ATMEl的AT91SAM7SE系列获奖了
3887|2
 楼主| mmd2102 发表于 2007-1-16 11:55 | 显示全部楼层 |阅读模式
Atmel抯&nbsp;AT91SAM7SE&nbsp;32-bit&nbsp;Flash&nbsp;MCU&nbsp;Named&nbsp;in&nbsp;EDN抯&nbsp;Hot&nbsp;100&nbsp;Products&nbsp;of&nbsp;2006&nbsp;<br /><br />Selected&nbsp;for&nbsp;Processor&nbsp;Category&nbsp;<br /><br />Rousset,&nbsp;France,&nbsp;January&nbsp;15,&nbsp;2007&nbsp;.&nbsp;.&nbsp;.&nbsp;Atmel?Corporation&nbsp;(Nasdaq:&nbsp;ATML),&nbsp;a&nbsp;global&nbsp;leader&nbsp;in&nbsp;the&nbsp;development&nbsp;and&nbsp;fabrication&nbsp;of&nbsp;advanced&nbsp;semiconductor&nbsp;solutions,&nbsp;announced&nbsp;today&nbsp;that&nbsp;its&nbsp;AT91SAM7SE&nbsp;ARM?based&nbsp;32-bit&nbsp;Flash&nbsp;microcontroller&nbsp;has&nbsp;been&nbsp;included&nbsp;in&nbsp;EDN抯&nbsp;annual&nbsp;list&nbsp;of&nbsp;Hot&nbsp;100&nbsp;Products&nbsp;in&nbsp;the&nbsp;Processors&nbsp;category.&nbsp;These&nbsp;products&nbsp;are&nbsp;featured&nbsp;in&nbsp;EDN抯&nbsp;December&nbsp;15,&nbsp;2006&nbsp;issue&nbsp;and&nbsp;can&nbsp;be&nbsp;viewed&nbsp;at&nbsp;http://www.edn.com.&nbsp;<br /><br />The&nbsp;AT91SAM7SE-series&nbsp;is&nbsp;the&nbsp;industry抯&nbsp;first&nbsp;family&nbsp;of&nbsp;ARM7&nbsp;Flash&nbsp;MCUs&nbsp;to&nbsp;Support&nbsp;1G&nbsp;byte-Plus&nbsp;SDRAM,&nbsp;NAND&nbsp;Flash&nbsp;and&nbsp;CompactFlash?&nbsp;and&nbsp;they&nbsp;feature&nbsp;a&nbsp;universal&nbsp;memory&nbsp;interface&nbsp;including&nbsp;an&nbsp;Error&nbsp;Correcting&nbsp;Code&nbsp;Controller&nbsp;(ECC).&nbsp;Available&nbsp;with&nbsp;on-chip&nbsp;Flash&nbsp;memory&nbsp;densities&nbsp;of&nbsp;32K,&nbsp;256K,&nbsp;and&nbsp;512K&nbsp;bytes,&nbsp;the&nbsp;AT91SAM7SE&nbsp;microcontrollers&nbsp;also&nbsp;include&nbsp;the&nbsp;same&nbsp;supervisory&nbsp;features&nbsp;found&nbsp;on&nbsp;8-bit&nbsp;MCUs&nbsp;including&nbsp;a&nbsp;brown-out&nbsp;detector,&nbsp;power-on-reset,&nbsp;real-time&nbsp;clock,&nbsp;crystal&nbsp;oscillator,&nbsp;watchdog&nbsp;timer&nbsp;and&nbsp;three&nbsp;16-bit&nbsp;timers.&nbsp;Communication&nbsp;interfaces&nbsp;include&nbsp;three&nbsp;USARTs,&nbsp;USB,&nbsp;TWI,&nbsp;I2S&nbsp;(SSC)&nbsp;and&nbsp;SPI.&nbsp;The&nbsp;device&nbsp;also&nbsp;has&nbsp;four&nbsp;pulse&nbsp;width&nbsp;modulators&nbsp;(PWM),&nbsp;an&nbsp;8-channel,&nbsp;10-bit&nbsp;analog-to-digital&nbsp;converter&nbsp;(ADC)&nbsp;and&nbsp;88&nbsp;I/O&nbsp;pins.