[Actel FPGA] [求助]JTAG下载出错,无法找到设备!
3283|2
 楼主| peizhiluo 发表于 2008-3-16 18:41 | 显示全部楼层 |阅读模式
问大家一个问题,我自制的板子,用A3P060芯片。<br />可是JTAG连接后就是找不到该设备。<br />我片子管脚上各点电压都量过了,<br />VCC1.5V,&nbsp;VPUMP和VJTAG3.3V。<br />连程序多没法下载,什么也做不下去了。<br />有知道的吗??指点一下,<br /><br />FlashPro软件提示下面错误:<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Signal&nbsp;Integrity&nbsp;Failure<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Integrity&nbsp;Check&nbsp;Pattern&nbsp;Not&nbsp;Found.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Integrity&nbsp;Check&nbsp;Pattern&nbsp;:<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;550FAAF000FF0000FFFF<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;IrScan&nbsp;Error.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Possible&nbsp;chain&nbsp;exceeds&nbsp;expected&nbsp;maximum&nbsp;device&nbsp;count:&nbsp;256.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Chain&nbsp;Analysis&nbsp;Failed.<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Data&nbsp;Bit&nbsp;length&nbsp;:&nbsp;8272<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Compare&nbsp;Data&nbsp;&nbsp;:&nbsp;81D6035A78007F0000FFFF000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000......<br />Error:&nbsp;programmer&nbsp;'FPBBALTLPT1'&nbsp;:&nbsp;Scan&nbsp;Chain&nbsp;FAILED.<br />Error:&nbsp;Failed&nbsp;to&nbsp;run&nbsp;Action.<br />
zlgactel 发表于 2008-3-19 21:17 | 显示全部楼层
re
请问你用的是什么下载线呢?
li0411 发表于 2008-3-21 11:10 | 显示全部楼层
你怎么解决的?
我使用的A3P250,下载时也出现了同样的情况,请问你怎么解决的?
