求助:CCS3.1 F2812的simulator 时,出错
3771|2
freeman05|  楼主 | 2007-12-7 13:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问,我用CCS3.1 F2812的simulator 时,错现如下问题:
   DevEmuRegs.M0RAMDFT = 0x0300;
   DevEmuRegs.M1RAMDFT = 0x0300;
   DevEmuRegs.L0RAMDFT = 0x0300;
   DevEmuRegs.L1RAMDFT = 0x0300;
   DevEmuRegs.H0RAMDFT = 0x0300;
 当运行到上面几句时,提示如下错问:
Can't Run Target CPU: Can't write to data memory 0x950, check memory config [-2184]
Can't Run Target CPU: Can't write to data memory 0x951, check memory config [-2184]
Can't Run Target CPU: Can't write to data memory 0x952, check memory config [-2184]
Can't Run Target CPU: Can't write to data memory 0x953, check memory config [-2184]
Can't Run Target CPU: Can't write to data memory 0x954, check memory config [-2184]
cmd文件中
MEMORY
PAGE 1 :
   /* Peripheral Frame 0:   */
   DEV_EMU    : origin = 0x000880, length = 0x000180
SECTIONS
   DevEmuRegsFile    : > DEV_EMU,    PAGE = 1
请问这是什么原因啊
wqw_410| | 2007-12-10 15:50 | 只看该作者
看一下memory map
看一下memory map,看你的DEV_EMU在不在有效区域内
ssliudh1226| | 2014-4-24 17:01 | 只看该作者
请问楼主你的问题解决了吗?我也遇到同样问题,不知道该怎么办了