&nbsp;<br /><br />Like&nbsp;Atmel抯&nbsp;other&nbsp;AT91SAM7&nbsp;MCUs,&nbsp;the&nbsp;AT91SAM7SE-series&nbsp;has&nbsp;an&nbsp;11-channel&nbsp;peripheral&nbsp;DMA&nbsp;controller&nbsp;(PDC)&nbsp;that&nbsp;increases&nbsp;on-chip&nbsp;bandwidth&nbsp;to&nbsp;10&nbsp;Mbps&nbsp;while&nbsp;maintaining&nbsp;96%&nbsp;of&nbsp;the&nbsp;CPU抯&nbsp;cycles&nbsp;for&nbsp;application&nbsp;processing.&nbsp;The&nbsp;PDC&nbsp;can&nbsp;store&nbsp;the&nbsp;streaming&nbsp;content&nbsp;directly&nbsp;in&nbsp;the&nbsp;external&nbsp;NAND&nbsp;Flash&nbsp;or&nbsp;SDRAM&nbsp;without&nbsp;CPU&nbsp;intervention&nbsp;making&nbsp;these&nbsp;MCUs&nbsp;ideal&nbsp;for&nbsp;data&nbsp;logging&nbsp;applications&nbsp;such&nbsp;as&nbsp;ambulatory&nbsp;medical&nbsp;monitoring.&nbsp;<br /><br />Products&nbsp;that&nbsp;appear&nbsp;in&nbsp;EDN抯&nbsp;annual&nbsp;Hot&nbsp;100&nbsp;Products&nbsp;issue&nbsp;are&nbsp;chosen&nbsp;by&nbsp;its&nbsp;editors&nbsp;from&nbsp;the&nbsp;hundreds&nbsp;of&nbsp;newsworthy&nbsp;items&nbsp;that&nbsp;grace&nbsp;the&nbsp;pages&nbsp;of&nbsp;EDN,&nbsp;whether&nbsp;they&nbsp;appeared&nbsp;in&nbsp;EDN抯&nbsp;New&nbsp;Products&nbsp;section,&nbsp;a&nbsp;feature&nbsp;story,&nbsp;or&nbsp;an&nbsp;online&nbsp;exclusive.&nbsp;The&nbsp;list&nbsp;encompasses&nbsp;a&nbsp;range&nbsp;of&nbsp;architectures&nbsp;and&nbsp;technologies&nbsp;and&nbsp;numerous&nbsp;categories梖rom&nbsp;analog&nbsp;ICs&nbsp;to&nbsp;multimedia&nbsp;to&nbsp;test-and-measurement&nbsp;tools.&nbsp;<br /><br />Footnotes:&nbsp;<br /><br />MCU&nbsp;=&nbsp;Microcontroller&nbsp;<br /><br />SDRAM&nbsp;=&nbsp;Synchronous&nbsp;Dynamic&nbsp;Random&nbsp;Access&nbsp;Memory&nbsp;<br /><br />USART&nbsp;=&nbsp;Universal&nbsp;Synchronous/Asynchronous&nbsp;Receiver/Transmitter&nbsp;<br /><br />USB&nbsp;=&nbsp;Universal&nbsp;Serial&nbsp;Bus&nbsp;<br /><br />TWI&nbsp;=&nbsp;Two&nbsp;Wire&nbsp;Interface&nbsp;<br /><br />SSC&nbsp;=&nbsp;Synchronous&nbsp;Serial&nbsp;Controller&nbsp;<br /><br />SPI&nbsp;=&nbsp;Serial&nbsp;Peripheral&nbsp;Interface&nbsp;<br /><br />PWM&nbsp;=&nbsp;Pulse&nbsp;Width&nbsp;Modulator&nbsp;<br /><br />ADC&nbsp;=&nbsp;Analog-to-Digital&nbsp;Converter&nbsp;<br /><br />DMA&nbsp;=&nbsp;Direct&nbsp;Memory&nbsp;Access&nbsp;<br /><br />About&nbsp;Atmel&nbsp;<br /><br />Atmel&nbsp;is&nbsp;a&nbsp;worldwide&nbsp;leader&nbsp;in&nbsp;the&nbsp;design&nbsp;and&nbsp;manufacture&nbsp;of&nbsp;microcontrollers,&nbsp;advanced&nbsp;logic,&nbsp;mixed-signal,&nbsp;nonvolatile&nbsp;memory&nbsp;and&nbsp;radio&nbsp;frequency&nbsp;(RF)&nbsp;components.