[i.MX] imx6dl上添加adv7180 请大神指教 在线等!
3761|6
 楼主| ruofeng1008 发表于 2016-1-5 09:23 | 显示全部楼层 |阅读模式
版本是4.4.2
board-imx6q_sabresd.c添加代码如下:
static void adv7180_pwdn(int pwdn)
        if (pwdn)
                gpio_set_value(SABRESD_CSI1_PWN, 1);
        else
                gpio_set_value(SABRESD_CSI1_PWN, 0);
static void mx6q_csi1_io_init(void)
        if (cpu_is_mx6q())
                mxc_iomux_v3_setup_multiple_pads(mx6q_sabresd_csi1_sensor_pads,
                        ARRAY_SIZE(mx6q_sabresd_csi1_sensor_pads));
        else if (cpu_is_mx6dl())
                mxc_iomux_v3_setup_multiple_pads(mx6dl_sabresd_csi1_sensor_pads,
                        ARRAY_SIZE(mx6dl_sabresd_csi1_sensor_pads));
        if (cpu_is_mx6q())
                mxc_iomux_set_gpr_register(1, 20, 1, 1);//by ruofeng
                //mxc_iomux_set_gpr_register(1, 19, 1, 1);
                //mxc_iomux_set_gpr_register(13, 0, 3, 4);
                mxc_iomux_set_gpr_register(13, 3, 3, 4);
/*static struct fsl_mxc_tvin_platform_data adv7180_data = {
    .dvddio_reg    = NULL,
    .dvdd_reg    = NULL,
    .avdd_reg    = NULL,
    .pvdd_reg    = NULL,
    .pwdn        = adv7180_pwdn,
    .reset        = NULL,
    .cvbs        = true,
    .io_init    = mx6q_csi1_io_init,
static struct fsl_mxc_camera_platform_data adv7180_data = {
        .mclk = 24000000,
        .mclk_source = 0,
        .csi = 1,
static struct i2c_board_info mxc_i2c2_board_info[] __initdata = {
#ifdef MYDEBUG
                I2C_BOARD_INFO("adv7180", 0x21),
                .platform_data = (void *)&adv7180_data,
#endif
static struct fsl_mxc_capture_platform_data capture_data[] = {
                .csi = 0,
                .ipu = 0,
                .mclk_source = 0,
                .is_mipi = 0,
                .csi = 1,
                .ipu = 0,
                .mclk_source = 0,
                .is_mipi = 1,
#ifdef MYDEBUG
                .csi = 1,
                .ipu = 1,
                .mclk_source = 0,
                .is_mipi = 0,
#endif
static void __init mx6_sabresd_board_init(void)
        imx6q_add_v4l2_capture(0, &capture_data[0]);
        imx6q_add_v4l2_capture(1, &capture_data[1]);
#ifdef MYDEBUG
        imx6q_add_v4l2_capture(2, &capture_data[2]);
#endif
启动后出现段错误,也不知道哪加错了,新手请指教
kris_fei 发表于 2016-1-5 09:39 | 显示全部楼层
你给的是driver的code,问的是segament fault的error,不是oops?
log也贴出来吧
评分
参与人数 1威望 +1 收起 理由
ruofeng1008 + 1
查看全部评分
 楼主| ruofeng1008 发表于 2016-1-5 09:47 | 显示全部楼层
log也贴出来吧
不知道哪错了  麻烦帮看看是不是有什么地方改错改漏了
LOG信息.pdf
304.06 KB, 下载次数: 25
log信息
 楼主| ruofeng1008 发表于 2016-1-5 10:45 | 显示全部楼层
log也贴出来吧
Internal error: Oops: 17 [#1] PREEMPT SMP
Modules linked in:
CPU: 0    Not tainted  (3.0.35 #49)
PC is at _ipu_get+0x4/0x24
我用gdb调试,定位出错误在:
Breakpoint 1 at 0xc048e404: file drivers/mxc/ipu3/ipu_common.c, line 217.
其中:ipu_common.c  line 217.
void _ipu_get(struct ipu_soc *ipu)
        int ret;
        ret = clk_enable(ipu->ipu_clk);
        if (ret < 0)
                BUG();
难道说我的时钟配置错误了吗  还是什么?
mini1986 发表于 2016-1-5 10:49 | 显示全部楼层
没搞过这个,关注一下,学习学习......
kris_fei 发表于 2016-1-5 13:29 | 显示全部楼层
仿照csi0的初始化顺序添加下看看,是不是哪里有漏掉了。
 楼主| ruofeng1008 发表于 2016-1-6 10:36 | 显示全部楼层
没有漏,imx6DL是只支持一个IPU的,电路应该出错了。
