[STM32F0] 求stm32f030f4p6系统时钟变36MHZ的方法
1946|10
 楼主| 289947679 发表于 2016-1-8 17:03 | 显示全部楼层 |阅读模式
求stm32f030f4p6系统时钟变36MHZ的方法。不知道怎么去改。有图形
 楼主| 289947679 发表于 2016-1-8 17:05 | 显示全部楼层
Varus 发表于 2016-1-8 17:06 | 显示全部楼层
楼主用的内部还是外部时钟,是不是用分频
 楼主| 289947679 发表于 2016-1-8 17:07 | 显示全部楼层
这个图才是对的
xmshao 发表于 2016-1-9 11:53 | 显示全部楼层
看来大家对STM32Cube 运用得很熟啊
楼主也下载个STM32CUBEMX玩玩 很方便的
 楼主| 289947679 发表于 2016-1-9 13:54 | 显示全部楼层
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
uint16_t TimerPeriod = 0;
uint16_t Channel1Pulse = 0, Channel2Pulse = 0, Channel3Pulse = 0, Channel4Pulse = 0;
void TIM_Config(void)
NVIC_InitTypeDef NVIC_InitStructure;
TIM_OCInitTypeDef TIM_OCInitSrtucture;
        //TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM14, ENABLE);
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOB, ENABLE);
        /* ÅäÖÃGPIO¹Ü½Å¸´ÓÃ*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;// | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
        //Ó³ÉäI/OΪÍâÉèËùÓÃ
         GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_0);
// GPIO_InitTypeDef GPIO_InitStructure;
  /* ʹÄÜGPIOʱÖÓ */
// RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOB, ENABLE);
//  /* ÅäÖÃGPIO¹Ü½Å¸´ÓÃ*/
//  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;// | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
//  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
//  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
//  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
//  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
//  GPIO_Init(GPIOB, &GPIO_InitStructure);
  //GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_1);
//  GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_2);
//  GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_2);
//  GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_2);
void TIM_PWM_Config(void)
        /* TIM14 µÄÅäÖà ---------------------------------------------------PB1Êä³ö36Mhz clock
   TIM1 ÊäÈëʱÖÓ(TIM1CLK) ÉèÖÃΪ APB2 ʱÖÓ (PCLK2)
    => TIM1CLK = PCLK2 = SystemCoreClock
   TIM1CLK = SystemCoreClock, Prescaler = 0, TIM1 counter clock = SystemCoreClock
   SystemCoreClock Ϊ48 MHz
   ÎÒÃǵÄÄ¿±ê²úÉú 4 ·PWM ÐźÅÔÚ17.57 KHz:
     - TIM1_Period = (SystemCoreClock / 17570) - 1
   ÐŵÀ1ÉèÖõÄÕ¼¿Õ±ÈΪ 50%
   ÐŵÀ2ÉèÖõÄÕ¼¿Õ±ÈΪ 37.5%
   ÐŵÀ3ÉèÖõÄÕ¼¿Õ±ÈΪ 25%
   ÐŵÀ4ÉèÖõÄÕ¼¿Õ±ÈΪ 12.5%
   ¶¨Ê±Æ÷Âö³åµÄ¼ÆË㷽ʽÈçÏÂ:
     - ChannelxPulse = DutyCycle * (TIM1_Period - 1) / 100
    /*¼ÆËãÔ¤¶¨±íµÄÖµ£¬Ò²¾ÍÊǶàÉÙ¸öʱÖÓ¼ÆÊýΪһ¸öÖÜÆÚ*/
  //TimerPeriod = (SystemCoreClock / 17570 ) - 1;
        //TimerPeriod = (SystemCoreClock/1000000) -1 ;
  /*¼ÆËãCCR1 Ìø×ªÖµ ÔÚÕ¼¿Õ±ÈΪ50%ʱ*/
  Channel1Pulse = (uint16_t) (((uint32_t) 5 * ( TimerPeriod - 1)) / 10);
/*¼ÆËãCCR2 Ìø×ªÖµ ÔÚÕ¼¿Õ±ÈΪ37.5%ʱ*/
//  Channel2Pulse = (uint16_t) (((uint32_t) 375 * (TimerPeriod - 1)) / 1000);
//  /*¼ÆËãCCR3 Ìø×ªÖµ ÔÚÕ¼¿Õ±ÈΪ25%ʱ*/
//  Channel3Pulse = (uint16_t) (((uint32_t) 25 * (TimerPeriod - 1)) / 100);
// /*¼ÆËãCCR4Ìø×ªÖµ ÔÚÕ¼¿Õ±ÈΪ12.5%ʱ*/
//  Channel4Pulse = (uint16_t) (((uint32_t) 125 * (TimerPeriod- 1)) / 1000);
  /* TIM14 ʱÖÓʹÄÜ */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM14 , ENABLE);
  /* Time ¶¨Ê±»ù´¡ÉèÖÃ*/
//         u16 CCR1= 0;
//   u16 CCR2= 0;
  TIM_TimeBaseStructure.TIM_Prescaler =0 ;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  /* Time ¶¨Ê±ÉèÖÃΪÉÏÉýÑØ¼ÆËãģʽ*/
        //TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Down;  /* Time ¶¨Ê±ÉèÖÃΪÏÂÉýÑØ¼ÆËãģʽ*/
  TIM_TimeBaseStructure.TIM_Period = TimerPeriod;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM14, &TIM_TimeBaseStructure);
  /* ƵµÀ1£¬2£¬3£¬4µÄPWM ģʽÉèÖà */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  //TIM_OCInitStructure.TIM_Pulse = Channel1Pulse;//ʹÄÜÆµµÀ1ÅäÖÃ
  TIM_OC1Init(TIM14, &TIM_OCInitStructure);
//  TIM_OCInitStructure.TIM_Pulse = Channel2Pulse;//ʹÄÜÆµµÀ2ÅäÖÃ
//  TIM_OC2Init(TIM1, &TIM_OCInitStructure);
//  TIM_OCInitStructure.TIM_Pulse = Channel3Pulse;//ʹÄÜÆµµÀ3ÅäÖÃ
//  TIM_OC3Init(TIM1, &TIM_OCInitStructure);
//  TIM_OCInitStructure.TIM_Pulse = Channel4Pulse;//ʹÄÜÆµµÀ4ÅäÖÃ
//  TIM_OC4Init(TIM1, &TIM_OCInitStructure);
  /* TIM1 ¼ÆËãÆ÷ʹÄÜ*/
  TIM_Cmd(TIM14, ENABLE);
//  /* TIM1 Ö÷Êä³öʹÄÜ */
  TIM_CtrlPWMOutputs(TIM14, ENABLE);
//  TIM_ITConfig(TIM3,TIM_IT_CC1,ENABLE);
////        .NVIC_IRQChannel=TIM3_IRQN;
////        NVIC_Init
 楼主| 289947679 发表于 2016-1-9 13:55 | 显示全部楼层
现在系统时钟达到36M,但是PWM搞不出36MHZ
,有人帮我看看
309030 发表于 2016-1-9 16:49 | 显示全部楼层
PWM频率要这么高吗
UBC-Jason 发表于 2016-1-13 16:40 | 显示全部楼层
看官帮顶,学习学习!
