S3C2440内部的RTC不用,引脚应该怎样连接?
4239|3
 楼主| joylight 发表于 2007-1-17 15:48 | 显示全部楼层 |阅读模式
XTIrtc&nbsp;AI&nbsp;32&nbsp;kHz&nbsp;crystal&nbsp;input&nbsp;for&nbsp;RTC.&nbsp;If&nbsp;it&nbsp;isn’t&nbsp;used,&nbsp;it&nbsp;has&nbsp;to&nbsp;be&nbsp;High&nbsp;(VDDRTC).<br />XTOrtc&nbsp;AO&nbsp;32&nbsp;kHz&nbsp;crystal&nbsp;output&nbsp;for&nbsp;RTC.&nbsp;If&nbsp;it&nbsp;isn’t&nbsp;used,&nbsp;it&nbsp;has&nbsp;to&nbsp;be&nbsp;Float.<br />晶振引脚没问题<br /><br />RTCVDD&nbsp;P&nbsp;RTC&nbsp;VDD&nbsp;(3.0V,&nbsp;Input&nbsp;range:&nbsp;1.8&nbsp;~&nbsp;3.6V)<br />This&nbsp;pin&nbsp;must&nbsp;be&nbsp;connected&nbsp;to&nbsp;power&nbsp;properly&nbsp;if&nbsp;RTC&nbsp;isn't&nbsp;used.<br /><br />RTCVDD应该如何接啊?怎么才算properly?
foyyof 发表于 2007-1-17 16:25 | 显示全部楼层
re:
使用RTC时,一般是将电源(or&nbsp;bat)连接个大点的电阻连接到VDDrtc。<br /><br />所以你也可以这么做,只不过是没电池而已罢了。
 楼主| joylight 发表于 2007-1-17 16:52 | 显示全部楼层
谢谢foyyof,电压用3.3V应该OK吧。
foyyof 发表于 2007-1-17 19:39 | 显示全部楼层
no problem!
