那位高手帮忙看下CCS2000的这两条错误是什么意思??
4291|0
 楼主| clz918 发表于 2007-3-15 16:13 | 显示全部楼层 |阅读模式
&nbsp;&nbsp;小弟在往2812中下载程序时出现:<br /><br />&nbsp;&nbsp;<br /><br />Can't&nbsp;Remove&nbsp;Breakpoint:&nbsp;Error&nbsp;0x0000000A/-1153&nbsp;Error&nbsp;during:&nbsp;Memory,&nbsp;Break&nbsp;Point,&nbsp;&nbsp;The&nbsp;memory&nbsp;at&nbsp;0x003F87C1&nbsp;continually&nbsp;indicated&nbsp;it&nbsp;was&nbsp;'not&nbsp;ready'&nbsp;All&nbsp;memory&nbsp;operations&nbsp;currently&nbsp;in&nbsp;progress&nbsp;were&nbsp;aborted&nbsp;in&nbsp;order&nbsp;to&nbsp;regain&nbsp;control&nbsp;of&nbsp;the&nbsp;processor.&nbsp;This&nbsp;is&nbsp;considered&nbsp;a&nbsp;catastrophic&nbsp;event,&nbsp;but&nbsp;the&nbsp;debugger&nbsp;should&nbsp;&nbsp;still&nbsp;be&nbsp;able&nbsp;to&nbsp;access&nbsp;memory&nbsp;and&nbsp;CPU&nbsp;registers.&nbsp;System&nbsp;state&nbsp;has&nbsp;been&nbsp;altered.&nbsp;&nbsp;It&nbsp;is&nbsp;strongly&nbsp;advised&nbsp;that&nbsp;the&nbsp;processor&nbsp;should&nbsp;be&nbsp;reset&nbsp;before&nbsp;resuming&nbsp;execution,<br /><br />Breakpoint&nbsp;Manager:&nbsp;An&nbsp;error&nbsp;was&nbsp;encountered&nbsp;attempting&nbsp;to&nbsp;clear&nbsp;a&nbsp;breakpoint&nbsp;used<br /><br />&nbsp;for&nbsp;end&nbsp;of&nbsp;program&nbsp;detection.<br /><br />&nbsp;2812软件复位时出现:<br /><br />Failed&nbsp;Software&nbsp;Reset:&nbsp;Error&nbsp;0x00000020/-1150&nbsp;Error&nbsp;during:&nbsp;Execution,&nbsp;&nbsp;JTAG&nbsp;protocol&nbsp;reset.&nbsp;&nbsp;t&nbsp;0x003F87C1&nbsp;continually&nbsp;indicated&nbsp;it&nbsp;was&nbsp;'not&nbsp;ready'&nbsp;All&nbsp;memory&nbsp;operations&nbsp;currently&nbsp;in&nbsp;progress&nbsp;were&nbsp;aborted&nbsp;in&nbsp;order&nbsp;to&nbsp;regain&nbsp;control&nbsp;of&nbsp;the&nbsp;processor.&nbsp;This&nbsp;is&nbsp;considered&nbsp;a&nbsp;catastrophic&nbsp;event,&nbsp;but&nbsp;the&nbsp;debugger&nbsp;should&nbsp;&nbsp;still&nbsp;be&nbsp;able&nbsp;to&nbsp;access&nbsp;memory&nbsp;and&nbsp;CPU&nbsp;registers.&nbsp;System&nbsp;state&nbsp;has&nbsp;been&nbsp;altered.&nbsp;&nbsp;It&nbsp;is&nbsp;strongly&nbsp;advised&nbsp;that&nbsp;the&nbsp;processor&nbsp;should&nbsp;be&nbsp;reset&nbsp;before&nbsp;resuming&nbsp;execution,<br /><br />请问这两种故障是什么原因造成的&nbsp;&nbsp;<br />
