os似乎挺火爆.想自己编译一个windows内核吗?
4369|3
 楼主| high 发表于 2007-12-10 12:06 | 显示全部楼层 |阅读模式
想高台坐论windows,linux,ce,ucos....你好我好,至少了解才能比较吧?<br />linux和ucos的容易获得,<br />windows的内核代码和编译环境,我给出一个线索<br />下载关键字:windows&nbsp;research&nbsp;kernel.<br /><br /><br /><br /><br />WRK&nbsp;v1.2<br /><br />The&nbsp;Windows&nbsp;Research&nbsp;Kernel&nbsp;v1.2&nbsp;contains&nbsp;the&nbsp;sources&nbsp;for&nbsp;the&nbsp;core&nbsp;of<br />the&nbsp;Windows&nbsp;(NTOS)&nbsp;kernel&nbsp;and&nbsp;a&nbsp;build&nbsp;environment&nbsp;for&nbsp;a&nbsp;kernel&nbsp;that&nbsp;will&nbsp;run&nbsp;on<br />&nbsp;&nbsp;&nbsp;&nbsp;x86&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;(Windows&nbsp;Server&nbsp;2003&nbsp;Service&nbsp;Pack&nbsp;1)&nbsp;and<br />&nbsp;&nbsp;&nbsp;&nbsp;AMD64&nbsp;&nbsp;&nbsp;(Windows&nbsp;XP&nbsp;x64&nbsp;Professional)<br />A&nbsp;future&nbsp;version&nbsp;may&nbsp;also&nbsp;support&nbsp;booting&nbsp;WRK&nbsp;kernels&nbsp;on&nbsp;Windows&nbsp;XP&nbsp;x86&nbsp;systems,<br />but&nbsp;the&nbsp;current&nbsp;kernels&nbsp;will&nbsp;fail&nbsp;to&nbsp;boot&nbsp;due&nbsp;to&nbsp;differences&nbsp;in&nbsp;some&nbsp;shared&nbsp;structures.<br /><br />The&nbsp;NTOS&nbsp;kernel&nbsp;implements&nbsp;the&nbsp;basic&nbsp;OS&nbsp;functions<br />for&nbsp;processes,&nbsp;threads,&nbsp;virtual&nbsp;memory&nbsp;and&nbsp;cache&nbsp;managers,&nbsp;I/O&nbsp;management,<br />the&nbsp;registry,&nbsp;executive&nbsp;functions&nbsp;such&nbsp;as&nbsp;the&nbsp;kernel&nbsp;heap&nbsp;and&nbsp;synchronization,<br />the&nbsp;object&nbsp;manager,&nbsp;the&nbsp;local&nbsp;procedure&nbsp;call&nbsp;mechanism,&nbsp;the&nbsp;security&nbsp;reference<br />monitor,&nbsp;low-level&nbsp;CPU&nbsp;management&nbsp;(thread&nbsp;scheduling,&nbsp;Asynchronous&nbsp;and&nbsp;Deferred<br />Procedure&nbsp;calls,&nbsp;interrupt/trap&nbsp;handling,&nbsp;exceptions),&nbsp;etc.<br /><br />The&nbsp;NT&nbsp;Hardware&nbsp;Abstraction&nbsp;Layer,&nbsp;file&nbsp;systems,&nbsp;network&nbsp;stacks,&nbsp;and&nbsp;device<br />drivers&nbsp;are&nbsp;implemented&nbsp;separately&nbsp;from&nbsp;NTOS&nbsp;and&nbsp;loaded&nbsp;into&nbsp;kernel&nbsp;mode<br />as&nbsp;dynamic&nbsp;libraries.&nbsp;&nbsp;Sources&nbsp;for&nbsp;these&nbsp;dynamic&nbsp;components&nbsp;are&nbsp;not&nbsp;included<br />in&nbsp;the&nbsp;WRK,&nbsp;but&nbsp;some&nbsp;are&nbsp;available&nbsp;in&nbsp;various&nbsp;development&nbsp;kits&nbsp;published<br />by&nbsp;Microsoft,&nbsp;such&nbsp;as&nbsp;the&nbsp;Installable&nbsp;File&nbsp;System&nbsp;(IFS)&nbsp;Kit&nbsp;and&nbsp;the<br />Windows&nbsp;Driver&nbsp;Development&nbsp;Kit&nbsp;(DDK).<br /><br />WRK&nbsp;v1.2&nbsp;includes&nbsp;most&nbsp;of&nbsp;the&nbsp;NTOS&nbsp;kernel&nbsp;sources&nbsp;from&nbsp;the&nbsp;latest&nbsp;released<br />version&nbsp;of&nbsp;Windows,&nbsp;which&nbsp;supports&nbsp;the&nbsp;AMD64&nbsp;architecture&nbsp;on&nbsp;the&nbsp;Desktop.