帮忙看一下程序是对是错
2566|4
 楼主| 120232604 发表于 2007-12-27 10:52 | 显示全部楼层 |阅读模式
TE, LDO, ck, ST, TI
这是单片机控制步进电机正反转的程序,帮忙看一下程序是对是错
START:do;
$INCLUDE(REG51.DCL)
DECLARE (addrl,n,I,j,ok,ds) byte; /*定义变量*/
declare l(5) byte;
declare (dat,data) byte at (30h);
declare delay word;
DECLARE ACO(11) BYTE CONSTANT (05h,9fh,23h,0bh,99h,49h,/*定义LED段码表*/
  41h,1fh,01h,09h,00h);
declare si literally 'p21',sck literally 'p20';  /*X25045囗线定义*/
declare so literally 'p22',cs literally 'p23';
dog:procedure;  /* 初始化看门狗x25045 */
 cs=1;
 call time(1);
 cs=0;
 call time(1);
 cs=1;
end dog;
run:procedure;  /*步进电机运行脉冲输出程序*/
  if ok=1 then
  call dog;
  do;
    p14=0;
     call time(1);
    p14=1;
     call time(1);
  end;
end run;
DISPLAYROCEDURE(L0,L10); /*显示子程序*/
DECLARE (L0,L10) BYTE; /*定义显示二位*/
n=L10;
  n=aco(n);           /*十位数BCD码译成段码*/
  sbuf=n;             /*十位数送164显示*/
  do while ti=0;      /*等待发送结束*/
     call dog;        /*看门狗定时器复位*/
  end;
n=L0;
   n=aco(n);
   sbuf=n;           /*个位数送164显示*/
   do while ti=0;
    call dog;
   end;
end display;
outbyt:  procedure(da);       /*向看门狗存储器写入一字节*/
declare (i,da) byte;
j=da;                 /*将要写入的字节赋给临时变量J */
do i=0 to 7;          /*左移8位,送到口线si */
   sck=0;
   j=scl(j,1);
   si=cy;
   sck=1;            /*每移一位数据,跟一个时钟信号*/
end;
end outbyt;
inbyt:  procedure;   /* 从看门狗存储器读出一字节 */
declare (i,di) byte;
j=0;
 do i=0 to 7;
   sck=1;
   sck=0;
   cy=so;
   j=scl(j,1);  /*从看门狗存储器读出一字节送入临时变量j*/
 end;
 dat=j;
end inbyt;
wrenable: procedure;   /* 置看门狗写使能*/
sck=0;
cs=0;
;  /* write enable command */
call outbyt(06h); /* x25045 写使能指令06h */
cs=1;
sck=0;
end wrenable;
wrdisable: procedure;  /* 置看门狗写禁止 */
 sck=0;
 cs=0;
 ; /* write disable command */
 call outbyt(04h);
 sck=0;
 cs=1;
end wrdisable;
wrregister: procedure;   /* 写状态寄存器 */
 sck=0;
 cs=0;
 dat=01h;      /* write register command */
 call outbyt(dat);
 ;     /* 00h--1.4S, 20h--200MS, 10h--600MS, 30h--disable Wdog */
 call outbyt(00h); /* 设定看门狗定时时间 */
 sck=0;
 cs=1;
 call time(200); /* wait to complete writting cycle */
end wrregister;
rdregister:procedure;  /*  读看门狗状态寄存器 */
 sck=0;
 cs=0;
 ;   /* register read command */
 call outbyt(05h);
 call inbyt; /* status register read in <DAT> */
 sck=0;
 cs=1;
end rdregister;
wbyte:procedure;   /*  看门狗存储器字节写入子程序 */
  declare comm byte;
  sck=0;
  cs=0;
  comm=02h;  /*  写指令 02h */
  call outbyt(comm);
  call outbyt(addrl);
  call outbyt(dat);  /*  send one byte data to X25043 */
  cs=1;
  sck=0;
  call time(150);
end wbyte;
rbyte:procedure;  /*看门狗存储器字节读出子程序  */
  declare comm byte;
  sck=0;
  cs=0;
  comm=03h;     /* read command */
  call outbyt(comm);
  call outbyt(addrl);
  call inbyt;   /* read one byte to <DAT>  */
  sck=0;
  cs=1;
end rbyte;
incdata:   procedure;          /* 参数修改--"加"键处理子程序+ */
if p10=0 then         /* 如果K7键按下*/
    do;
do while p10=0;       /* 等待键松开有效 */
  call dog;           /* 此处必需调用看门狗复位子程序("喂狗"),否则程序将被看门狗复位*/
end;
data=data+1;          /* 设定值+1 */
if data>99 then data=1;  /* 规定设定值的上限*/
L(1)=data MOD 10;       /*将设定值的十位数拆出来送给十位数显示变量L(1) */
L(2)=data/10;           /*将设定值的个位数拆出来送给个位数显示变量L(2) */
