ULINK 下载出错了? 谁给看看怎么回事??
3596|5
 楼主| 小小电子 发表于 2007-11-18 11:52 | 显示全部楼层 |阅读模式
一直提示:can't&nbsp;load&nbsp;flash&nbsp;programming&nbsp;algorithm&nbsp;!&nbsp;.<br /><br />不知道谁有遇到这种情况??&nbsp;&nbsp;&nbsp;如何解决?&nbsp;我试了很多种方法都不行。<br /><br />以前一直都用的好好的??&nbsp;&nbsp;&nbsp;&nbsp;难道是我ULINK坏了?还是芯片坏了?<br />&nbsp;<br />
computer00 发表于 2007-11-18 13:18 | 显示全部楼层
没有选择合适的芯片吧?还有要需要一个初始化文件的
 楼主| 小小电子 发表于 2007-11-18 13:42 | 显示全部楼层
应该不会是这个问题
因为我以前就用这个工程一直都仿真的好好的&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;今天在仿真运行的时候出错。&nbsp;&nbsp;我关闭重新下载仿真他就提示这个了。<br />
 楼主| 小小电子 发表于 2007-11-18 17:26 | 显示全部楼层
偶尔有一两次下载 也出现下面错误
Full&nbsp;Chip&nbsp;Erase&nbsp;Done.<br />Programming&nbsp;Done.<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100000H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=18H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100001H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=F0H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100002H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=9FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100003H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100004H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=18H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100005H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=F0H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100006H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=9FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100007H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100008H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=18H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100009H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=F0H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010000AH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=9FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010000BH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010000CH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=18H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010000DH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=F0H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010000EH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=9FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010000FH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100010H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=18H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100011H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=F0H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100012H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=9FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100013H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100014H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100015H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100016H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=A0H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100017H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E1H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100018H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=20H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010001AH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=1FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010001BH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010001CH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=20H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010001EH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=1FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010001FH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100020H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=40H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100021H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100022H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=10H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100023H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100024H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=90H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100025H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=07H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100026H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=10H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100027H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100028H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=8CH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100029H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=07H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010002AH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=10H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010002BH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010002CH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=88H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010002DH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=07H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010002EH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=10H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010002FH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100030H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=84H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100031H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=07H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100032H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=10H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100033H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100034H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100035H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100036H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100037H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100038H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100039H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010003AH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010003BH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010003CH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010003DH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010003EH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010003FH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100040H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=B4H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100041H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100042H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=9FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100043H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100044H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=B4H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100045H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=10H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100046H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=9FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100047H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100048H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=08H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100049H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=10H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010004AH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=80H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010004BH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010004DH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010004EH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E0H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010004FH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E3H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100050H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=ACH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100051H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=10H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100052H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=9FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100053H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100054H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=60H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100055H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=10H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100056H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=80H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100057H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100058H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=A8H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100059H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010005AH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=9FH)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010005BH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010005CH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=02H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010005DH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=19H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010005EH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=A0H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;0010005FH&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E3H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100060H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=04H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100061H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=10H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100062H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=80H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100063H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=E5H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100064H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=A0H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100065H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=00H)&nbsp;!<br />Contents&nbsp;missmatch&nbsp;at:&nbsp;00100066H&nbsp;&nbsp;(Flash=FFH&nbsp;&nbsp;Required=9FH)&nbsp;!<br />Too&nbsp;many&nbsp;errors&nbsp;to&nbsp;display&nbsp;!
boy123 发表于 2007-11-18 18:29 | 显示全部楼层
写不进去?
 楼主| 小小电子 发表于 2007-11-18 19:39 | 显示全部楼层
也不一定
有时候可以写进去&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;有时候又不行<br /><br />不过写进去后&nbsp;&nbsp;&nbsp;一仿真就出错了&nbsp;&nbsp;&nbsp;&nbsp;然后就老长一段时间写不进去
