STVD7求助
4128|3
 楼主| dangerb_cn 发表于 2007-9-5 11:55 | 显示全部楼层 |阅读模式
ST, tv, dc, ic, se
小弟菜鸟一个
最近开始学习使用STVD7软件
用的是汇编语言
遇到了麻烦
build 的时候老是出错
Assembling mapping.asm...
asm mapping.asm -I="C:\Program Files\STMicroelectronics\st7toolset\include" -I="C:\Program Files\STMicroelectronics\st7toolset\include"  -obj=Debug\mapping.obj -I="C:\Program Files\STMicroelectronics\st7toolset\asm\include"
STMicroelectronics assembler v4.49
      No errors on assembly of 'D:\stwork\mapping.asm'
Assembling adc.asm...
asm adc.asm -I="C:\Program Files\STMicroelectronics\st7toolset\include" -I="C:\Program Files\STMicroelectronics\st7toolset\include"  -obj=Debug\adc.obj -I="C:\Program Files\STMicroelectronics\st7toolset\asm\include"
Couldn't open table file 'C:\Program Files\STMicroelectronics\st7toolset\asm\TITLE "adc.ASM'.tab': Invalid argument
 The command: "asm adc.asm -I="C:\Program Files\STMicroelectronics\st7toolset\include" -I="C:\Program Files\STMicroelectronics\st7toolset\include"  -obj=Debug\adc.obj -I="C:\Program Files\STMicroelectronics\st7toolset\asm\include"" has failed, the returned value is: 2
exit code=2.
second.s19 - 1 error(s), 0 warning(s)
程序代码如下
TITLE "adc.ASM'
MOTOROLA
#INCLUDE "ST7FLITE02.INC"
WORDS
SEGMENG 'ROM'
.MAIN
      CALL INIT
.WAIT
      BTJF ADCCSR,#7,WAIT
            LD A,ADCDR
            LD PADR,A
            JRA WAIT
.INIT
      LD A,#$0FF
            LD PADDR,A
            LD PAOR,A
            LD A,#$25
            LD ADCCSR,A
            RET
            SEGMENT 'VECTOR'
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W 0
            DC.W MAIN
            END
zl_777 发表于 2007-9-14 17:39 | 显示全部楼层
少一个“st7/”
在程序开头的地方加一个“st7/”
st7/
TITLE "adc.ASM'
MOTOROLA
WORDS
SEGMENG 'ROM'
.MAIN
      CALL INIT
.WAIT
qigongwei 发表于 2007-9-14 21:29 | 显示全部楼层
Reference
以前自己写的一个文档里,刚好有这么一段介绍ST7 ASM的内容,我贴上来你可以参考参考,其实更具体的内容你可以在下面的文档中找到:
6、ST7 Family Programming Manual
http://www.st.com/stonline/products/literature/pm/4020.pdf
ST7汇编文件格式
       下列为ST7汇编文件格式参考:
st7/        ;(1)
       TITLE "test.asm"        ;(2)
       MOTOROLA        ;(3)
       #INCLUDE "st72324.inc"      ; Include st72324 registers and memory mapping file.      ;(4)
#INCLUDE "userdef.inc"      ;扩展外部定义文件
segment 'ram'          ;RAM Segment                                      ;(5)
#Define        ;(6)
Data  EQU  100
;************RAM0 SEGMENT************
WORDS         ; following addresses are 16 bit length.                    ;(7)
       segment 'rom'          ;Program Code                                        ;(8)
;------- Main Program Sub-Routine Section ----------
.main             ;Initialization                                                              ;(9)
       RSP        ;Reset Stack Pointer
.Loop
       NOP
JP Loop
.Dummy_rt        ;(10)
       IRET
;---------Interrupt & Reset Vectors-------------------
       segment 'vectit'        ;(11)
       DC.W Dummy_rt ; FFE0-FFE1h location
       DC.W Dummy_rt ; FFE2-FFE3h location
AVD:
      DC.W Dummy_rt ; FFE4-FFE5h location
SCI:
DC.W Dummy_rt ; FFE6-FFE7h location
Timer_B:
    DC.W Dummy_rt
Timer_A:
    DC.W Dummy_rt
SPI:
       DC.W Dummy_rt ; FFEC-FFEDh location
       DC.W Dummy_rt ; FFEE-FFEFh location
Port_B_1:
      DC.W PortB_INT ; FFF0-FFF1h location
Port_B_2:
       DC.W Dummy_rt ; FFF2-FFF3h location
Port_F:
      DC.W Dummy_rt ; FFF4-FFF5h location
Port_A:
       DC.W Dummy_rt ; FFF6-FFF7h location
Time_RTC:
DC.W Dummy_rt ; FFF8-FFF9h location
       DC.W Dummy_rt ; FFFA-FFFBh location
TRAP_1:
      DC.W Dummy_rt ; FFFC-FFFDh location
Reset:
      DC.W main          ; FFFE-FFFFh location
       END        ;(12)
说明:
st7/        ;(1)
       MOTOROLA        ;(3)
代码中数字的表达方式。ST7汇编编译器提供下述四种格式的支持:
进制
INTEL
MOTOLORA
TEXAS
ZILOG
二进制
1010B
%1010
?1010
%(2)1010
八进制
175O
-175
-175
%(8)175
十六进制
45H or 0FFH
$45 or $FF
>45  or >FF
%45 or %FF
       将MOTOROLA改为你习惯的格式代码即可,记得使用的16进制格式也要该过来。
伪指令(Include)
       用于包含外部定义文件。上述定义为提供给编译器的MCU特殊功能寄存器文件。可通过打开SDVP7安装路径下的“C:\Program Files\STMicroelectronics\st7toolset\include”找到(路径为默认定义路径)。
伪指令(Segment)
       用于定义可寻址空间的一个地址范围,具有可被定义的属性。一个程序模块中最多可以定义128个段,可允许的类型有:
名称
类型
ROM
只读存储器,用于程序存储区
RAM0
读写存储器,用于8位地址区
RAM1
读写存储器,用于16位地址区
STACK
读写存储器,用于堆栈
IO
用于IO寄存器(地址在0页)
VECTOR
中断矢量地址区
       段允许将一段代码定义在以某一其实地址开始底空间,也允许定义一部分变量集中放置到某一个RAM范围内。
#Define        ;(6)
Data  EQU  100
伪指令(Define/EQU)
       Define:给符号常量赋字符串值;
       EQU: 对符号常数赋值,赋值后值不可跟改;
WORDS         ; following addresses are 16 bit length                                                         ;(7)
       起始地址是偶数
    段定义,表明一下代码内容在下一个“segment”之前均位于“ROM”区
       标号,ST汇编编译器最大支持标号字符数为26。
.Dummy_rt        ;(10)
       异常中断函数入口。这里出于对系统的健壮性考虑,建议对于系统中并未使用的中断,都使用一个同样的异常中断函数,用于异常进入时,做中断退出。
    段定义,表明下列代码为中断向量部分内容。
       END        ;(12)
汇编结束指令,这里需要注意的是在END之后请保留几个空格和一个回车符,否则编译会出错。
qigongwei 发表于 2007-9-14 21:32 | 显示全部楼层
word里面复制的在预览里还是好好的
怎么帖子发出去再看,格式就乱了