call display(L(1),L(2)); /* 将改变后的设定值送164显示出来*/
call time(200);         /* 延时 */
call dog;
call time(200);
call dog;
call wrenable;           /* 置存储器写使能 */
addrl=00h;               /* 置存储器地址 */
dat=l(1);
call wbyte;              /* 将变量L(1)的值写入存储器00h位置 */
call wrenable;
addrl=01h;
dat=l(2);
call wbyte;              /* 将变量L(2)的值写入存储器01h位置 */
      end;
end incdata;
decdata:   ROCEDURE;         /* 参数修改---"减"键处理子程序- */
IF p11=0 THEN         /* k8 键处理子程序 */
     do;
do while p11=0;
   call dog;
end;
DATA=DATA-1;             /* 设定值-1 */
if data=0 then data=99;
L(1)=data MOD 10;
L(2)=data/10;
call display(l(1),l(2));
call dog;
call time(200);
call dog;
call time(200);
call dog;
 call wrenable;
 addrl=00h;
 dat=l(1);
 call wbyte;
 call wrenable;
 addrl=01h;
 dat=l(2);
 call wbyte;
   end;
END decdata;
starton:   ROCEDURE;         /* start */
    declare sd byte;
    if p12=0 THEN         /* K9键处理子程序  */
 do;
     do while p12=0;
call dog;
     end;
     if p17=0 then ok=0;  /* 如果p17 口线上有信号输入,则运行标志置0 (停止运行)*/
     p13=1;              /* 置步进电机正向运转 */
     call time(200);
      call dog;
     do while ok=1;      /* 当运行标志为1时,执行速度延时操作 */
       do sd= 0 to data; /* 根据设定值 data的数值延时来确定步进电机运行时的脉冲给定速度*/
   call dog;
     end;
 end;
END starton;
step:   ROCEDURE;         /* step */
declare sd byte;
call time(200);
call dog;
IF p33=0 THEN      /* k11键处理子程序  */
  do;
if p17=0 then ok=0; /* 如果p17上有信号输入,则停止运行*/
do while p33=0;
   do sd= 0 to data; /* 调用延时,调整步进电机的运行速度 */
       call dog;
      call time(2);
   end;
   call run;
   call dog;
end;
 end;
 ok=0;
END step;
back:   ROCEDURE;         /* 反向运行处理子程序 */
declare sd byte;
IF p34=0 THEN
  do;
do while p34=0;
   call dog;
end;
if p15=0 then ok=0;   /* 反向运行时,如果遇到p15上有信号输入,则停止步进电机运行 */
p13=0;                /* 置步进电机反向运行 */
call time(200);
call dog;
     do while ok=1;
do sd=0 to data;     /*根据设定值调节步进电机的运行速度 */
   call dog;
   call time(2);
end;
call run;
if (p15=0 or p32=0 ) then ok=0; /* p15 或 p32 口线任意一个有信号输入,停止运行 */
     end;
 end;
END back;
MAIN$PROGRAM:    /* 初始化主程序 */
ea=0;             /* 关中断  */
SCON=00h;         /*置串口方式0 ,串行数据输出模式*/
PCON=00h;
tmod=11h;
et0=1;
enable;          /* 开中断 (ea=1) */
SCK=0;cs=1;      /* 定义存储器口线初始状态 */
call wrenable;
call wrregister;  /* 看门狗存储器 初始化  */
call wrenable;
call dog;
p2=0ffh;               /* 初始化各个口线的状态 */
p1=0ffh;ok=0;
p14=1;p32=1;p33=1;p34=1;
p13=1;
ADDRL=00h;     /* 上电复位后从存储器中读出设定的速度值   */
CALL rbyte;
l(1)=dat;
addrl=01h;
call rbyte;
l(2)=dat;
DATA=L(1)+L(2)*10;    /*将读出的值合并成十进制,存入变量data中 */
/* 以下是主循环程序 */
LOOP:
IF p10=0 THEN CALL incdata;  /* 检测各个按键是否有按下 */
IF p11=0 THEN CALL decdata;
if p12=0 then
  do;
     ok=1;
     call starton;
  end;
if p34=0 then
  do;
    ok=1;
    call back;
  end;
if p33=0 then
  do;
    ok=1;
    call step;
  end;
call dog;
CALL DISPLAY(L(1),L(2));  /* 将设定值送164显示 */
call dog;
CALL TIME(100);
call dog;
GOTO LOOP;
END START;
zusen 发表于 2007-12-27 13:18 | 显示全部楼层
看了,我晕了~
wtt1314 发表于 2007-12-27 14:13 | 显示全部楼层
有点长
看别人的程序真累!
zlgmcuCHTZ 发表于 2007-12-27 14:23 | 显示全部楼层
ZZZZZZZZZZZZZZZ
ayb_ice 发表于 2007-12-27 14:25 | 显示全部楼层
我还没有搞懂是汇编还是C
