[ZLG-ARM] 周工请帮忙_旧工程转新工程出现的问题
2751|1
 楼主| yjgyiy 发表于 2008-4-1 16:23 | 显示全部楼层 |阅读模式
因旧工程维护<br />将周工的工程模板(旧工程由KEIL3.00a与ADS_1.2结合编译使用)更改到MDK3.20<br />出现问题<br /><br />如果使用MDK3.20+ADS_1.2编译时出现如下Error:<br /><br />target.c:&nbsp;Error:&nbsp;C3062E:&nbsp;unknown&nbsp;option&nbsp;'--depend'<br /><br />后使用keil下的Realview后又出现Error:<br /><br />.\Debug_in_ChipFlashAndChipRam\Project.axf:&nbsp;Error:&nbsp;L6238E:&nbsp;startup.o(vectors)&nbsp;contains&nbsp;invalid&nbsp;call&nbsp;from&nbsp;'~PRES8'&nbsp;function&nbsp;to&nbsp;'REQ8'&nbsp;function&nbsp;FIQ_Exception.<br /><br />.\Debug_in_ChipFlashAndChipRam\Project.axf:&nbsp;Error:&nbsp;L6238E:&nbsp;startup.o(vectors)&nbsp;contains&nbsp;invalid&nbsp;call&nbsp;from&nbsp;'~PRES8'&nbsp;function&nbsp;to&nbsp;'REQ8'&nbsp;function&nbsp;TargetResetInit.<br />
 楼主| yjgyiy 发表于 2008-4-1 16:58 | 显示全部楼层
找到问题了
在启动文件startup.s里增加如下代码<br /><br />PRESERVE8<br /><br />更改之前:<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;bottom_of_heap<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;bottom_of_Stacks<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;top_of_heap<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;StackUsr<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;Reset<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;__user_initial_stackheap<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;CODE32<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;AREA&nbsp;&nbsp;&nbsp;&nbsp;vectors,CODE,READONLY<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ENTRY<br /><br />更改之后:<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;bottom_of_heap<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;bottom_of_Stacks<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;top_of_heap<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;StackUsr<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;&nbsp;Reset<br />&nbsp;&nbsp;&nbsp;&nbsp;EXPORT&nbsp;__user_initial_stackheap<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;CODE32<br />&nbsp;&nbsp;&nbsp;&nbsp;PRESERVE8<br />&nbsp;&nbsp;&nbsp;&nbsp;AREA&nbsp;&nbsp;&nbsp;&nbsp;vectors,CODE,READONLY<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ENTRY<br /><br />编译通过<br />测试程序正常<br />哈!!!<br /><br />摆脱ADS_1.2了.<br />
