[技术问题解答] MPC5642A FLASH 擦除的块全是0
1454|0
 楼主| iyaqi2015 发表于 2016-1-7 09:36 | 显示全部楼层 |阅读模式
flash, pc, lm, se, TE
在对MPC5642A芯片FLASH中的L6和L7块擦除后,查看s19文件,对应的区域全是0,不是1,请论坛里的大神不吝赐教呀
擦除代码如下
void FlashEraseAll()
        /*********Init********/
        /* write the passwords*/
        FLASH_A.LMLR.R=0xA1A11111;
        FLASH_A.SLMLR.R=0xC3C33333;
        FLASH_A.HLR.R=0xB2B22222;
        /* unlock blosks we want to erash. FLASH_A:L6,L7*/
        FLASH_A.LMLR.R=0x8013033F;
        FLASH_A.SLMLR.R=0x8013033F;
        /*Clear MCR*/
        FLASH_A.MCR.R=0;
        /*********Erash********/
        /**Erash FLASH_A**/
        /* Set MCR ERS bit */
        FLASH_A.MCR.B.ERS = 1;
        /* FLASH_A:L6,L7 are selected for erase */
        FLASH_A.LMSR.R=0x000000C0;
        /* Interlock write */
        *(uint32*)(0x00018000) = 0xFFFFFFFF;
        *(uint32*)(0x0001C000) = 0xFFFFFFFF;
        /* Set MCR EHV bit */
        FLASH_A.MCR.B.EHV=1;
        while(FLASH_A.MCR.B.DONE==0){
        if(FLASH_A.MCR.B.PEG==1)
                FLASH_A.MCR.B.ERS=0;
                FLASH_A.MCR.B.EHV=0;
        while(1)