&nbsp;Leveraging&nbsp;one&nbsp;of&nbsp;the&nbsp;industry's&nbsp;broadest&nbsp;intellectual&nbsp;property&nbsp;(IP)&nbsp;technology&nbsp;portfolios,&nbsp;Atmel&nbsp;is&nbsp;able&nbsp;to&nbsp;provide&nbsp;the&nbsp;electronics&nbsp;industry&nbsp;with&nbsp;complete&nbsp;system&nbsp;solutions.&nbsp;Focused&nbsp;on&nbsp;consumer,&nbsp;industrial,&nbsp;security,&nbsp;communications,&nbsp;computing&nbsp;and&nbsp;automotive&nbsp;markets,&nbsp;Atmel&nbsp;ICs&nbsp;can&nbsp;be&nbsp;found&nbsp;Everywhere&nbsp;You&nbsp;Are&reg;.&nbsp;<br /><br />?2007&nbsp;Atmel&nbsp;Corporation.&nbsp;All&nbsp;Rights&nbsp;Reserved.&nbsp;Atmel?&nbsp;**&nbsp;and&nbsp;combinations&nbsp;thereof,&nbsp;Everywhere&nbsp;You&nbsp;Are?and&nbsp;others,&nbsp;are&nbsp;registered&nbsp;trademarks&nbsp;or&nbsp;trademarks&nbsp;of&nbsp;Atmel&nbsp;Corporation&nbsp;or&nbsp;its&nbsp;subsidiaries.&nbsp;ARM?is&nbsp;a&nbsp;registered&nbsp;trademark&nbsp;of&nbsp;ARM&nbsp;Ltd.&nbsp;Other&nbsp;terms&nbsp;and&nbsp;product&nbsp;names&nbsp;may&nbsp;be&nbsp;trademarks&nbsp;of&nbsp;others.&nbsp;<br /><br />About&nbsp;EDN&nbsp;<br /><br />Known&nbsp;as&nbsp;the&nbsp;揤oice&nbsp;of&nbsp;the&nbsp;engineer,?Waltham,&nbsp;MA-based&nbsp;EDN&nbsp;serves&nbsp;the&nbsp;vital&nbsp;information&nbsp;needs&nbsp;of&nbsp;design&nbsp;engineers&nbsp;and&nbsp;engineering&nbsp;managers&nbsp;worldwide.&nbsp;The&nbsp;EDN&nbsp;franchise&nbsp;includes&nbsp;EDN,&nbsp;EDN&nbsp;Europe,&nbsp;EDN&nbsp;Asia,&nbsp;EDN&nbsp;Australia,&nbsp;EDN&nbsp;China,&nbsp;EDN&nbsp;Japan,&nbsp;and&nbsp;EDN.com.&nbsp;<br /><br />EDN&nbsp;is&nbsp;published&nbsp;by&nbsp;Reed&nbsp;Business&nbsp;Information&nbsp;(www.reedbusiness/us.com),&nbsp;the&nbsp;largest&nbsp;business-to-business&nbsp;publisher&nbsp;in&nbsp;the&nbsp;U.S.&nbsp;and&nbsp;a&nbsp;member&nbsp;of&nbsp;the&nbsp;Reed&nbsp;Elsevier&nbsp;Group&nbsp;plc&nbsp;(NYSE:&nbsp;RUK&nbsp;and&nbsp;ENL)&nbsp;?a&nbsp;world-leading&nbsp;publisher&nbsp;and&nbsp;information&nbsp;provider&nbsp;operating&nbsp;in&nbsp;the&nbsp;science&nbsp;and&nbsp;medical,&nbsp;legal,&nbsp;education&nbsp;and&nbsp;business-to-business&nbsp;industry&nbsp;sectors.&nbsp;<br /><br />Information:&nbsp;<br /><br />Atmel's&nbsp;AT91SAM7SE&nbsp;product&nbsp;information&nbsp;may&nbsp;be&nbsp;retrieved&nbsp;at&nbsp;http://www.atmel.com/products/AT91/.