在我用quartus编译时候出来这样的警告 <br />Warning: Found pins functioning as undefined clocks and/or memory enables <br />Info: Assuming node "clk" is an undefined clock <br /><br />在时间仿真时出现这样的错误 <br />Error: Can't continue timing simulation because delay annotation information for design is missing <br />这些都是什么原因啊,我一直查不出来的,如果用功能仿真是可以仿真成功的。 <br />望高手指教 |
