[ZLG-MCU] diy lmiflash工具
2490|2
 楼主| machunshui 发表于 2008-3-20 09:32 | 显示全部楼层 |阅读模式
LMIFLASH&nbsp;and&nbsp;JTAG<br /><br />CorrecT&nbsp;me&nbsp;if&nbsp;I&nbsp;am&nbsp;WRONG&nbsp;:&nbsp;-<br />Eric,<br />1)&nbsp;LMIFLASH&nbsp;utility&nbsp;implements&nbsp;a&nbsp;JTAG&nbsp;programmer&nbsp;via&nbsp;a&nbsp;FTDI's&nbsp;FT232&nbsp;driver&nbsp;chip&nbsp;and&nbsp;hence&nbsp;it&nbsp;is&nbsp;non&nbsp;compatible&nbsp;to&nbsp;Wiggler&nbsp;hardware.<br />2)&nbsp;And&nbsp;if&nbsp;we&nbsp;do&nbsp;not&nbsp;want&nbsp;to&nbsp;buy&nbsp;Luminary&nbsp;Development&nbsp;board,&nbsp;can&nbsp;we&nbsp;DIY&nbsp;our&nbsp;own&nbsp;FDTI&nbsp;FT232&nbsp;chip&nbsp;board&nbsp;programmer&nbsp;and&nbsp;make&nbsp;our&nbsp;own&nbsp;and&nbsp;just&nbsp;use&nbsp;the&nbsp;LMIFLASH&nbsp;utility&nbsp;?<br />3)&nbsp;If&nbsp;LMIFLASH&nbsp;utility&nbsp;does&nbsp;not&nbsp;require&nbsp;firmware<br />sitting&nbsp;inside&nbsp;the&nbsp;LM3S102&nbsp;chip&nbsp;or&nbsp;there&nbsp;is&nbsp;No&nbsp;seriaL&nbsp;number&nbsp;sitting&nbsp;inside&nbsp;the&nbsp;CAT93C46&nbsp;chip&nbsp;that&nbsp;requres&nbsp;authentification,&nbsp;we&nbsp;can&nbsp;readily&nbsp;do&nbsp;it,&nbsp;right&nbsp;or&nbsp;wrong&nbsp;?<br /><br /><br /><br /><br /><br /><br />Re:LMIFLASH&nbsp;and&nbsp;JTAG<br /><br />Answers:<br /><br />1.&nbsp;Yes,&nbsp;LMIFLASH&nbsp;uses&nbsp;FTDI's&nbsp;D2XX&nbsp;drivers&nbsp;to&nbsp;communicate&nbsp;with&nbsp;the&nbsp;FT2232,&nbsp;and&nbsp;is&nbsp;not&nbsp;compatible&nbsp;with&nbsp;any&nbsp;other&nbsp;hardware.<br /><br />2.&nbsp;Yes,&nbsp;you&nbsp;can&nbsp;definitely&nbsp;implement&nbsp;your&nbsp;own&nbsp;FT2232&nbsp;interface&nbsp;and&nbsp;use&nbsp;LMIFLASH.&nbsp;The&nbsp;only&nbsp;thing&nbsp;other&nbsp;requirement&nbsp;(other&nbsp;than&nbsp;the&nbsp;FTDI&nbsp;chip)&nbsp;is&nbsp;that&nbsp;the&nbsp;USB&nbsp;EEPROM&nbsp;be&nbsp;programmed&nbsp;with&nbsp;something&nbsp;that&nbsp;LMIFLASH&nbsp;knows&nbsp;about,&nbsp;meaning&nbsp;that&nbsp;the&nbsp;device&nbsp;string&nbsp;would&nbsp;need&nbsp;to&nbsp;be&nbsp;named&nbsp;as&nbsp;one&nbsp;of&nbsp;our&nbsp;boards.&nbsp;If&nbsp;the&nbsp;requirement&nbsp;arises,&nbsp;I&nbsp;can&nbsp;change&nbsp;the&nbsp;utility&nbsp;to&nbsp;allow&nbsp;you&nbsp;to&nbsp;pass&nbsp;a&nbsp;device&nbsp;name&nbsp;for&nbsp;connection&nbsp;purposes.<br /><br />3.&nbsp;This&nbsp;kind&nbsp;of&nbsp;ties&nbsp;in&nbsp;with&nbsp;(2).&nbsp;The&nbsp;current&nbsp;implementation&nbsp;of&nbsp;LMIFLASH&nbsp;requires&nbsp;that&nbsp;the&nbsp;board&nbsp;be&nbsp;one&nbsp;of&nbsp;the&nbsp;device&nbsp;name&nbsp;strings&nbsp;that&nbsp;we&nbsp;program&nbsp;into&nbsp;the&nbsp;EEPROM&nbsp;at&nbsp;the&nbsp;factory.&nbsp;Those&nbsp;names&nbsp;are:<br /><br />&quot;LM3S811&nbsp;Evaluation&nbsp;Board&nbsp;A&quot;<br />&quot;LM3Sxxx&nbsp;Development&nbsp;Board&nbsp;A&quot;<br />&quot;USB&nbsp;&lt-&gt&nbsp;JTAG/SWD&nbsp;A&quot;
flyhouse 发表于 2008-3-21 15:17 | 显示全部楼层
bu zi dao lz xian suo sen me ????
zuoyou 发表于 2008-3-21 23:34 | 显示全部楼层
re
猜了半天才知道2楼说甚么