<br /><br /><br />Atmel&nbsp;Press&nbsp;Contacts:&nbsp;<br /><br />Peter&nbsp;Bishop,&nbsp;Communications&nbsp;Manager,&nbsp;Atmel&nbsp;Rousset<br />Phone:&nbsp;+33&nbsp;(0)&nbsp;4&nbsp;42&nbsp;53&nbsp;61&nbsp;50,&nbsp;Email:&nbsp;peter.bishop@rfo.atmel.com<br /><br /><br />Helen&nbsp;Perlegos,&nbsp;Public&nbsp;Relations&nbsp;-&nbsp;USA&nbsp;and&nbsp;Asia&nbsp;Pacific&nbsp;Rim&nbsp;<br />Phone:&nbsp;+&nbsp;1&nbsp;408&nbsp;487-&nbsp;2963,&nbsp;Email:&nbsp;hperlegos@atmel.com<br /><br /><br />Veronique&nbsp;Sablereau,&nbsp;Corporate&nbsp;Communications&nbsp;Manager&nbsp;-&nbsp;Europe,&nbsp;<br />Phone:&nbsp;+33&nbsp;1&nbsp;30&nbsp;60&nbsp;70&nbsp;68,&nbsp;Fax:&nbsp;+&nbsp;49&nbsp;71&nbsp;31&nbsp;67&nbsp;24&nbsp;23&nbsp;<br />Email:&nbsp;veronique.sablereau@atmel.com<br /><br />
 楼主| mmd2102 发表于 2007-1-16 11:56 | 显示全部楼层
需要这个开发板的找我,有现货
需要这个开发板的找我,有现货,资源如下:<br />512KB内部Flash<br />32KB&nbsp;内部SRAM<br />32&nbsp;Mbytes&nbsp;of&nbsp;SDRAM&nbsp;memory<br />256&nbsp;Mbytes&nbsp;of&nbsp;NAND&nbsp;Flash&nbsp;memory<br />One&nbsp;USB&nbsp;device&nbsp;port&nbsp;interface<br />One&nbsp;DBGU&nbsp;serial&nbsp;communication&nbsp;port<br />One&nbsp;additional&nbsp;serial&nbsp;communication&nbsp;port&nbsp;with&nbsp;RTS/CTS&nbsp;handshake&nbsp;control<br />One&nbsp;JTAG/ICE&nbsp;debug&nbsp;interface<br />One&nbsp;Atmel&nbsp;AT73C213&nbsp;Stereo&nbsp;Audio&nbsp;DAC<br />One&nbsp;power&nbsp;LED&nbsp;and&nbsp;two&nbsp;general-purpose&nbsp;LEDs<br />One&nbsp;joystick&nbsp;and&nbsp;two&nbsp;user&nbsp;input&nbsp;pushbuttons<br />One&nbsp;Reset&nbsp;pushbutton<br />Three&nbsp;expansion&nbsp;connectors&nbsp;(PIO&nbsp;A,&nbsp;PIO&nbsp;B,&nbsp;PIO&nbsp;C)<br />One&nbsp;EBI&nbsp;expansion&nbsp;BGA-like&nbsp;footprint&nbsp;connector
 楼主| mmd2102 发表于 2007-1-16 13:28 | 显示全部楼层
re
Atmel为基于ARM7&nbsp;的USB微控制器&nbsp;SAM7&nbsp;系列增添三款新产品。全新的&nbsp;SAM7SE&nbsp;微控制器&nbsp;(MCU)&nbsp;备有32kB、256kB和512kB&nbsp;的闪存容量选择,是业界唯一配有外部总线接口的ARM7&nbsp;MCU,能够直接访问大容量的外部&nbsp;NAND&nbsp;闪存、SDRAM、CompactFlash、SRAM以及&nbsp;ROM存储器。在&nbsp;TrueIDE&nbsp;模式下,AT91SAM7SE&nbsp;的外部总线接口能支持32位NAND&nbsp;闪存、SDRAM&nbsp;和CompactFlash内存。此外,它配备了一个带有错误纠正代码控制器&nbsp;(error-correcting&nbsp;code&nbsp;controller,&nbsp;ECC)&nbsp;的NAND&nbsp;闪存控制器,能够补偿NAND闪存因长时间使用而丢失的数位。同时,AT91SAM7SE&nbsp;还含有一个内置的闪存控制器,不但可提供多达8个的可配置芯片选择,而且更支持多种16位和32位的静态设备,包括&nbsp;SRAM、ROM、闪存、内存映像的LCD,以及现场可编程门阵列&nbsp;(FPGA)。AT91SAM7SE512&nbsp;采用&nbsp;128&nbsp;脚绿色环保&nbsp;QFP&nbsp;或BGA封装。<br />
