;GSTATUS3 has the start address just after POWER_OFF wake-up
    ldr r0,[r1]
    mov pc,r0
    LTORG
HandlerFIQ      HANDLER HandleFIQ
HandlerIRQ      HANDLER HandleIRQ
HandlerUndef    HANDLER HandleUndef
HandlerSWI      HANDLER HandleSWI
HandlerDabort   HANDLER HandleDabort
HandlerPabort   HANDLER HandlePabort
IsrIRQ
    sub    sp,sp,#4       ;reserved for PC
    stmfd    sp!,{r8-r9}
    ldr    r9,=INTOFFSET
    ldr    r9,[r9]
    ldr    r8,=HandleEINT0
    add    r8,r8,r9,lsl #2
    ldr    r8,[r8]
    str    r8,[sp,#8]
    ldmfd    sp!,{r8-r9,pc}
; ENTRY
ResetHandler
    ldr    r0,=WTCON       ;watch dog disable
    ldr    r1,=0x0
    str    r1,[r0]
    ldr    r0,=INTMSK
    ldr    r1,=0xffffffff  ;all interrupt disable
    str    r1,[r0]
    ldr    r0,=INTSUBMSK
    ldr    r1,=0x3ff        ;all sub interrupt disable
    str    r1,[r0]
    [ {FALSE}
        ; rGPFDAT = (rGPFDAT & ~(0xf<<4)) | ((~data & 0xf)<<4);
        ; Led_Display
    ldr    r0,=GPFCON
    ldr    r1,=0x5500
    str    r1,][r0]
    ldr    r0,=GPFDAT
    ldr    r1,=0x10
    str    r1,[r0]
    ;To reduce PLL lock time, adjust the LOCKTIME register.
    ldr    r0,=LOCKTIME
    ldr    r1,=0xffffff
    str    r1,[r0]
        [ PLL_ON_START
    ;Configure MPLL
    ldr    r0,=MPLLCON
    ldr    r1,=((M_MDIV<<12)+(M_PDIV<<4)+M_SDIV)  ;Fin=12MHz,Fout=50MHz
    str    r1,][r0]
    ;Check if the boot is caused by the wake-up from POWER_OFF mode.
    ldr    r1,=GSTATUS2
    ldr    r0,[r1]
    tst    r0,#0x2
        ;In case of the wake-up from POWER_OFF mode, go to POWER_OFF_WAKEUP handler.
    bne    WAKEUP_POWER_OFF
    EXPORT StartPointAfterPowerOffWakeUp
        ldr    r0,=SMRDATA
    ldr    r3, [r0], #4
    str    r3, [r1], #4
    cmp    r2, r0
    bne    %B0
        ;Initialize stacks
    bl    InitStacks
      ; Setup IRQ handler
    ldr    r0,=HandleIRQ       ;This routine is needed
    ldr    r1,=IsrIRQ          ;if there isn't 'subs pc,lr,#4' at 0x18, 0x1c
    str    r1,[r0]
    ;Copy and paste RW data/zero initialized data
    ldr    r0, =|Image$$RO$$Limit| ; Get pointer to ROM data
    ldr    r1, =|Image$$RW$$Base|  ; and RAM copy
    ldr    r3, =|Image$$ZI$$Base|
    ;Zero init base => top of initialised data
    cmp    r0, r1      ; Check that they are different
    beq    %F2
    cmp    r1, r3      ; Copy init data
    ldrcc    r2, [r0], #4    ;--> LDRCC r2, [r0] + ADD r0, r0, #4
    strcc    r2, [r1], #4    ;--> STRCC r2, [r1] + ADD r1, r1, #4
    bcc    %B1
    ldr    r1, =|Image$$ZI$$Limit| ; Top of zero init segment
    mov    r2, #0
    cmp    r3, r1      ; Zero init
    strcc    r2, [r3], #4
    bcc    %B3
    [ :LNOT:THUMBCODE
        bl    Main        ;Don't use main() because ......
        b    .
    [ THUMBCODE         ;for start-up code for Thumb mode
        orr    lr,pc,#1
        bx    lr
        CODE16
        b    .