<br />The&nbsp;kernel&nbsp;sources&nbsp;excluded&nbsp;from&nbsp;the&nbsp;kit&nbsp;are&nbsp;primarily&nbsp;in&nbsp;the&nbsp;areas&nbsp;of<br />plug-and-play,&nbsp;power&nbsp;management,&nbsp;the&nbsp;device&nbsp;verifier,&nbsp;kernel&nbsp;debugger<br />interface,&nbsp;and&nbsp;virtual&nbsp;dos&nbsp;machine.&nbsp;&nbsp;The&nbsp;primary&nbsp;modifications&nbsp;to&nbsp;WRK<br />from&nbsp;the&nbsp;released&nbsp;kernel&nbsp;are&nbsp;related&nbsp;to&nbsp;cleanup&nbsp;and&nbsp;removal&nbsp;of&nbsp;server<br />support,&nbsp;such&nbsp;as&nbsp;code&nbsp;related&nbsp;to&nbsp;the&nbsp;Intel&nbsp;IA64.<br /><br />***<br /><br />Organization&nbsp;of&nbsp;the&nbsp;WRK&nbsp;sources<br /><br />The&nbsp;file&nbsp;License.txt&nbsp;contains&nbsp;the&nbsp;license&nbsp;covering&nbsp;use&nbsp;of&nbsp;the&nbsp;WRK.<br /><br />The&nbsp;public\&nbsp;directory&nbsp;contains&nbsp;a&nbsp;number&nbsp;of&nbsp;include&nbsp;files&nbsp;shared&nbsp;among&nbsp;system<br />components.&nbsp;&nbsp;base\ntos\&nbsp;contains&nbsp;the&nbsp;NTOS&nbsp;sources.<br /><br />The&nbsp;primary&nbsp;NTOS&nbsp;source&nbsp;components&nbsp;included&nbsp;in&nbsp;the&nbsp;WRK&nbsp;are&nbsp;organized&nbsp;as&nbsp;follows:<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;cache\&nbsp;&nbsp;-&nbsp;cache&nbsp;manager<br />&nbsp;&nbsp;&nbsp;&nbsp;config\&nbsp;-&nbsp;registry&nbsp;implementation<br />&nbsp;&nbsp;&nbsp;&nbsp;dbgk\&nbsp;&nbsp;&nbsp;-&nbsp;user-mode&nbsp;debugger&nbsp;support<br />&nbsp;&nbsp;&nbsp;&nbsp;ex\&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;executive&nbsp;functions&nbsp;(kernel&nbsp;heap,&nbsp;synchronization,&nbsp;time)<br />&nbsp;&nbsp;&nbsp;&nbsp;fsrtl\&nbsp;&nbsp;-&nbsp;file&nbsp;system&nbsp;run-time&nbsp;support<br />&nbsp;&nbsp;&nbsp;&nbsp;io\&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;I/O&nbsp;manager<br />&nbsp;&nbsp;&nbsp;&nbsp;ke\&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;scheduler,&nbsp;CPU&nbsp;management,&nbsp;low-level&nbsp;synchronization<br />&nbsp;&nbsp;&nbsp;&nbsp;lpc\&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;local&nbsp;procedure&nbsp;call&nbsp;implementation<br />&nbsp;&nbsp;&nbsp;&nbsp;mm\&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;virtual&nbsp;memory&nbsp;manager<br />&nbsp;&nbsp;&nbsp;&nbsp;ob\&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;kernel&nbsp;object&nbsp;manager<br />&nbsp;&nbsp;&nbsp;&nbsp;ps\&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;process/thread&nbsp;support<br />&nbsp;&nbsp;&nbsp;&nbsp;se\&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;security&nbsp;functions<br />&nbsp;&nbsp;&nbsp;&nbsp;wmi\&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;Windows&nbsp;Management&nbsp;Instrumentation<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;inc\&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;NTOS-only&nbsp;include&nbsp;files<br />&nbsp;&nbsp;&nbsp;&nbsp;rtl\&nbsp;&nbsp;&nbsp;&nbsp;-&nbsp;kernel&nbsp;run-time&nbsp;support<br />&nbsp;&nbsp;&nbsp;&nbsp;init\&nbsp;&nbsp;&nbsp;-&nbsp;kernel&nbsp;startup<br /><br />***<br /><br />Two&nbsp;of&nbsp;the&nbsp;best&nbsp;existing&nbsp;sources&nbsp;for&nbsp;documentation&nbsp;of&nbsp;the&nbsp;NTOS&nbsp;kernel&nbsp;are<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Microsoft&nbsp;Windows&nbsp;Internals,&nbsp;4th&nbsp;Ed&nbsp;2005,&nbsp;Mark&nbsp;Russinovich&nbsp;and&nbsp;David&nbsp;Solomon<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;The&nbsp;Windows&nbsp;Curriculum&nbsp;Resource&nbsp;Kit&nbsp;(CRK)<br />&nbsp;&nbsp;&nbsp;&nbsp;http://www.msdnaa.net/curriculum/pfv.aspx?ID=6191<br /><br />Additional&nbsp;information&nbsp;about&nbsp;using&nbsp;Windows&nbsp;for&nbsp;teaching&nbsp;and&nbsp;research<br />in&nbsp;operating&nbsp;systems&nbsp;is&nbsp;available&nbsp;at<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;http://www.microsoft.com/resources/sharedsource/Licensing/WindowsAcademic.mspx<br /><br />Specific&nbsp;questions&nbsp;about&nbsp;use&nbsp;of&nbsp;the&nbsp;WRK,&nbsp;CRK,&nbsp;or&nbsp;ProjectOZ&nbsp;can&nbsp;be&nbsp;directed&nbsp;to<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;compsci@microsoft.com<br /><br />Questions&nbsp;about&nbsp;the&nbsp;kernel&nbsp;sources&nbsp;(or&nbsp;CRK&nbsp;or&nbsp;ProjectOZ)&nbsp;can&nbsp;be&nbsp;directed&nbsp;to<br />the&nbsp;MSDN&nbsp;academic&nbsp;forum&nbsp;groups&nbsp;(http://forums.microsoft.com/WindowsAcademic)<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Curriculum<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;A&nbsp;discussion&nbsp;forum&nbsp;regarding&nbsp;development&nbsp;of&nbsp;operating&nbsp;systems&nbsp;curriculum<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;based&nbsp;on&nbsp;the&nbsp;Windows&nbsp;kernel,&nbsp;including&nbsp;use&nbsp;of&nbsp;the&nbsp;Windows&nbsp;Curriculum<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Resource&nbsp;Kit,&nbsp;the&nbsp;Windows&nbsp;Research&nbsp;Kernel,&nbsp;and&nbsp;ProjectOZ.<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Kernel&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Questions&nbsp;&&nbsp;Answers&nbsp;regarding&nbsp;the&nbsp;Windows&nbsp;Research&nbsp;Kernel,<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;its&nbsp;architecture,&nbsp;source&nbsp;code&nbsp;and&nbsp;use&nbsp;in&nbsp;teaching&nbsp;and&nbsp;research.<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;ProjectOZ<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Questions&nbsp;&&nbsp;Answers&nbsp;regarding&nbsp;use&nbsp;of&nbsp;ProjectOZ&nbsp;for&nbsp;teaching&nbsp;and<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;research&nbsp;of&nbsp;operating&nbsp;systems&nbsp;topics.<br /><br />***<br /><br />Building/deploying&nbsp;a&nbsp;WRK&nbsp;kernel&nbsp;for&nbsp;x86&nbsp;[or&nbsp;amd64]<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;0.&nbsp;Copy&nbsp;the&nbsp;WRK&nbsp;into&nbsp;a&nbsp;directory,&nbsp;say&nbsp;%wrk%.&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;1.&nbsp;set&nbsp;arch=x86&nbsp;[or&nbsp;amd64]<br />&nbsp;&nbsp;&nbsp;&nbsp;2.&nbsp;path&nbsp;%wrk%\tools\%arch%;%path%<br />&nbsp;&nbsp;&nbsp;&nbsp;3.