[AVR单片机] 关于IAR下用MKII的仿真出错的问题
2287|0
 楼主| hjhwsk 发表于 2007-11-5 16:20 | 显示全部楼层 |阅读模式
在IAR下用MKII仿真时,下载完程序后即进入全速运行,停止运行后,系统提示
Mon Nov 05 16:00:48 2007: The stack 'CStack' is filled to 100% (512 bytes used out of 512). The warning threshold is set to 90%.
Mon Nov 05 16:00:48 2007: The stack 'RStack' is filled to 100% (64 bytes used out of 64). The warning threshold is set to 90%.
修改了CStack,RStack的大小后,情况没有改变,请问是这什么原因.知道的帮忙解决一下.先谢了.
