请教关于MODELSIM 软件四步仿真出现的问题
2543|3
 楼主| ATAO涛 发表于 2007-4-29 15:43 | 显示全部楼层 |阅读模式
  各位大侠: <br />    用ise7.1i&nbsp;设计的程序,,在modelsim xe ii 5.7C中仿真,,,<br />    1,&nbsp;行为仿真正确,,,simulate&nbsp;behavioral&nbsp;model&nbsp;is&nbsp;right;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;2,转换RTL后仿真也是正确的,,simulate post-translate vhdl model is right;<br />    3,映射后仿真错误.,,,simulate post-map vhdl model is error;<br />     错误: <br />     #&nbsp;**&nbsp;Error:&nbsp;(vsim-SDF-3240)&nbsp;vcm_vhd1_map.sdf(16945):&nbsp;   Instance&nbsp;'/uut/clk16mhz_1_317'&nbsp;does&nbsp;not&nbsp;have&nbsp;a&nbsp;generic&nbsp;named&nbsp;'tperiod_clk_posedge'.<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-SDF-3240)&nbsp;vcm_vhd1_map.sdf(12427):&nbsp;Instance&nbsp;'/uut/clk16mhz_248'&nbsp;does&nbsp;not&nbsp;have&nbsp;a&nbsp;generic&nbsp;named&nbsp;'tperiod_clk_posedge'.<br />#&nbsp;**&nbsp;Error:&nbsp;(vsim-SDF-3240)&nbsp;vcm_vhd1_map.sdf(17952):&nbsp;<br />Instance&nbsp;'/uut/cnt33_0'&nbsp;does&nbsp;not&nbsp;have&nbsp;a&nbsp;generic&nbsp;named&nbsp;'tperiod_clk_posedge'.<br />    4,布局布线后仿真错误,,,simulate post-place&route vhdl model is error;<br />
limee 发表于 2007-5-1 23:07 | 显示全部楼层
请贴代码
yb840311 发表于 2007-5-2 15:01 | 显示全部楼层
回复
可能代码中出了问题,把代码粘来看一下
 楼主| ATAO涛 发表于 2007-5-23 09:32 | 显示全部楼层
代码 应该没问题
&nbsp;代码应该没问题,,,&nbsp;下到FPGA里面,,运行功能是正确的,,,,就是用&nbsp;MODSIM仿真,,出现了上述问题
