[ZLG-ARM] 请教ZLG的高人:MagicARM的ucLinux的问题
2273|6
 楼主| seu626 发表于 2007-6-27 20:07 | 显示全部楼层 |阅读模式
tart&nbsp;User's&nbsp;Program...Linux&nbsp;version&nbsp;2.4.24-uc0&nbsp;(root@vcmj)&nbsp;(gcc&nbsp;version&nbsp;2.95.3&nbsp;20015Processor:&nbsp;philip&nbsp;lpc2200&nbsp;revision&nbsp;14<br />Architecture:&nbsp;zlg-arm-linux<br />Ignoring&nbsp;unrecognised&nbsp;tag&nbsp;0x00000000<br />On&nbsp;node&nbsp;0&nbsp;totalpages:&nbsp;2048<br />zone(0):&nbsp;0&nbsp;pages.<br />zone(1):&nbsp;2048&nbsp;pages.<br />zone(2):&nbsp;0&nbsp;pages.<br />Kernel&nbsp;command&nbsp;line:&nbsp;root=/dev/ram<br />Calibrating&nbsp;delay&nbsp;loop...&nbsp;1.93&nbsp;BogoMIPS<br />Memory:&nbsp;8MB&nbsp;=&nbsp;8MB&nbsp;total<br />Memory:&nbsp;5876KB&nbsp;available&nbsp;(962K&nbsp;code,&nbsp;183K&nbsp;data,&nbsp;40K&nbsp;init)<br />Dentry&nbsp;cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;1024&nbsp;(order:&nbsp;1,&nbsp;8192&nbsp;bytes)<br />Inode&nbsp;cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;512&nbsp;(order:&nbsp;0,&nbsp;4096&nbsp;bytes)<br />Mount&nbsp;cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;512&nbsp;(order:&nbsp;0,&nbsp;4096&nbsp;bytes)<br />Buffer&nbsp;cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;1024&nbsp;(order:&nbsp;0,&nbsp;4096&nbsp;bytes)<br />Page-cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;2048&nbsp;(order:&nbsp;1,&nbsp;8192&nbsp;bytes)<br />POSIX&nbsp;conformance&nbsp;testing&nbsp;by&nbsp;UNIFIX<br />Linux&nbsp;NET4.0&nbsp;for&nbsp;Linux&nbsp;2.4<br />Based&nbsp;upon&nbsp;Swansea&nbsp;University&nbsp;Computer&nbsp;Society&nbsp;NET3.039<br />Initializing&nbsp;RT&nbsp;netlink&nbsp;socket<br />Starting&nbsp;kswapd<br />Serial&nbsp;driver&nbsp;version&nbsp;5.05c&nbsp;(2001-07-08)&nbsp;with&nbsp;no&nbsp;serial&nbsp;options&nbsp;enabled<br />ttyS00&nbsp;at&nbsp;0xe000c000&nbsp;(irq&nbsp;=&nbsp;6)&nbsp;is&nbsp;a&nbsp;16550A<br />ttyS01&nbsp;at&nbsp;0xe0010000&nbsp;(irq&nbsp;=&nbsp;7)&nbsp;is&nbsp;a&nbsp;16550A<br />RAMDISK&nbsp;driver&nbsp;initialized:&nbsp;16&nbsp;RAM&nbsp;disks&nbsp;of&nbsp;4096K&nbsp;size&nbsp;1024&nbsp;blocksize<br />NET4:&nbsp;Linux&nbsp;TCP/IP&nbsp;1.0&nbsp;for&nbsp;NET4.0<br />IP&nbsp;Protocols:&nbsp;ICMP,&nbsp;UDP,&nbsp;TCP<br />IP:&nbsp;routing&nbsp;cache&nbsp;hash&nbsp;table&nbsp;of&nbsp;512&nbsp;buckets,&nbsp;4Kbytes<br />TCP:&nbsp;Hash&nbsp;tables&nbsp;configured&nbsp;(established&nbsp;512&nbsp;bind&nbsp;512)<br />RAMDISK:&nbsp;ext2&nbsp;filesystem&nbsp;found&nbsp;at&nbsp;block&nbsp;0<br />RAMDISK:&nbsp;Loading&nbsp;1000&nbsp;blocks&nbsp;[1&nbsp;disk]&nbsp;into&nbsp;ram&nbsp;disk...&nbsp;done.<br />Freeing&nbsp;initrd&nbsp;memory:&nbsp;1024K<br />VFS:&nbsp;Mounted&nbsp;root&nbsp;(ext2&nbsp;filesystem)&nbsp;readonly.