<br />高温、常温一切正常<br />低温(-40度)下时钟、电压正常,但是AM186CC似乎没有跑起来,开发系统都挂不上去<br />开发系统是:帕拉丁... 通过串口连接<br /><br />调式信息如下:<br />连不上去<br />Info :Ensuring executable is up to date<br />Info :Loading: E:\E1_and_hlsl_old_final\4.20离开成都时的版本\e1_50suo_newversion_gao_version\e1_50suo_newversion_gao_version\e1u.axe <br />Info :-------- new debugging session 15:33:17 2007-5-9 --------<br />Info :Couldn't link to remote. Check power, cabling, and registry entries or reset target<br />Info :Process terminated: E:\E1_and_hlsl_old_final\4.20离开成都时的版本\e1_50suo_newversion_gao_version\e1_50suo_newversion_gao_version\e1u.axe<br /><br /><br />连上,程序下载15%后失败<br />Info :Ensuring executable is up to date<br />Info :Loading: E:\E1_and_hlsl_old_final\4.20离开成都时的版本\e1_50suo_newversion_gao_version\e1_50suo_newversion_gao_version\e1u.axe <br />Info :-------- new debugging session 15:03:00 2007-5-9 --------<br />Info :Cpu: Am186CC real address mode<br />Info :Target cpu reset<br />Info :Fatal communications error: Communication packet length byte read failure.<br />Info :The communications link to the remote has been lost (see runtime tab for details). You'll need to check the connection settings and possibly reset the target before reconnecting.<br />Info :Memory write test failed at address 0x018D90: wrote 0x55, read back 0x0 (Hidden)<br />Info :Can't load segment at 0x18d9:0x0 - one of the segment endpoints could not be written. See the Runtime tab in the Message window for exact details.<br />Info :Process terminated: E:\E1_and_hlsl_old_final\4.20离开成都时的版本\e1_50suo_newversion_gao_version\e1_50suo_newversion_gao_version\e1u.axe<br /><br /><br />急需解决,大虾帮忙下:)! <br /> <br /> |
