向高手求救,keil编译问题
7897|2
 楼主| ajian4040214 发表于 2009-4-15 21:01 | 显示全部楼层 |阅读模式
在keil中编译时老是编译不了,显示下面的东西,不知道什么问题????<br />Build&nbsp;target&nbsp;'Target&nbsp;1'<br />assembling&nbsp;STARTUP.A51...<br />assembling&nbsp;Text2.ASM...<br />linking...<br />***&nbsp;WARNING&nbsp;L30:&nbsp;MEMORY&nbsp;SPACE&nbsp;OVERLAP<br />&nbsp;&nbsp;&nbsp;&nbsp;FROM:&nbsp;&nbsp;&nbsp;&nbsp;C:000000H&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;TO:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;C:000003H&nbsp;&nbsp;&nbsp;<br />***&nbsp;ERROR&nbsp;L127:&nbsp;UNRESOLVED&nbsp;EXTERNAL&nbsp;SYMBOL<br />&nbsp;&nbsp;&nbsp;&nbsp;SYMBOL:&nbsp;&nbsp;?C_START<br />&nbsp;&nbsp;&nbsp;&nbsp;MODULE:&nbsp;&nbsp;STARTUP.obj&nbsp;(?C_STARTUP)<br />***&nbsp;ERROR&nbsp;L128:&nbsp;REFERENCE&nbsp;MADE&nbsp;TO&nbsp;UNRESOLVED&nbsp;EXTERNAL<br />&nbsp;&nbsp;&nbsp;&nbsp;SYMBOL:&nbsp;&nbsp;?C_START<br />&nbsp;&nbsp;&nbsp;&nbsp;MODULE:&nbsp;&nbsp;STARTUP.obj&nbsp;(?C_STARTUP)<br />&nbsp;&nbsp;&nbsp;&nbsp;ADDRESS:&nbsp;1000017H<br />Program&nbsp;Size:&nbsp;data=9.0&nbsp;xdata=0&nbsp;const=0&nbsp;code=28<br />Target&nbsp;not&nbsp;created<br /><br />还弹出如图的框:<br />弄了很多次都是这样,用C程序好像不会这样,而汇编就会,是什么问题啊??<br />
hnustlxj 发表于 2009-4-17 13:22 | 显示全部楼层
不要添加“STARTUP.A51”就不会出问题。
不要添加“STARTUP.A51”就不会出问题。<br />
 楼主| ajian4040214 发表于 2009-4-17 17:37 | 显示全部楼层
好的,谢谢
