定时中断
818|16
 楼主| zhaoxqi 发表于 2016-1-10 18:54 | 显示全部楼层 |阅读模式
最近入手OMAP-138,我想用DSP核实现一个定时中断功能。参考SEED提供的开发包,写了一个测试代码。
发现,将TIMER0配置成32位,非关联模式后,TIMER3:4运行正常,但是TIMER1:2不运行。
dengdc 发表于 2016-1-10 18:57 | 显示全部楼层
代码设置代码看看
 楼主| zhaoxqi 发表于 2016-1-10 19:05 | 显示全部楼层
 楼主| zhaoxqi 发表于 2016-1-10 19:09 | 显示全部楼层
uint32_t USTIMER0_init(void)
     // configure timer 0 for free run.
     // 32-bit unchained mode, timer3:4 /12 prescaler.
    // enable muxed pins as gpio outputs and disable all related interrupts.
     // would need to also setup the pinmux register to select the gpio
     // function of these pins in order to use as gpio.
//   TMR0->GPINT_GPEN = GPENO12 | GPENI12;
//  TMR0->GPDATA_GPDIR = GPDIRO12 | GPDIRI12;
   // stop and reset timer.
    TMR0->TGCR = 0x00000000;
    TMR0->TCR = 0x00000000;
   // disable interrupts and set emulation to free run.
    TMR0->INTCTLSTAT = 0;
    SETBIT(TMR0->EMUMGT, SOFT | FREE);
   // config timer0 in 32-bit unchained mode.
    // remove timer0 - 3:4 from reset.
    SETBIT(TMR0->TGCR, PRESCALER(TIMER_DIV - 1) | TIMMODE_32BIT_UNCHAINED /*| TIM34RS*/ );
   // init timer0 - 1:2 period....use full range of counter.
    TMR0->TIM34 = 0x00000000;
    TMR0->PRD34 = 0x00000000;
// TMR0->PRD34 = 0xFFFFFFFF;
   TMR0->TIM12 = 0x00000000;
    TMR0->PRD12 = 0x00000000;
    // start timer0 - 3:4.
// SETBIT(TMR0->TCR, ENAMODE34_CONT);
   return (ERR_NO_ERROR);
void USTIMER0_delay(uint32_t in_delay)
     uint32_t regData;
#if 0
    // stop the timer, clear int stat, and clear timer value.
     CLRBIT(TMR0->TGCR, TIM34RS);
     SETBIT(TMR0->INTCTLSTAT, PRDINTSTAT34);
    // setup compare time.
    TMR0->PRD34 = TICKS_PER_US * in_delay;
    // start timer1 - 3:4 to run once up to the period.
     SETBIT(TMR0->TCR, ENAMODE34_ONETIME);
     SETBIT(TMR0->TGCR, TIM34RS);
    // wait for the signal that we have hit our period.
     while (!CHKBIT(TMR0->INTCTLSTAT, PRDINTSTAT34));
#else
     CLRBIT(TMR0->TGCR, TIM12RS);
     SETBIT(TMR0->INTCTLSTAT, PRDINTSTAT12);
     TMR0->PRD12 = TICKS_PER_US * in_delay;
    CLRBIT(TMR0->TCR,CLKSRC12);
     CLRBIT(TMR0->TCR,TIEN12);
     SETBIT(TMR0->TCR, ENAMODE12_ONETIME);
     SETBIT(TMR0->TGCR, TIM12RS);
     while (!CHKBIT(TMR0->INTCTLSTAT, PRDINTSTAT12));
#endif
主函数
main()
     USTIMER0_init();
     printf("the timer0 test start\n" );
     USTIMER0_delay(100);
     printf("the timer0 test end\n");
jiahy 发表于 2016-1-10 19:12 | 显示全部楼层
如果使用timer3:4来实现,这个测试函数就可以走完吗?
 楼主| zhaoxqi 发表于 2016-1-10 19:15 | 显示全部楼层
可以走完
jiahy 发表于 2016-1-10 19:17 | 显示全部楼层
用timer1:2来做呢
 楼主| zhaoxqi 发表于 2016-1-10 20:41 | 显示全部楼层
 楼主| zhaoxqi 发表于 2016-1-10 20:45 | 显示全部楼层
根据TI,定时器的 资料上配置了内部时钟源,禁止了内部时钟源开关就是始终不往下运行!
wyjie 发表于 2016-1-10 20:48 | 显示全部楼层
还需要配置什么吧
jlyuan 发表于 2016-1-10 20:52 | 显示全部楼层
检查Linux启动了没有
yszong 发表于 2016-1-10 20:54 | 显示全部楼层
timer1:2中的一个被Linux当系统定时器用了
yszong 发表于 2016-1-10 20:57 | 显示全部楼层
另一个在内核中好像是被Ban了。
午夜粪车 发表于 2016-1-10 21:00 | 显示全部楼层
把这个定时器设置为DSP使用
 楼主| zhaoxqi 发表于 2016-1-10 21:02 | 显示全部楼层
好了!
 楼主| zhaoxqi 发表于 2016-1-10 21:04 | 显示全部楼层
我的DSP端软件是裸跑的!
结贴了