<br />Freeing&nbsp;init&nbsp;memory:&nbsp;40K<br />Shell&nbsp;invoked&nbsp;to&nbsp;run&nbsp;file:&nbsp;/etc/rc<br />Command:&nbsp;hostname&nbsp;GDB-ARMulator<br />Command:&nbsp;/bin/expand&nbsp;/etc/ramfs.img&nbsp;/dev/ram1<br />Command:&nbsp;mount&nbsp;-n&nbsp;-o&nbsp;remount,rw&nbsp;/<br />Command:&nbsp;mount&nbsp;-t&nbsp;proc&nbsp;proc&nbsp;/proc<br />Command:&nbsp;mount&nbsp;-t&nbsp;ext2&nbsp;/dev/ram1&nbsp;/var<br />Command:&nbsp;insmod&nbsp;/bin/zlg_ffs<br />Using&nbsp;/bin/zlg_ffs<br />Warning:&nbsp;loading&nbsp;zlg_ffs&nbsp;will&nbsp;taint&nbsp;the&nbsp;kernel:&nbsp;non-GPL&nbsp;license&nbsp;-&nbsp;Proprietary<br />&nbsp;&nbsp;See&nbsp;http://www.tux.org/lkml/#export-tainted&nbsp;for&nbsp;information&nbsp;about&nbsp;tainted&nbsp;modules<br />zlg_ffs:&nbsp;zlg_ffs_init&nbsp;OK<br />Command:&nbsp;mount&nbsp;/dev/zlg_ffs&nbsp;/usr<br />VFS:&nbsp;Can't&nbsp;find&nbsp;ext2&nbsp;filesystem&nbsp;on&nbsp;dev&nbsp;zlg_ffs(126,0).<br />kmod:&nbsp;failed&nbsp;to&nbsp;exec&nbsp;/sbin/modprobe&nbsp;-s&nbsp;-k&nbsp;nls_cp437,&nbsp;errno&nbsp;=&nbsp;2<br />kmod:&nbsp;failed&nbsp;to&nbsp;exec&nbsp;/sbin/modprobe&nbsp;-s&nbsp;-k&nbsp;nls_iso8859-1,&nbsp;errno&nbsp;=&nbsp;2<br />kmod:&nbsp;failed&nbsp;to&nbsp;exec&nbsp;/sbin/modprobe&nbsp;-s&nbsp;-k&nbsp;nls_iso8859-1,&nbsp;errno&nbsp;=&nbsp;2<br />kmod:&nbsp;failed&nbsp;to&nbsp;exec&nbsp;/sbin/modprobe&nbsp;-s&nbsp;-k&nbsp;nls_iso8859-1,&nbsp;errno&nbsp;=&nbsp;2<br />Command:&nbsp;mkdir&nbsp;/var/tmp<br />Command:&nbsp;mkdir&nbsp;/var/log<br />Command:&nbsp;mkdir&nbsp;/var/run<br />Command:&nbsp;mkdir&nbsp;/var/lock<br />Command:&nbsp;mkdir&nbsp;/var/empty<br />Command:&nbsp;/usr/etc/rc<br />/usr/etc/rc:&nbsp;Bad&nbsp;command&nbsp;or&nbsp;file&nbsp;name<br />Command:&nbsp;cat&nbsp;/etc/motd<br />Welcome&nbsp;to<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;____&nbsp;_&nbsp;&nbsp;_<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;/&nbsp;&nbsp;__|&nbsp;||_|<br />&nbsp;&nbsp;&nbsp;&nbsp;_&nbsp;&nbsp;&nbsp;_|&nbsp;|&nbsp;&nbsp;|&nbsp;|&nbsp;_&nbsp;____&nbsp;&nbsp;_&nbsp;&nbsp;&nbsp;_&nbsp;&nbsp;_&nbsp;&nbsp;_<br />&nbsp;&nbsp;&nbsp;|&nbsp;|&nbsp;|&nbsp;|&nbsp;|&nbsp;&nbsp;|&nbsp;||&nbsp;|&nbsp;&nbsp;_&nbsp;\|&nbsp;|&nbsp;|&nbsp;|\&nbsp;\/&nbsp;/<br />&nbsp;&nbsp;&nbsp;|&nbsp;|_|&nbsp;|&nbsp;|__|&nbsp;||&nbsp;|&nbsp;|&nbsp;|&nbsp;|&nbsp;|_|&nbsp;|/&nbsp;&nbsp;&nbsp;&nbsp;\<br />&nbsp;&nbsp;&nbsp;|&nbsp;&nbsp;___\____|_||_|_|&nbsp;|_|\____|\_/\_/<br />&nbsp;&nbsp;&nbsp;|&nbsp;|<br />&nbsp;&nbsp;&nbsp;|_|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />GDB/ARMulator&nbsp;support&nbsp;by&nbsp;&ltdavidm@snapgear.com&gt<br />For&nbsp;further&nbsp;information&nbsp;check:<br />http://www.uclinux.org/<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />Execution&nbsp;Finished,&nbsp;Exiting<br /><br />实在是郁闷了,启动如上老有错误,无法加载DM9000,网口灯不亮<br />请指点迷津,不胜感谢!