&nbsp;cd&nbsp;%wrk%\base\ntos<br />&nbsp;&nbsp;&nbsp;&nbsp;4.&nbsp;nmake&nbsp;-no**&nbsp;%arch%=<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;will&nbsp;produce&nbsp;kernel&nbsp;files&nbsp;in&nbsp;BUILD\EXE\%arch%<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;[wrkx86.*&nbsp;or&nbsp;wrkx64.*]<br />&nbsp;&nbsp;&nbsp;&nbsp;5.&nbsp;copy&nbsp;the&nbsp;kernel&nbsp;to&nbsp;%SystemRoot%\system32\<br />&nbsp;&nbsp;&nbsp;&nbsp;6.&nbsp;if&nbsp;x86,&nbsp;find&nbsp;the&nbsp;Multi-processor&nbsp;version&nbsp;of&nbsp;hal.dll&nbsp;[see&nbsp;below]<br />&nbsp;&nbsp;&nbsp;&nbsp;7.&nbsp;add&nbsp;a&nbsp;line&nbsp;to&nbsp;C:\boot.ini&nbsp;of&nbsp;the&nbsp;target&nbsp;system<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;to&nbsp;boot&nbsp;this&nbsp;kernel&nbsp;and&nbsp;the&nbsp;MP&nbsp;hal&nbsp;[see&nbsp;below]<br />&nbsp;&nbsp;&nbsp;&nbsp;8.&nbsp;reboot&nbsp;and&nbsp;select&nbsp;the&nbsp;boot&nbsp;option&nbsp;for&nbsp;the&nbsp;new&nbsp;kernel<br />&nbsp;&nbsp;&nbsp;&nbsp;9.&nbsp;you&nbsp;will&nbsp;boot&nbsp;up&nbsp;on&nbsp;a&nbsp;kernel&nbsp;you&nbsp;built/linked&nbsp;yourself!<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;[always&nbsp;keep&nbsp;the&nbsp;original&nbsp;boot.ini&nbsp;line&nbsp;and&nbsp;kernel/hal&nbsp;available&nbsp;so&nbsp;you<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;can&nbsp;still&nbsp;boot&nbsp;your&nbsp;system&nbsp;if&nbsp;something&nbsp;fails&nbsp;with&nbsp;your&nbsp;WRK&nbsp;kernel&nbsp;modifications]<br />&nbsp;&nbsp;&nbsp;&nbsp;10.&nbsp;set&nbsp;up&nbsp;a&nbsp;debugger&nbsp;[see&nbsp;below]<br /><br />Multi-processor&nbsp;hal&nbsp;(x86&nbsp;only,&nbsp;amd64&nbsp;hals&nbsp;are&nbsp;all&nbsp;MP)<br />&nbsp;&nbsp;&nbsp;&nbsp;All&nbsp;hals&nbsp;are&nbsp;renamed&nbsp;hal.dll,&nbsp;so&nbsp;you&nbsp;have&nbsp;to&nbsp;use&nbsp;the&nbsp;link&nbsp;command&nbsp;to<br />&nbsp;&nbsp;&nbsp;&nbsp;see&nbsp;what&nbsp;type&nbsp;of&nbsp;hal&nbsp;hal.dll&nbsp;really&nbsp;is:<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;link&nbsp;-dump&nbsp;-all&nbsp;hal.dll&nbsp;|&nbsp;findstr&nbsp;pdb<br />&nbsp;&nbsp;&nbsp;&nbsp;The&nbsp;MP&nbsp;hals&nbsp;have&nbsp;an&nbsp;'m'&nbsp;in&nbsp;the&nbsp;native&nbsp;name&nbsp;of&nbsp;the&nbsp;hal,&nbsp;e.g.&nbsp;halmacpi.dll<br />&nbsp;&nbsp;&nbsp;&nbsp;You&nbsp;may&nbsp;already&nbsp;have&nbsp;an&nbsp;MP&nbsp;hal&nbsp;installed&nbsp;on&nbsp;UP&nbsp;systems,&nbsp;due&nbsp;to&nbsp;hyperthreading.<br />&nbsp;&nbsp;&nbsp;&nbsp;If&nbsp;the&nbsp;hal&nbsp;isn't&nbsp;MP,&nbsp;you&nbsp;need&nbsp;to&nbsp;find&nbsp;the&nbsp;MP&nbsp;hal&nbsp;that&nbsp;corresponds&nbsp;to&nbsp;the&nbsp;current&nbsp;hal<br />&nbsp;&nbsp;&nbsp;&nbsp;the&nbsp;target&nbsp;system&nbsp;does&nbsp;have,&nbsp;i.e.