        CODE32
;function initializing stacks
InitStacks
    ;Don't use DRAM,such as stmfd,ldmfd......
    ;SVCstack is initialized before
    ;Under toolkit ver 2.5, 'msr cpsr,r1' can be used instead of 'msr cpsr_cxsf,r1'
    mrs    r0,cpsr
    bic    r0,r0,#MODEMASK
    orr    r1,r0,#UNDEFMODE|NOINT
    msr    cpsr_cxsf,r1        ;UndefMode
    ldr    sp,=UndefStack
    orr    r1,r0,#ABORTMODE|NOINT
    msr    cpsr_cxsf,r1        ;AbortMode
    ldr    sp,=AbortStack
    orr    r1,r0,#IRQMODE|NOINT
    msr    cpsr_cxsf,r1        ;IRQMode
    ldr    sp,=IRQStack
    orr    r1,r0,#FIQMODE|NOINT
    msr    cpsr_cxsf,r1        ;FIQMode
    ldr    sp,=FIQStack
    bic    r0,r0,#MODEMASK|NOINT
    orr    r1,r0,#SVCMODE
    msr    cpsr_cxsf,r1        ;SVCMode
    ldr    sp,=SVCStack
    ;USER mode has not be initialized.
    mov    pc,lr
    ;The LR register won't be valid if the current mode is not SVC mode.
    LTORG
SMRDATA DATA
; Memory configuration should be optimized for best performance
; The following parameter is not optimized.
; Memory access cycle parameter strategy
; 1) The memory settings is  safe parameters even at HCLK=75Mhz.
; 2) SDRAM refresh period is for HCLK=75Mhz.
        DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28))
        DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC))   ;GCS0
        DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC))   ;GCS1
        DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC))   ;GCS2
        DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC))   ;GCS3
        DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC))   ;GCS4
        DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC))   ;GCS5
        DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN))    ;GCS6
        DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN))    ;GCS7
        DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT)
    DCD 0x32            ;SCLK power saving mode, BANKSIZE 128M/128M
        DCD 0x30            ;MRSR6 CL=3clk
        DCD 0x30            ;MRSR7
;        DCD 0x20            ;MRSR6 CL=2clk
;        DCD 0x20            ;MRSR7
        ALIGN
        AREA RamData, DATA, READWRITE
        ^   _ISR_STARTADDRESS
HandleReset     #   4
HandleUndef     #   4
HandleSWI       #   4
HandlePabort    #   4
HandleDabort    #   4
HandleReserved  #   4
HandleIRQ       #   4
HandleFIQ       #   4
;Don't use the label 'IntVectorTable',
;The value of IntVectorTable is different with the address you think it may be.
;IntVectorTable
HandleEINT0       #   4
HandleEINT1       #   4
HandleEINT2       #   4
HandleEINT3       #   4
HandleEINT4_7    #   4
HandleEINT8_23    #   4
HandleRSV6    #   4
HandleBATFLT       #   4
HandleTICK       #   4
HandleWDT    #   4
HandleTIMER0     #   4
HandleTIMER1     #   4
HandleTIMER2     #   4
HandleTIMER3     #   4
HandleTIMER4     #   4
HandleUART2      #   4
HandleLCD     #   4
HandleDMA0    #   4
HandleDMA1    #   4
HandleDMA2    #   4
HandleDMA3    #   4
HandleMMC    #   4
HandleSPI0    #   4
HandleUART1    #   4
HandleRSV24    #   4
HandleUSBD    #   4
HandleUSBH    #   4
HandleIIC       #   4
HandleUART0     #   4
HandleSPI1     #   4
HandleRTC     #   4
HandleADC     #   4
        END
twentyone| | 2008-10-8 00:01 | 只看该作者
RE
从NAND FLASH启动,2410提供了STEPPING STONE,只支持4K代码的拷贝。这只是一种启动方式,你需要灵活应用,以满足你的程序的需要。
playlinus|  楼主 | 2008-10-8 09:47 | 只看该作者
我是问以上的init实现不了大于4K程序的nand启动吧 ?
是不是需要额外的搬运nand内容到SDRAM的函数才可以实现 ?
