新手请教
2415|2
tracyf|  楼主 | 2007-12-17 22:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ov, se, AC, ck, vr
各位大哥,以下程序是一段100进制的程序,可我在用KEIL51单步仿真时,程序到LOOP:MOV 30H,#0时就停止了,但数码管亮了;稍等一下,就会出现
     CONNECTION TO TAAGET SYSTEM LOST!
Try Again:please reset your target system and selet'Try ..'
Settings:Opens a dialog where you can select the monitor...
Stop Debugging:
请各位大哥帮帮忙,看下程序是哪出了问题,怎么会出现寻个窗口,如何解决,谢谢,
acall main
    org 0bh
    acall zd
main:
    mov r6,#10
    mov 30h,#0
    mov 31h,#0
    mov tmod,#1
    mov th0,#3ch
    mov tl0,#0b0h
    setb ea
  setb et0
  setb tr0
LOOP:MOV 30H,#0
     mov r7,#0feh
loop1:mov p2,#0ffh(关断数码管)
      mov a,@r1
      mov dptr,#tab
      movc a,@a+dptr
      mov p0,a
      mov p2,r7
      inc r1
      mov a,r7
      RL a
      mov r7,a
      cjne r7,#0fbh,loop1
      sjmp loop
back:
    reti
zd:
   mov th0,#3ch
   mov tl0,#0b0h
   djnz r6,back
   mov r0,#30h
   inc @r0
   cjne @r0,#10,back
   mov 30h,#0
   inc r0
   inc @r0
   cjne @r0,#10,back
   mov 30h,#0
   mov 31h,#0
   sjmp back
tab:db 0c0h,0f9h,0a4h,0b0h,99h,92h,82h,0f8h,80h,90h,88h,83h,0c6h,0a1h,86h,8eh
   end
adming| | 2007-12-18 17:34 | 只看该作者
个人觉得不是软件问题
tracyf|  楼主 | 2007-12-18 19:53 | 只看该作者
RE
谢谢,我贴张图,请各位大哥再帮忙看看,给点意见,谢谢.C:\Documents and Settings\ANNIE\My Documents\My Pictures\2.jpg