&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;halacpi.dll&nbsp;&nbsp;-&gt&nbsp;halacpim.dll&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;ACPI&nbsp;PIC-based&nbsp;PC&nbsp;&nbsp;[used&nbsp;by&nbsp;VirtualPC]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;halaacpi.dll&nbsp;-&gt&nbsp;halmacpi.dll&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;ACPI&nbsp;APIC-based&nbsp;PC<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;halapic.dll&nbsp;&nbsp;-&gt&nbsp;halmps.dll&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;MPS<br />&nbsp;&nbsp;&nbsp;&nbsp;Look&nbsp;in&nbsp;the&nbsp;WRK&nbsp;WS03SP1HALS\x86&nbsp;directory&nbsp;for&nbsp;the&nbsp;MP&nbsp;hal&nbsp;you&nbsp;need.<br /><br />Boot.ini<br />&nbsp;&nbsp;&nbsp;&nbsp;Edit&nbsp;boot.ini&nbsp;(you&nbsp;may&nbsp;have&nbsp;to&nbsp;use&nbsp;attrib&nbsp;-h&nbsp;-s&nbsp;-r&nbsp;first)<br />&nbsp;&nbsp;&nbsp;&nbsp;Copy&nbsp;the&nbsp;line&nbsp;for&nbsp;the&nbsp;first&nbsp;operating&nbsp;system&nbsp;listed&nbsp;to&nbsp;the&nbsp;end&nbsp;of&nbsp;the&nbsp;file&nbsp;and&nbsp;edit&nbsp;it.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;[boot&nbsp;loader]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;timeout=30<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;[operating&nbsp;systems]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;multi(0)disk(0)rdisk(0)partition(2)\WINDOWS=&quot;Windows&nbsp;Server&nbsp;2003,&nbsp;Standard&quot;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;multi(0)disk(0)rdisk(0)partition(2)\WINDOWS=&quot;test&quot;&nbsp;/kernel=wrkx86.exe&nbsp;/hal=halmacpi.dll<br />&nbsp;&nbsp;&nbsp;&nbsp;Note&nbsp;that&nbsp;the&nbsp;filenames&nbsp;must&nbsp;be&nbsp;short&nbsp;(8.3)&nbsp;names.<br />&nbsp;&nbsp;&nbsp;&nbsp;You&nbsp;can&nbsp;add&nbsp;additional&nbsp;options&nbsp;for&nbsp;debugging&nbsp;(as&nbsp;specified&nbsp;in&nbsp;the&nbsp;WinDbg/KD&nbsp;help).<br /><br />Debugging&nbsp;WRK<br />&nbsp;&nbsp;&nbsp;&nbsp;The&nbsp;WinDBG/KD&nbsp;debuggers&nbsp;will&nbsp;work&nbsp;with&nbsp;the&nbsp;WRK.&nbsp;&nbsp;The&nbsp;documentation&nbsp;is&nbsp;pretty&nbsp;thorough,&nbsp;and<br />&nbsp;&nbsp;&nbsp;&nbsp;includes&nbsp;information&nbsp;about&nbsp;how&nbsp;to&nbsp;debug&nbsp;across&nbsp;a&nbsp;serial&nbsp;port,&nbsp;locally&nbsp;(examining&nbsp;kernel&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;data&nbsp;from&nbsp;user-mode),&nbsp;and&nbsp;debugging&nbsp;kernels&nbsp;running&nbsp;on&nbsp;VirtualPC.<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;Version&nbsp;6.6.3.5&nbsp;of&nbsp;the&nbsp;WinDBG/KD&nbsp;debuggers&nbsp;is&nbsp;available&nbsp;with&nbsp;the&nbsp;Curriculum&nbsp;Resource&nbsp;Kit<br />&nbsp;&nbsp;&nbsp;&nbsp;Tools&nbsp;(&quot;CurriculumResourceKit-CRK\CRKTools\Debugging&nbsp;Tools&quot;&nbsp;directory&nbsp;on&nbsp;the&nbsp;CD).&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;The&nbsp;latest&nbsp;version&nbsp;of&nbsp;the&nbsp;Windows&nbsp;Debugging&nbsp;Tools&nbsp;can&nbsp;be&nbsp;downloaded&nbsp;from<br />&nbsp;&nbsp;&nbsp;&nbsp;http://www.microsoft.com/whdc/devtools/debugging.<br />
xwj 发表于 2007-12-10 16:52 | 显示全部楼层
呵呵,欢迎各位帅哥靓女来坐台,坐高台。
老狼 发表于 2007-12-10 23:10 | 显示全部楼层
小心,高处不胜寒呀!
靓女过来,坐我身边!
mxh0506 发表于 2007-12-19 12:35 | 显示全部楼层
不错啊~
