[ZLG-MCU] µC/TCP-IP 最新版源程序官方下载地址
7611|17
 楼主| zlgmcu 发表于 2007-12-25 21:09 | 显示全部楼层 |阅读模式
You&nbsp;can&nbsp;evaluate&nbsp;the&nbsp;&micro;C/TCP-IP&nbsp;source&nbsp;code&nbsp;for&nbsp;FREE&nbsp;for&nbsp;45&nbsp;days,&nbsp;but&nbsp;a&nbsp;license&nbsp;is&nbsp;required&nbsp;when&nbsp;&micro;C/TCP-IP&nbsp;is&nbsp;used&nbsp;commercially.&nbsp;The&nbsp;policy&nbsp;is&nbsp;as&nbsp;follows:<br /><br />&micro;C/TCP-IP&nbsp;source&nbsp;and&nbsp;object&nbsp;code&nbsp;can&nbsp;be&nbsp;used&nbsp;by&nbsp;accredited&nbsp;Colleges&nbsp;and&nbsp;Universities&nbsp;without&nbsp;requiring&nbsp;a&nbsp;license,&nbsp;as&nbsp;long&nbsp;as&nbsp;there&nbsp;is&nbsp;no&nbsp;commercial&nbsp;application&nbsp;involved.&nbsp;In&nbsp;other&nbsp;words,&nbsp;no&nbsp;licensing&nbsp;is&nbsp;required&nbsp;if&nbsp;&micro;C/TCP-IP&nbsp;is&nbsp;used&nbsp;for&nbsp;educational&nbsp;use.<br /><br />You&nbsp;need&nbsp;to&nbsp;obtain&nbsp;an&nbsp;'Executable&nbsp;Distribution&nbsp;License'&nbsp;to&nbsp;embed&nbsp;&micro;C/TCP-IP&nbsp;in&nbsp;a&nbsp;product&nbsp;that&nbsp;is&nbsp;sold&nbsp;with&nbsp;the&nbsp;intent&nbsp;to&nbsp;make&nbsp;a&nbsp;profit&nbsp;or&nbsp;if&nbsp;the&nbsp;product&nbsp;is&nbsp;not&nbsp;used&nbsp;for&nbsp;education&nbsp;or&nbsp;'peaceful'&nbsp;research.<br /><br />To&nbsp;Obtain&nbsp;the&nbsp;latest&nbsp;&micro;C/TCP-IP&nbsp;source&nbsp;code<br /><br />1.)&nbsp;Register&nbsp;to&nbsp;the&nbsp;Micrium&nbsp;website.&nbsp;If&nbsp;you&nbsp;don't&nbsp;already&nbsp;have&nbsp;an&nbsp;account,&nbsp;you&nbsp;will&nbsp;be&nbsp;asked&nbsp;to&nbsp;create&nbsp;one&nbsp;by&nbsp;clicking&nbsp;on&nbsp;the&nbsp;download&nbsp;icon.&nbsp;<br /><br />2.)&nbsp;This&nbsp;is&nbsp;the&nbsp;only&nbsp;web&nbsp;site&nbsp;approved&nbsp;by&nbsp;Micrium&nbsp;to&nbsp;download&nbsp;&micro;C/TCP-IP&nbsp;source&nbsp;code.&nbsp;<br /><br />3.)&nbsp;Note&nbsp;that&nbsp;support&nbsp;will&nbsp;only&nbsp;be&nbsp;provided&nbsp;to&nbsp;Licensees&nbsp;under&nbsp;maintenance.&nbsp;<br /><br />4.)&nbsp;Contact&nbsp;us&nbsp;for&nbsp;licensing&nbsp;information.&nbsp;<br /><br /><br /><br />http://www.micrium.com/products/tcp-ip/tcp-ip_download.html
123654789 发表于 2007-12-25 21:11 | 显示全部楼层
麻烦 要注册
 楼主| zlgmcu 发表于 2007-12-25 21:13 | 显示全部楼层
Luminary以太网的例子,及移植代码
http://www.micrium.com/php/download.php?file=Micrium-LuminaryMicro-uCOS-II-TCPIP-EK-LM3S6965.exe
 楼主| zlgmcu 发表于 2007-12-25 21:14 | 显示全部楼层
注册一下,小意思啦。。。
别人可是商业化软件
 楼主| zlgmcu 发表于 2007-12-25 21:18 | 显示全部楼层
有支持Keil 平台的,也有基于IAR平台的
123654789 发表于 2007-12-25 21:21 | 显示全部楼层
还有问题啊 用途受到限制啊
&micro;C/TCP-IP&nbsp;source&nbsp;and&nbsp;object&nbsp;code&nbsp;can&nbsp;be&nbsp;used&nbsp;by&nbsp;accredited&nbsp;Colleges&nbsp;and&nbsp;Universities&nbsp;without&nbsp;requiring&nbsp;a&nbsp;license,&nbsp;<br /><br />as&nbsp;long&nbsp;as&nbsp;there&nbsp;is&nbsp;no&nbsp;commercial&nbsp;application&nbsp;involved.&nbsp;<br />只要不涉及商业应用<br /><br />In&nbsp;other&nbsp;words,&nbsp;<br />换句话说<br />no&nbsp;licensing&nbsp;is&nbsp;required&nbsp;<br />不用许可证<br />if&nbsp;&micro;C/TCP-IP&nbsp;is&nbsp;used&nbsp;for&nbsp;educational&nbsp;use.<br />如果用在教育用途
平常人 发表于 2007-12-25 21:21 | 显示全部楼层
How do you ensure that commercial user pays?
How&nbsp;many&nbsp;users&nbsp;pay&nbsp;it&nbsp;in&nbsp;China?<br /><br />这是否意味着鼓励不付钱?在中国有多少用户能够支付这样的版权费?
123654789 发表于 2007-12-25 21:22 | 显示全部楼层
no one will pay it
mohanwei 发表于 2007-12-25 21:24 | 显示全部楼层
^_^
 楼主| zlgmcu 发表于 2007-12-25 21:32 | 显示全部楼层
Luminary以太网关于uC/TCP_IP的应用文档
http://www.micrium.com/downloads/appnotes/AN-3965.pdf
 楼主| zlgmcu 发表于 2007-12-25 21:43 | 显示全部楼层
还有最新版的uC/OS-II的源代码,但是,我们建议用户使用2.52版的源代码。
zusen 发表于 2007-12-26 11:10 | 显示全部楼层
注册了,下载了,研究研究
zusen 发表于 2007-12-26 11:30 | 显示全部楼层
不知有没有公开这个板子的原理图???
693212523 发表于 2007-12-26 18:50 | 显示全部楼层
网上有的
luminary上有的
haoxchao 发表于 2011-2-14 11:59 | 显示全部楼层
黑发尤物 发表于 2011-2-15 17:26 | 显示全部楼层
看看去
huanan_ 发表于 2011-6-28 16:50 | 显示全部楼层
有人用 µC/TCP-IP 做产品的吗?
huzixian 发表于 2011-6-29 22:24 | 显示全部楼层
看看去
