FlashPro<br />Version: 8.5.2.4<br />Release: v8.5 SP2<br /><br />Software Version: 8.5.2.4<br />Warning: Using local backup copy: 'E:\vga_lcd\mini2440\verilog\VGA\vga\designer\impl1\vga_fp\projectData\vga.pdb'.<br />PDB file 'E:\vga_lcd\mini2440\verilog\VGA\vga\designer\impl1\vga_fp\projectData\vga.pdb' has been loaded successfully.<br />DESIGN : vga; CHECKSUM : FF61; PDB_VERSION : 1.6<br />Error: Failed to acquire communication port.<br />Opened 'E:\vga_lcd\mini2440\verilog\VGA\vga\designer\impl1\vga_fp\vga.pro'<br />Checking for software updates...<br />Info: This software version is up to date. There are no available updates.<br />Rescanning for Programmers...<br />Rescanning for Programmers DONE.<br />programmer 'FPBBALTLPT1' : Para2Buff<br />programmer 'FPBBALTLPT1' : Scan Chain...<br />Error: programmer 'FPBBALTLPT1' : Signal Integrity Failure<br /> Integrity Check Pattern Not Found.<br /> Integrity Check Pattern :<br /> 550FAAF000FF0000FFFF<br /> IrScan Error.<br /> TDO stuck at 0<br /> Chain Analysis Failed.<br />Error: programmer 'FPBBALTLPT1' : Data Bit length : 8272<br />Error: programmer 'FPBBALTLPT1' : Compare Data : 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000<br />Error: programmer 'FPBBALTLPT1' : Scan Chain FAILED.<br />Error: Failed to run Action.<br />programmer 'FPBBALTLPT1' : Scan Chain...<br />Error: programmer 'FPBBALTLPT1' : Signal Integrity Failure<br /> Integrity Check Pattern Not Found.<br /> Integrity Check Pattern :<br /> 550FAAF000FF0000FFFF<br /> IrScan Error.<br /> TDO stuck at 0<br /> Chain Analysis Failed.<br />Error: programmer 'FPBBALTLPT1' : Data Bit length : 8272<br />Error: programmer 'FPBBALTLPT1' : Compare Data : 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000<br />Error: programmer 'FPBBALTLPT1' : Scan Chain FAILED.<br />Error: Failed to run Action.<br /> |
