[嵌入式linux] 内核崩溃
1255|0
 楼主| 没咯将形 发表于 2016-1-16 22:46 | 显示全部楼层 |阅读模式
崩溃时曝出:
[20160114_21:08:28]Unable to handle kernel paging request at virtual address 0000ffb0
[20160114_21:08:28]atmel_mxt_ts 1-004a: Interrupt triggered but zero messages
[20160114_21:08:28]pgd = 80004000
[20160114_21:08:28][0000ffb0] *pgd=00000000
[20160114_21:08:28]Internal error: Oops - BUG: 17 [#1] PREEMPT SMP ARM
[20160114_21:08:28]Modules linked in: mbt8xxx(O) sd8xxx(O) mlan(PO) cfg80211
[20160114_21:08:28]CPU: 1 PID: 2220 Comm: kworker/1:2 Tainted: P           O 3.10.45 #591
[20160114_21:08:28]Workqueue: kinteractive_down 0x80315c88
[20160114_21:08:28]task: ace99900 ti: acacc000 task.ti: acacc000
[20160114_21:08:28]pc : [<804e90e0>]    lr : [<80313434>]    psr: 200f0013
[20160114_21:08:28]sp : acacdd78  ip : acacdd88  fp : acacdd84
[20160114_21:08:28]r10: 00000001  r9 : acacde68  r8 : 00000001
[20160114_21:08:28]r7 : acacde68  r6 : 00000002  r5 : ac34f2c0  r4 : 00000001
[20160114_21:08:28]r3 : acacc000  r2 : 00000001  r1 : 807e0001  r0 : 0000ffb0
[20160114_21:08:28]Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
[20160114_21:08:28]Control: 10c5387d  Table: 3c7c804a  DAC: 00000015
[20160114_21:08:28]Process kworker/1:2 (pid: 2220, stack limit = 0xacacc238)
[20160114_21:08:28]Stack: (0xacacdd78 to 0xacace000)
[20160114_21:08:29]dd60:                                                       acacdda4 acacdd88
[20160114_21:08:29]dd80: 80313434 804e90c4 80313378 fffffffe 00000000 00000000 acacddcc acacdda8
[20160114_21:08:29]dda0: 8004a420 80313384 ffffffff 807eff3c 807eff24 00000000 00000000 ffffffff
[20160114_21:08:29]ddc0: acacde04 acacddd0 8004a888 8004a3e0 00000000 8004a7b8 00000000 acacde68
[20160114_21:08:29]dde0: ac34b780 8076055c 00000001 807f0020 807560e0 810140e0 acacde1c acacde08
如何根据上面信息找到崩溃的函数?