zlgarm 发表于 2007-6-29 08:34 | 显示全部楼层
re:
以太网和Modem接口有2个管脚复用,使用DM9000的时候请将Modem相关跳线断开。<br /><br />另外,要注意正确使用网线(交叉or平行)?否则网卡灯也不会亮。
wangharry 发表于 2007-6-29 23:42 | 显示全部楼层
请问 uClinux是板子上跑的 还是在skyeye跑的
请问&nbsp;uClinux是板子上跑的&nbsp;还是在skyeye跑的
 楼主| seu626 发表于 2007-6-30 10:38 | 显示全部楼层
再次请教
Modem接口跳线是断开的,网线应没什么问题,因为之前用gftp下载内核和文件系统时是成功的.总会出现这样的错误,实在不知为何,还请高人指点<br /><br />VFS:&nbsp;Can't&nbsp;find&nbsp;ext2&nbsp;filesystem&nbsp;on&nbsp;dev&nbsp;zlg_ffs(126,0).<br />kmod:&nbsp;failed&nbsp;to&nbsp;exec&nbsp;/sbin/modprobe&nbsp;-s&nbsp;-k&nbsp;nls_cp437,&nbsp;errno&nbsp;=&nbsp;2<br />kmod:&nbsp;failed&nbsp;to&nbsp;exec&nbsp;/sbin/modprobe&nbsp;-s&nbsp;-k&nbsp;nls_iso8859-1,&nbsp;errno&nbsp;=&nbsp;2<br />kmod:&nbsp;failed&nbsp;to&nbsp;exec&nbsp;/sbin/modprobe&nbsp;-s&nbsp;-k&nbsp;nls_iso8859-1,&nbsp;errno&nbsp;=&nbsp;2<br />kmod:&nbsp;failed&nbsp;to&nbsp;exec&nbsp;/sbin/modprobe&nbsp;-s&nbsp;-k&nbsp;nls_iso8859-1,&nbsp;errno&nbsp;=&nbsp;2<br />Command:&nbsp;mkdir&nbsp;/var/tmp<br />Command:&nbsp;mkdir&nbsp;/var/log<br />Command:&nbsp;mkdir&nbsp;/var/run<br />Command:&nbsp;mkdir&nbsp;/var/lock<br />Command:&nbsp;mkdir&nbsp;/var/empty<br />Command:&nbsp;/usr/etc/rc<br />/usr/etc/rc:&nbsp;Bad&nbsp;command&nbsp;or&nbsp;file&nbsp;name<br />Command:&nbsp;cat&nbsp;/etc/motd<br />
zlgarm 发表于 2007-6-30 12:19 | 显示全部楼层
re:
您是不是修改了内核或者文件系统?建议先更换为出厂程序试试。
wangharry 发表于 2007-7-1 20:55 | 显示全部楼层
skyeye
楼主你是用SKYEYE运行的吗?
 楼主| seu626 发表于 2007-7-2 15:54 | 显示全部楼层
还是不行
不是用skyeye<br /><br />另将光盘所带的ftproot中的文件,通过gftp下载到开发平台后启动依然<br />问题如上.实在是怪哉!<br />
