IAR + IAR j-link download出错!
3630|0
 楼主| howard000 发表于 2007-4-29 15:48 | 显示全部楼层 |阅读模式
Sun Apr 29 15:51:45 2007: J-Link firmware: V1.20 (J-Link compiled Mar 22 2007 16:08:22 ARM Rev.5)
Sun Apr 29 15:51:45 2007: JTAG speed is initially set to: 32 kHz
Sun Apr 29 15:51:45 2007: Resetting target using RESET pin
Sun Apr 29 15:51:45 2007: Hardware reset with strategy 0 was performed
Sun Apr 29 15:51:45 2007: Initial reset was performed
Sun Apr 29 15:51:45 2007: J-Link found 1 JTAG device. ARM core Id: 3F0F0F0F(ARM7)
Sun Apr 29 15:51:45 2007: Device at TAP0 selected
Sun Apr 29 15:51:45 2007: Auto JTAG speed: 8000 kHz
Sun Apr 29 15:51:46 2007: 688 bytes downloaded and verified (1.13 Kbytes/sec)
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080C8
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080CC
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080D0
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080D2
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080E8
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008128
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000812C
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008130
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008132
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008150
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008158
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000815A
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008160
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000817D
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008180
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008182
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000081A4
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008242
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008001
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008004
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008038
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008244
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008248
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000824E
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000082A4
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000825C
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008268
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008281
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00000020
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008042
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x0000806C
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008078
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008080
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008094
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080A4
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x000080B8
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at Memory address 0x00008298
Sun Apr 29 15:51:46 2007: There were warnings during download, see Log Window
Sun Apr 29 15:51:49 2007: Loaded debugee: C:\Documents and Settings\Administrator\My Documents\LED\Debug\Exe\led.d79
Sun Apr 29 15:51:49 2007: Target reset
Sun Apr 29 15:52:20 2007: The stack 'CSTACK' is filled to 100% (8192 bytes used out of 8192). The warning threshold is set to 90%.
Sun Apr 29 15:52:20 2007: The stack 'IRQ_STACK' is filled to 100% (256 bytes used out of 256). The warning threshold is set to 90%.
